Series 550 freezes laptop
When the first beta 550 came out I was testing the driver and the laptop sometimes froze randomly. I didn’t know what was causing it until I went back to the 545 drivers and it was fixed.
I thought it would be a problem because they were beta but no. It also happens to me with the stable version.
When this happens to me, the laptop freezes and the “caps lock” light keeps flashing. (Watch video)
I think it may be due to some change with the systemd services added in version 550 because that is when it happens the most. It has already happened to me twice when I am updating the system and it breaks it because the update cannot be completed. In the video it happens when the specific hooks are being processed (reloading system manager configuration).
When I recovered the system I reviewed the logs and I did not see anything referring to the nvidia driver. So I can only provide the nvidia-bug-report with version 545.
To add something else, it also happened to me the other day when I was testing the nvidia-powerd service. I had the service running with a game open and I tried stopping/starting it and the laptop froze the same way. That’s why I associate it with systemd.
I also think it has happened to me sometimes with the desktop computer with manjaro, although I can’t be sure because I use the laptop more.
System:
EndeavourOS Linux x86_64
ASUS TUF Gaming A15 FA507XI_FA507XI 1.0
Kernel: 6.7.7-arch1-1
Plasma 5.27.10
CPU: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics
GPU: NVIDIA GeForce RTX 4070 Max-Q / Mobile
Driver: 550.54.14
Nvidia bug report version 545:
nvidia-bug-report.log.gz (4.2 MB)
I use endeavourOS(with kde) too on a lenovo legion 5(15h6h w/amd5600h+rtx3060) and can confirm random freezing on desktop use (currently ever since updating from 545 from nvidia-lts package i cannot also get nvidia to deep sleep which could affect stability?), REISUB works at least, when using nvidia-550 so i decided to wait for it and revert to 545, hope it gets fixed or else could be just distro specific.
If needed i can revert to back to nvidia-550 and fill bug report, for now i leave mine from 545:
nvidia-bug-report.log.gz (3.4 MB)
do you happen to get kernel panics with Call Trace’s related to zswap or anything memory management related?
I have the same Problem on CachyOS with KDE. The Laptop freezes most of the time while updating Packages or while logging off/shutting down the Laptop. Rarely happens when playing games. 545 works without Problems.
Specs:
Laptop: Lenovo Legion 7 Pro
Kernel: 6.7.8-2-cachyos
Plasma: 5.27.10
CPU: AMD Ryzen 9 7945HX
GPU: NVIDIA GeForce RTX 4090 Laptop GPU
The Bug Report is from 545:
nvidia-bug-report.log.gz (904.5 KB)
Hi All,
I would request everyone to share bug report from repro driver and share reliable repro steps if possible.
Here is the bug report from 550 stable:
nvidia-bug-report.log.gz (1.1 MB)
Repro Steps:
  1. Hard freeze while logging off/rebooting/shutting down
    1.1 Use Laptop for a while ~30min+ (play some Games, watch some Videos)
    1.2 Logging off/rebooting/shutting down via GUI or Terminal causes instant hard freeze
    Logging off/rebooting/shutting down works after I’ve just started the Laptop.
  2. Installing Packages e.g. virt-manager
    2.1 Use Laptop for a while ~30min+ (play some Games, watch some Videos)
    2.2 Install packages via pacman e.g. virt-manager
    2.3 Hard freeze at “Reloading system manager configuration…”
Forgot to add this happens on hybrid and dedicated mode.
No its not a kernel panic, as Input works from REISUB.
I got reports from last night, as I downgraded back to 545. I hope these are fine if not I will reproduce everything once again.
nvidia-bug-report.log.gz (2.1 MB)
kernel-panic.log (7.6 KB)
Steps to reproduce:
Unplug and plug charger over and over again until it freezes/kernel panics.
Other cases:
I found it to happen randomly, or just when chaining platform profiles.
Sometimes just when rebooting/powering off the machine, or randomly while booting/on the login screen.
It even happens when the GPU is not in use, powered off, on battery.
To mention, I use TLP for battery management, although I don’t think that has to do anything with this, system is in hybrid mode (prime offload).
System:
EndeavourOS
ASUS TUF Gaming F15 FX507ZM
Kernel: 6.7.8-zen
Plasma 5.27.10
CPU: i7-12700H
GPU: RTX 3060 Laptop
Driver: 550.54.14
@amrits i apologize for the incovenience caused.
Here is the bug report from 550:
nvidia-bug-report.log.gz (3.2 MB)
Reinstalled the nvidia 550 driver(nvidia-lts package) version now, RTD works too by the way so no problems there it seems :).
As for freezing, i just got one now and to reproduce:
After installing and checking things were loaded, i suspended the machine and right away i had a freeze on kde(v.5.27)
But this issue happens randomly, i just now did again and it did not happen, but in contrast e.g: the other day when i had vscode open, the app froze, then only mouse was working and then froze the system, REISUB worked still.
