Zedx can not launch by argus_camera
HI nvidia:
I have a zedx camera, I can use
v4l2-ctl --set-fmt-video=width=1920,height=1200,pixelformat=BA10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=image-video0.raw
to get image, but I can not use argus_camera to get image,
nvargus_nvraw --lps
nvargus_nvraw version 1.14.0
Number of supported sensor entries 6
Entry Source Mode Uniquename Resolution FR BitDepth Mode
Index Index Index CSI Dyn Type
0 0 0 zedxar0234_bottomleft_0 1920x1200 59 10 10 Bayer
1 0 1 zedxar0234_bottomleft_0 960x 600 120 10 10 Bayer
2 0 2 zedxar0234_bottomleft_0 1920x1080 59 10 10 Bayer
3 1 0 zedxar0234_bottomright_0 1920x1200 59 10 10 Bayer
4 1 1 zedxar0234_bottomright_0 960x 600 120 10 10 Bayer
5 1 2 zedxar0234_bottomright_0 1920x1080 59 10 10 Bayer
argus-log.txt (28.1 KB)
kernel.txt (3.9 KB)
trace.txt (4.3 KB)
Please contact vendor of the camera module for support. The camera is not enabled on default Jetpack release, and you would need to add device tree and enable sensor driver.
HI DaneLLL:
I have already add device tree and enabel sensor driver
Looks like the driver or device tree may not be ready. Would be great if you can work with the vendor to debug further. Can refer to the debug tips in
Jetson/l4t/Camera BringUp - eLinux.org
