Hi, I am running a ROS node on TX2 which uses zlib. I add the following line to ROS package CMakefile to include the zlib:
target_link_libraries(TrackRun yaml-cpp uvc jetson-utils z ${catkin_LIBRARIES))
I found that to compress an 640K data block, it took 140ms on TX2. I need something much faster than that, like 25ms. Any one know a special zlib build for TX2 which would utilize the computation resource on the device, such as GPU?