$nvidia-smi
Mon Mar 4 13:36:58 2024
| NVIDIA-SMI 550.54.14 Driver Version: 550.54.14 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 … On | 00000000:01:00.0 Off | N/A |
| N/A 31C P8 N/A / 55W | 8MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1174 G /usr/lib/Xorg 4MiB |
Specs/system:
OS:EndeavourOS
Laptop: Lenovo Legion 5
Kernel: 6.6.20-1-lts
Plasma: 5.27.10
CPU: AMD Ryzen 5 5600H
GPU: NVIDIA GeForce RTX 3060 Laptop GPU
Let me know if i missed anything more many thanks for the attention.
Hey Guys.
Same Problem here with Arch Linux on Nvidia-dkms (550).
I’m using a HP ZBook fury G9 with an NVIDIA RTX A2000 8GB dedicated GPU.
Steps to reproduce:
Just use the Laptop for 30 Minutes. It’s faster when you reactivate the Laptop from S3 Suspend. The Laptop and the Picture Freezes and you get a Kernel Panic. (see file)
The second file shows the packages, which I’ve upgraded and then causes the Problem.
I’ve now downgraded to the 535xx AUR Package. It works well.
I hope this helps.
-Roman
pacman-upgrade.log (1.0 KB)
kernel-panic.log (11.0 KB)
In my case I cannot provide the report with version 550 because I need the laptop operational and I cannot risk losing the system. At least until the weekend and in case it is necessary.
But in the case of the video it happened to me as other users have already reported. I had the laptop in sleep, I woke it up, I watched some videos and when installing a package it freezes at the “Reloading system manager configuration…” step.
I hope that with the information already provided it is enough to detect the problem.
I face the same problem with a 4060 mobile. Anything new about this?
The 550.40.55 Vulkan Dev driver doesnt have the freezing issues. Here is the bug report for it if it helps:
nvidia-bug-report.log.gz (1.3 MB)
Ah false alarm, sadly it just froze randomly again. Back to 545 it is.
I am having the same issue with a 3060 laptop card. The system freezes started after upgrading to driver v550 last week.
System:
OS: Manjaro Arch Linux x86_64
Laptop: Lenovo X1 Extreme Gen4
Kernel: 6.7.7-1-MANJARO
KDE Plasma: 5.27.10
CPU: 11th Gen Intel(R) Core™ i7-11800H @ 2.30GHz
GPU: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
Driver: 550.54.14
Here is the output of running sudo inxi -Gazy:
Graphics:
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 30c9:0031
    class-ID: 0e02 serial: <filter>
  Display: server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP1 model-id: CSO 0x1603 built: 2020
    res: 2560x1600 hz: 60 dpi: 191 gamma: 1.2 size: 340x220mm (13.39x8.66")
    diag: 406mm (16") ratio: 16:10 modes: 2560x1600
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
    drv: nvidia x11: drv: iris inactive: gbm,wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
    device-ID: 8086:9a60 memory: 61.06 GiB unified: yes
  API: Vulkan v: 1.3.276 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.54.14
    device-ID: 10de:2520 surfaces: xcb,xlib
The trigger to cause the freeze is not consistent. The most reliable way to trigger it seems to be inserting / removing a USB-C cable which connects a single external monitor to the laptop. When the freeze starts to happen, I can move the mouse around sometimes but the UI does not respond and eventually the mouse cursor does not move anymore. There does not seem to be any correlation between the freeze and the applications which are running when it happens.
What is very interesting is that events like watchdog: BUG: soft lockup - CPU#14 stuck for 78s! are logged several times for different CPU threads in the journalctl log when the freeze is happening. I can’t access a virtual TTY when the freeze happens and can only pull the logs after doing a hard shutdown and starting the system again.
Using only the Intel UHD graphics seems to prevent the issue, but I can’t connect the external display to the laptop in this state :(.
nvidia-bug-report.log.gz (388.9 KB)
All reports seem arch or derived.
Maybe it only affects arch?
In any case, it would be good to know if something has been detected or if it is at least being investigated.
Well, same problem here. I’m using a Asus TUF a15 FA506QM. When I do pacman -Syu I get the same error from the OP video, BLOQ MAYUS key to blink at reloading system manager configuration and the computer freeze. I test with linux-zen, linux and linux-lts kernel with the same result. I’m using Arch Linux and nvidia-dkms 550.54.14-4 package. I will to try rollback to 5.45 version.
I have a similar problem using NixOS (unstable). Version 545 runs stable - unfortunately NixOS does not include nvidia-bug-report.sh.
Crashes happen in X and Wayland, but I don’t use Wayland because it has a huge mouse lag on my 4k screen.
Kernel version was 6.7.6.
The Laptop is a Lenovo Legion 7i Gen 8 (Intel 13900HX, 32GB DDR5 5600MHz, NVidia RTX 4080).
The system is a NixOS running unstable using btrfs + LUKS on a Kingston FURY Renegade PCIe 4.0 NVMe M.2 SSD.
Mär 03 12:03:03 markusnix kernel: BUG: kernel NULL pointer dereference, address: 00000000000000eb
Mär 03 12:03:03 markusnix systemd[1]: Started Journal Service.
Mär 03 12:03:03 markusnix kernel: #PF: supervisor read access in kernel mode
Mär 03 12:03:03 markusnix kernel: #PF: error_code(0x0000) - not-present page
Mär 03 12:03:03 markusnix kernel: PGD 0 P4D 0
Mär 03 12:03:03 markusnix kernel: Oops: 0000 [#15] PREEMPT SMP NOPTI
Mär 03 12:03:03 markusnix kernel: CPU: 8 PID: 2793 Comm: systemd-journal Tainted: P      D    O       6.7.6 #1-NixOS
Mär 03 12:03:03 markusnix kernel: Hardware name: LENOVO 82WQ/LNVNB161216, BIOS KWCN42WW 09/15/2023
Mär 03 12:03:03 markusnix kernel: RIP: 0010:simple_xattr_get+0x31/0xa0
Mär 03 12:03:03 markusnix kernel: Code: 00 00 41 56 49 89 ce 41 55 4c 8d 6f 08 41 54 49 89 d4 55 48 89 f5 53 48 89 fb 4c 89 ef e8 e7 e9 72 00 48 8b 1b 48 85 db 74 1b <48> 8b 7b 18 48 89 ee e8 33 1c 70 00 85 c0 78 27 74 2b 48 8b 5b 08
Mär 03 12:03:03 markusnix kernel: RSP: 0018:ffff9ac283d33cf8 EFLAGS: 00010202
Mär 03 12:03:03 markusnix kernel: RAX: 0000000000001c00 RBX: 00000000000000d3 RCX: 0000000000000067
Mär 03 12:03:03 markusnix kernel: RDX: ffff915e099fca00 RSI: ffff9ac283d33dc8 RDI: ffff915e176ce5e0
Mär 03 12:03:03 markusnix kernel: RBP: ffff9ac283d33dc8 R08: ffff915e099fca00 R09: 0000000000000067
Mär 03 12:03:03 markusnix kernel: R10: ffff9ac283d33dc8 R11: 0000000000000000 R12: ffff915e099fca00
Mär 03 12:03:03 markusnix kernel: R13: ffff915e176ce5e0 R14: 0000000000000067 R15: ffff9ac283d33dc8
Mär 03 12:03:03 markusnix kernel: FS:  00007f45be8820c0(0000) GS:ffff91658d000000(0000) knlGS:0000000000000000
Mär 03 12:03:03 markusnix kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mär 03 12:03:03 markusnix kernel: CR2: 00000000000000eb CR3: 000000015148c000 CR4: 0000000000f50ef0
Mär 03 12:03:03 markusnix kernel: PKRU: 55555554
Mär 03 12:03:03 markusnix kernel: Call Trace:
Mär 03 12:03:03 markusnix kernel:  <TASK>
Mär 03 12:03:03 markusnix kernel:  ? __die+0x23/0x70
Mär 03 12:03:03 markusnix kernel:  ? page_fault_oops+0x17d/0x4b0
Mär 03 12:03:03 markusnix kernel:  ? exc_page_fault+0x72/0x160
Mär 03 12:03:03 markusnix kernel:  ? asm_exc_page_fault+0x26/0x30
Mär 03 12:03:03 markusnix kernel:  ? simple_xattr_get+0x31/0xa0
Mär 03 12:03:03 markusnix kernel:  ? simple_xattr_get+0x29/0xa0
Mär 03 12:03:03 markusnix kernel:  __vfs_getxattr+0x7f/0xb0
Mär 03 12:03:03 markusnix kernel:  do_getxattr+0xf0/0x180
Mär 03 12:03:03 markusnix kernel:  getxattr+0x91/0xd0
Mär 03 12:03:03 markusnix kernel:  path_getxattr+0x7b/0xd0
Mär 03 12:03:03 markusnix kernel:  do_syscall_64+0x44/0x100
Mär 03 12:03:03 markusnix kernel:  entry_SYSCALL_64_after_hwframe+0x6f/0x77
Mär 03 12:03:03 markusnix kernel: RIP: 0033:0x7f45bed20c8e
Mär 03 12:03:03 markusnix kernel: Code: 01 0d 00 f7 d8 64 89 02 ba ff ff ff ff eb d5 e8 f8 37 01 00 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 49 89 ca b8 c0 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 72 01 0d 00 f7 d8 64 89 01 48
Mär 03 12:03:03 markusnix kernel: RSP: 002b:00007ffed7f80038 EFLAGS: 00000246 ORIG_RAX: 00000000000000c0
Mär 03 12:03:03 markusnix kernel: RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f45bed20c8e
Mär 03 12:03:03 markusnix kernel: RDX: 0000555c1412be80 RSI: 0000555c137c78f0 RDI: 0000555c1412bbe0
Mär 03 12:03:03 markusnix kernel: RBP: 0000555c1412be80 R08: 0000000000000070 R09: 0000000000000001
Mär 03 12:03:03 markusnix kernel: R10: 0000000000000067 R11: 0000000000000246 R12: 0000555c1412bbe0
Mär 03 12:03:03 markusnix kernel: R13: 0000555c137c78f0 R14: 0000000000000068 R15: 0000000000000007
Mär 03 12:03:03 markusnix kernel:  </TASK>
Mär 03 12:03:03 markusnix kernel: Modules linked in: nft_chain_nat xt_MASQUERADE nf_conntrack_netlink xfrm_user xfrm_algo xt_addrtype ccm af_packet cmac algif_hash algif_skcipher af_alg bnep msr xt_conntrack ip6t_rpfilter ipt_rpfilter xt_pkttype xt_LOG nf_log_syslog xt_tcpudp nft_compat nf_tables sch_fq_codel snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio uinput snd_sof_pci_intel_tgl snd_sof_intel_hda_common snd_soc_hdac_hda soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_hda_codec_hdmi snd_sof snd_sof_utils snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_generic_allocation soundwire_bus iwlmvm r8153_ecm cdc_ether hid_multitouch usbnet i915 mac80211 nls_iso8859_1 ptp nls_cp437 pps_core libarc4 vfat fat btusb uvcvideo btrtl btintel snd_hda_scodec_tas2781_i2c btbcm intel_uncore_frequency videobuf2_vmalloc snd_soc_tas2781_fmwlib btmtk intel_uncore_frequency_common uvc videobuf2_memops intel_tcc_cooling snd_hda_intel videobuf2_v4l2 snd_soc_tas2781_comlib
Mär 03 12:03:03 markusnix kernel:  bluetooth drm_buddy snd_intel_dspcfg x86_pkg_temp_thermal snd_intel_sdw_acpi videodev snd_soc_core ttm cmdlinepart iTCO_wdt intel_powerclamp snd_hda_codec intel_pmc_bxt spi_nor iwlwifi drm_display_helper watchdog intel_rapl_msr joydev videobuf2_common mousedev processor_thermal_device_pci snd_compress snd_hda_core processor_thermal_device r8152 coretemp processor_thermal_wt_hint ac97_bus mtd mc processor_thermal_rfim snd_pcm_dmaengine crc32_pclmul snd_hwdep polyval_clmulni mii mei_pxp mei_hdcp cec processor_thermal_rapl polyval_generic snd_pcm ecdh_generic r8169 gf128mul pmt_telemetry intel_rapl_common intel_gtt ecc pmt_class ghash_clmulni_intel ucsi_acpi crc16 snd_timer intel_lpss_pci ideapad_laptop realtek typec_ucsi agpgart processor_thermal_wt_req i2c_i801 evdev tpm_crb sparse_keymap spi_intel_pci processor_thermal_power_floor mdio_devres intel_lpss rapl wmi_bmof nvidia_wmi_ec_backlight snd idma64 intel_cstate cfg80211 i2c_hid_acpi intel_uncore libphy typec platform_profile tpm_tis spi_intel i2c_smbus
Mär 03 12:03:03 markusnix kernel:  i2c_algo_bit soundcore roles virt_dma processor_thermal_mbox mac_hid intel_vsec rfkill crc8 i2c_hid mei_me int3403_thermal battery int340x_thermal_zone int3400_thermal tpm_tis_core intel_pmc_core serio_raw pinctrl_alderlake acpi_thermal_rel acpi_tad acpi_pad mei tiny_power_button ac button nvidia_drm(PO) drm_kms_helper nvidia_modeset(PO) video wmi nvidia_uvm(PO) nvidia(PO) ctr loop cpufreq_powersave xt_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 br_netfilter veth tun tap macvlan bridge stp llc kvm_intel kvm drm irqbypass fuse efi_pstore backlight configfs nfnetlink efivarfs dmi_sysfs ip_tables x_tables autofs4 dm_crypt aes_generic cbc encrypted_keys trusted asn1_encoder tee tpm rng_core hid_generic usbhid hid xhci_pci xhci_pci_renesas input_leds firmware_class led_class xhci_hcd atkbd nvme libps2 thunderbolt vivaldi_fmap usbcore sha512_ssse3 nvme_core sha512_generic sha256_ssse3 sha1_ssse3 aesni_intel t10_pi libaes crypto_simd cryptd crc64_rocksoft rtc_cmos crc64 crc_t10dif i8042
Mär 03 12:03:03 markusnix kernel:  crct10dif_generic crct10dif_pclmul usb_common crct10dif_common serio dm_mod dax btrfs blake2b_generic libcrc32c crc32c_generic crc32c_intel xor raid6_pq
Mär 03 12:03:03 markusnix kernel: ---[ end trace 0000000000000000 ]---
Mär 03 12:03:03 markusnix kernel: RSP: 0018:ffff9ac280bcfcf8 EFLAGS: 00010202
Mär 03 12:03:03 markusnix kernel: RAX: 0000000000000000 RBX: 00000000000000d3 RCX: 0000000000000067
Mär 03 12:03:03 markusnix kernel: RDX: ffff915e04f4bd80 RSI: ffff9ac280bcfdc8 RDI: ffff915e176ce5e0
Mär 03 12:03:03 markusnix kernel: RBP: ffff9ac280bcfdc8 R08: ffff915e04f4bd80 R09: 0000000000000067
Mär 03 12:03:03 markusnix kernel: R10: ffff9ac280bcfdc8 R11: 0000000000000000 R12: ffff915e04f4bd80
Mär 03 12:03:03 markusnix kernel: R13: ffff915e176ce5e0 R14: 0000000000000067 R15: ffff9ac280bcfdc8
Mär 03 12:03:03 markusnix kernel: note: systemd-journal[2793] exited with irqs disabled
Mär 03 12:03:03 markusnix kernel: note: systemd-journal[2793] exited with preempt_count 1
The issue on my machine seems to be triggered reliably after some testing last night . When performing a restart or shutdown the systemd services begin stopping, and then the kernel oops & system hang occurs. The first time it happened, I’d been using the laptop normally for 2-3 hours and then the hang triggered when performing a restart from the KDE start menu.
After doing a hard shutdown and starting up the machine again, another system hang randomly occurred ~6 minutes after that boot. There was no obvious trigger this time, it seemed to freeze without any user interaction. When this hang occurred there were several journal logs for “kernel: watchdog: BUG: soft lockup - CPU stuck”:
6941 Mar 14 00:31:58 void kernel: BUG: kernel NULL pointer dereference, address: 000000000000000a
6942 Mar 14 00:31:58 void kernel: #PF: supervisor read access in kernel mode
6943 Mar 14 00:31:58 void kernel: #PF: error_code(0x0000) - not-present page
6944 Mar 14 00:31:58 void kernel: PGD 0 P4D 0
6945 Mar 14 00:31:58 void kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
6946 Mar 14 00:31:58 void kernel: CPU: 15 PID: 1237 Comm: QXcbEventQueue Tainted: P           OE      6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
6947 Mar 14 00:31:58 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
6948 Mar 14 00:31:58 void kernel: RIP: 0010:refill_obj_stock+0x4f/0x180
7014 Mar 14 00:32:23 void kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 27s! [baloo_file_extr:1239]
7082 Mar 14 00:32:23 void kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 27s! [baloo_file:999]
7149 Mar 14 00:32:23 void kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 27s! [baloo_file_extr:1235]
7153 Mar 14 00:32:23 void kernel: CPU: 13 PID: 1235 Comm: baloo_file_extr Tainted: P      D    OEL     6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
7154 Mar 14 00:32:23 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
7155 Mar 14 00:32:23 void kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x6e/0x2e0
7199 Mar 14 00:32:51 void kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 53s! [baloo_file_extr:1239]
7267 Mar 14 00:32:51 void kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 53s! [baloo_file:999]
7271 Mar 14 00:32:51 void kernel: CPU: 8 PID: 999 Comm: baloo_file Tainted: P      D    OEL     6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
7272 Mar 14 00:32:51 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
7273 Mar 14 00:32:51 void kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x2a5/0x2e0
7334 Mar 14 00:32:51 void kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 53s! [baloo_file_extr:1235]
the crash occurs, and
7384 Mar 14 00:32:58 void kernel: rcu: INFO: rcu_preempt self-detected stall on CPU
7385 Mar 14 00:32:58 void kernel: rcu:         13-....: (17999 ticks this GP) idle=97b4/1/0x4000000000000000 softirq=5928/5928 fqs=5998
7386 Mar 14 00:32:58 void kernel: rcu:         (t=18000 jiffies g=31445 q=5265 ncpus=16)
7387 Mar 14 00:32:58 void kernel: Sending NMI from CPU 13 to CPUs 6:
7388 Mar 14 00:32:58 void kernel: NMI backtrace for cpu 6
7389 Mar 14 00:32:58 void kernel: CPU: 6 PID: 1239 Comm: baloo_file_extr Tainted: P      D    OEL     6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
7390 Mar 14 00:32:58 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
7391 Mar 14 00:32:58 void kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x223/0x2e0
7505 Mar 14 00:33:19 void kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 79s! [baloo_file:999]
7572 Mar 14 00:33:23 void kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 82s! [baloo_file_extr:1239]
After this 2nd hang occurred, I booted the system one more time (2 minutes after the 2nd hard shutdown). 12 minutes later I performed a normal shutdown in the KDE start menu and this is where things got interesting. The system hung with a black screen pretty much immediately and would not respond to any user input.
I left it running overnight and did a hard shutdown in the morning to see what it would log overnight, but when checking the journal log today there was nothing logged past 1 second after the shutdown was initiated. Below is the complete journal log from this instance of hanging and the subsequent boot entry this evening
 21512	Mar 14 00:55:27 void systemd[876]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
 21513	Mar 14 00:55:27 void systemd[876]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
 21514	Mar 14 00:55:31 void systemd[876]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
 21515	Mar 14 00:55:31 void systemd[876]: Started dbus-:1.2-org.kde.Shutdown@0.service.
 21516	Mar 14 00:55:31 void msm_kde_notifier[1180]: Shutting down MSM Notifier...
 21517	Mar 14 00:55:31 void kded5[958]: Service  ":1.46" unregistered
 21518	Mar 14 00:55:31 void kded5[958]: Service  ":1.48" unregistered
 21519	Mar 14 00:55:31 void kded5[958]: Service  ":1.47" unregistered
 21520	Mar 14 00:55:31 void polkitd[678]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.48, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
 21521	Mar 14 00:55:31 void systemd[876]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 2.158s CPU time.
 21522	Mar 14 00:55:31 void systemd[876]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=exited, status=1/FAILURE
 21523	Mar 14 00:55:31 void systemd[876]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
 21524	Mar 14 00:55:31 void systemd[876]: plasma-plasmashell.service: Consumed 4.276s CPU time.
 21525	Mar 14 00:55:32 void kded5[958]: Service  ":1.57" unregistered
 21526	Mar 14 00:55:32 void systemd[876]: app-dropbox@autostart.service: Failed with result 'signal'.
 21527	Mar 14 00:55:32 void systemd[876]: app-dropbox@autostart.service: Consumed 7.215s CPU time.
 21528	Mar 14 00:55:32 void systemd[876]: Stopped target plasma-workspace-x11.target.
 21529	Mar 14 00:55:32 void systemd[876]: Stopped target KDE Plasma Workspace.
 21530	Mar 14 00:55:32 void systemd[876]: Stopped target Startup of XDG autostart applications.
 21531	Mar 14 00:55:32 void systemd[876]: Stopping Geoclue Demo agent...
 21532	Mar 14 00:55:32 void systemd[876]: Stopping Accessibility...
 21533	Mar 14 00:55:32 void dbus-broker[1436]: Dispatched 747 messages @ 2(±3)μs / message.
 21534	Mar 14 00:55:32 void systemd[876]: Stopping Accessibility services bus...
 21535	Mar 14 00:55:32 void systemd[876]: Stopping KDE Global Shortcuts Server...
 21536	Mar 14 00:55:32 void systemd[876]: Stopping KScreen...
 21537	Mar 14 00:55:32 void systemd[876]: Stopping KDE Window Manager...
 21538	Mar 14 00:55:32 void systemd[876]: Stopping Powerdevil...
 21539	Mar 14 00:55:32 void systemd[876]: Stopping Xdg Desktop Portal For KDE...
 21540	Mar 14 00:55:32 void systemd[876]: Stopping Portal service...
 21541	Mar 14 00:55:32 void systemd[876]: Stopping flatpak document portal service...
 21542	Mar 14 00:55:32 void systemd[876]: Stopping sandboxed app permission store...
 21543	Mar 14 00:55:32 void systemd[876]: Stopping Baloo File Indexer Daemon...
 21544	Mar 14 00:55:32 void systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
 21545	Mar 14 00:55:32 void systemd[876]: Stopped sandboxed app permission store.
 21546	Mar 14 00:55:32 void systemd[876]: Stopped KDE Global Shortcuts Server.
 21547	Mar 14 00:55:32 void systemd[876]: Stopped KDE Session Management Server.
 21548	Mar 14 00:55:32 void systemd[876]: Stopped KScreen.
 21549	Mar 14 00:55:32 void systemd[876]: Stopped Geoclue Demo agent.
 21550	Mar 14 00:55:32 void systemd[876]: Stopped flatpak document portal service.
 21551	Mar 14 00:55:32 void systemd[876]: Stopped Accessibility.
 21552	Mar 14 00:55:32 void systemd[876]: Stopped target Current graphical user session.
 21553	Mar 14 00:55:32 void systemd[876]: Stopping KActivityManager Activity manager Service...
 21554	Mar 14 00:55:32 void systemd[876]: Stopped Xdg Desktop Portal For KDE.
 21555	Mar 14 00:55:32 void systemd[876]: Stopped Accessibility services bus.
 21556	Mar 14 00:55:32 void systemd-logind[679]: The system will power off now!
 21557	Mar 14 00:55:32 void systemd[876]: Stopped Portal service.
 21558	Mar 14 00:55:32 void systemd[876]: Stopped KActivityManager Activity manager Service.
 21559	Mar 14 00:55:32 void systemd[876]: Stopped Powerdevil.
 21560	Mar 14 00:55:32 void systemd-logind[679]: System is powering down.
 21561	Mar 14 00:55:32 void systemd[876]: Created slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
 21562	Mar 14 00:55:32 void systemd[876]: Stopped target KDE Plasma Workspace Core.
 21563	Mar 14 00:55:32 void systemd[876]: Started dbus-:1.2-org.freedesktop.Notifications@0.service.
 21564	Mar 14 00:55:32 void systemd[876]: Stopping KDE Daemon...
 21565	Mar 14 00:55:32 void systemd[876]: kde-baloo.service: Failed to kill control group /user.slice/user-1000.slice/user@1000.service/background.slice/kde-baloo.service, ignoring: Invalid argument
 21566	Mar 14 00:55:32 void systemd[876]: Stopped Baloo File Indexer Daemon.
 21567	Mar 14 00:55:32 void systemd[876]: kde-baloo.service: Consumed 1min 9.944s CPU time, 523.8M memory peak, 4.4G memory swap peak.
 21568	Mar 14 00:55:32 void systemd[1]: Stopping Session 2 of User pdf...
 21569	Mar 14 00:55:32 void systemd[876]: Stopped KDE Window Manager.
 21570	Mar 14 00:55:32 void systemd[876]: plasma-kwin_x11.service: Consumed 13.165s CPU time.
 21571	Mar 14 00:55:32 void systemd[876]: Stopped target Session services which should run early before the graphical session is brought up.
 21572	Mar 14 00:55:32 void sddm[810]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
 21573	Mar 14 00:55:32 void sddm[810]: Auth: sddm-helper (--socket /tmp/sddm-auth-6dbe7960-9914-4150-9981-3a1b0ca58594 --id 1 --start /usr/bin/startplasma-x11 --user pdf) crashed (exit code 1)
 21574	Mar 14 00:55:32 void sddm[810]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
 21575	Mar 14 00:55:32 void sddm[810]: Auth: sddm-helper exited with 1
 21576	Mar 14 00:55:32 void systemd[1]: Removed slice Slice /system/dbus-:1.1-org.kde.powerdevil.backlighthelper.
 21577	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21578	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21579	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21580	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21581	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21582	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21583	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21584	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21585	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21586	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21587	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21588	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21589	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21590	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21591	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21592	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21593	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21594	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21595	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21596	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21597	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21598	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21599	Mar 14 00:55:32 void kded5[958]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 21600	Mar 14 00:55:32 void kded5[958]: kf.notifications: Had queued notifications on destruction. Was the eventloop running?
 21601	Mar 14 00:55:32 void kded5[958]: kf.notifications: Playing audio notification failed: Destroyed
 21602	Mar 14 00:55:32 void systemd[876]: Stopped KDE Daemon.
 21603	Mar 14 00:55:32 void systemd[1]: Removed slice Slice /system/dbus-:1.1-org.kde.powerdevil.chargethresholdhelper.
 21604	Mar 14 00:55:32 void systemd[1]: Removed slice Slice /system/dbus-:1.1-org.kde.powerdevil.discretegpuhelper.
 21605	Mar 14 00:55:32 void systemd[1]: Removed slice Slice /system/getty.
 21606	Mar 14 00:55:32 void kernel: BUG: kernel NULL pointer dereference, address: 000000000000000a
 21607	Mar 14 00:55:32 void kernel: #PF: supervisor read access in kernel mode
 21608	Mar 14 00:55:32 void kernel: #PF: error_code(0x0000) - not-present page
 21609	Mar 14 00:55:32 void kernel: PGD 0 P4D 0
 21610	Mar 14 00:55:32 void kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
 21611	Mar 14 00:55:32 void kernel: CPU: 6 PID: 1154 Comm: QXcbEventQueue Tainted: P           OE      6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
 21612	Mar 14 00:55:32 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
 21613	Mar 14 00:55:32 void kernel: RIP: 0010:refill_obj_stock+0x4f/0x180
 21614	Mar 14 00:55:32 void kernel: Code: c7 40 08 03 00 65 4c 03 3d 7e 61 e3 73 49 8b 47 10 48 39 f8 0f 84 9c 00 00 00 4c 89 ff e8 59 f2 ff ff 49 89 c6 e8 61 ab d8 ff <48> 8b 45 00 a8 03 0f 85 c9 00 00 00 65 48 ff 00 e8 5c e3 d8 ff 49
 21615	Mar 14 00:55:32 void kernel: RSP: 0018:ffffb9de02e3f940 EFLAGS: 00010002
 21616	Mar 14 00:55:32 void kernel: RAX: 0000000000000002 RBX: 00000000000002dd RCX: ffff981a55c21460
 21617	Mar 14 00:55:32 void kernel: RDX: ffff981a6cb09800 RSI: 00000000000002dd RDI: ffff98296f5b0840
 21618	Mar 14 00:55:32 void kernel: RBP: 000000000000000a R08: ffff981a6d65ac30 R09: 0000000000000000
 21619	Mar 14 00:55:32 void kernel: R10: ffff981a55c21460 R11: 0000000000000000 R12: 0000000000000206
 21620	Mar 14 00:55:32 void kernel: R13: 00000000000231b4 R14: ffff981a84a1c880 R15: ffff98296f5b0840
 21621	Mar 14 00:55:32 void kernel: FS:  0000000000000000(0000) GS:ffff98296f580000(0000) knlGS:0000000000000000
 21622	Mar 14 00:55:32 void kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
 21623	Mar 14 00:55:32 void kernel: CR2: 000000000000000a CR3: 0000000644420006 CR4: 0000000000f70ef0
 21624	Mar 14 00:55:32 void kernel: PKRU: 55555554
 21625	Mar 14 00:55:32 void kernel: Call Trace:
 21626	Mar 14 00:55:32 void kernel:  <TASK>
 21627	Mar 14 00:55:32 void kernel:  ? __die+0x23/0x70
 21628	Mar 14 00:55:32 void kernel:  ? page_fault_oops+0x171/0x4e0
 21629	Mar 14 00:55:32 void kernel:  ? kernel_text_address+0x115/0x120
 21630	Mar 14 00:55:32 void kernel:  ? exc_page_fault+0x7f/0x180
 21631	Mar 14 00:55:32 void kernel:  ? asm_exc_page_fault+0x26/0x30
 21632	Mar 14 00:55:32 void kernel:  ? refill_obj_stock+0x4f/0x180
 21633	Mar 14 00:55:32 void kernel:  obj_cgroup_uncharge_zswap+0x1d/0x60
 21634	Mar 14 00:55:32 void kernel:  zswap_free_entry+0x1b/0x150
 21635	Mar 14 00:55:32 void kernel:  zswap_invalidate+0x73/0x80
 21636	Mar 14 00:55:32 void kernel:  swap_range_free+0x7e/0xd0
 21637	Mar 14 00:55:32 void kernel:  swapcache_free_entries+0x10e/0x270
 21638	Mar 14 00:55:32 void kernel:  free_swap_slot+0xb4/0xc0
 21639	Mar 14 00:55:32 void kernel:  __swap_entry_free+0x72/0x90
 21640	Mar 14 00:55:32 void kernel:  free_swap_and_cache+0x3d/0x80
 21641	Mar 14 00:55:32 void kernel:  unmap_page_range+0x7b3/0x1130
 21642	Mar 14 00:55:32 void kernel:  unmap_vmas+0xb5/0x190
 21643	Mar 14 00:55:32 void kernel:  exit_mmap+0xec/0x340
 21644	Mar 14 00:55:32 void kernel:  __mmput+0x3e/0x130
 21645	Mar 14 00:55:32 void kernel:  do_exit+0x31c/0xb60
 21646	Mar 14 00:55:32 void kernel:  do_group_exit+0x31/0x80
 21647	Mar 14 00:55:32 void kernel:  get_signal+0xa98/0xab0
 21648	Mar 14 00:55:32 void kernel:  arch_do_signal_or_restart+0x3e/0x270
 21649	Mar 14 00:55:32 void kernel:  exit_to_user_mode_prepare+0x18a/0x1f0
 21650	Mar 14 00:55:32 void kernel:  syscall_exit_to_user_mode+0x1b/0x40
 21651	Mar 14 00:55:32 void kernel:  do_syscall_64+0x70/0xe0
 21652	Mar 14 00:55:32 void kernel:  ? exc_page_fault+0x7f/0x180
 21653	Mar 14 00:55:32 void kernel:  entry_SYSCALL_64_after_hwframe+0x6e/0x76
 21654	Mar 14 00:55:32 void kernel: RIP: 0033:0x7a851c7190bf
 21655	Mar 14 00:55:32 void kernel: Code: Unable to access opcode bytes at 0x7a851c719095.
 21656	Mar 14 00:55:32 void kernel: RSP: 002b:00007a8513dffbd0 EFLAGS: 00000293 ORIG_RAX: 0000000000000007
 21657	Mar 14 00:55:32 void kernel: RAX: fffffffffffffdfc RBX: 00005e7f2adaf320 RCX: 00007a851c7190bf
 21658	Mar 14 00:55:32 void kernel: RDX: 00000000ffffffff RSI: 0000000000000001 RDI: 00007a8513dffc08
 21659	Mar 14 00:55:32 void kernel: RBP: 00005e7f2adaf320 R08: 0000000000000000 R09: 0000000000000001
 21660	Mar 14 00:55:32 void kernel: R10: 00007a850c009b20 R11: 0000000000000293 R12: 0000000000000000
 21661	Mar 14 00:55:32 void kernel: R13: 0000000000000000 R14: 00005e7f2adaf338 R15: 00007a8513dffc08
 21662	Mar 14 00:55:32 void kernel:  </TASK>
 21663	Mar 14 00:55:32 void kernel: Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg snd_ctl_led snd_soc_skl_hda_dsp snd_soc_hdac_hdmi snd_soc_intel_hda_dsp_common snd_sof_probes snd_hda_codec_realtek snd_hda_codec_generic snd_soc_dmic qrtr bnep uinput nvidia_uvm(POE) snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof nvidia_drm(POE) snd_sof_utils intel_tcc_cooling snd_soc_hdac_hda snd_hda_ext_core btusb x86_pkg_temp_thermal btrtl intel_powerclamp snd_soc_acpi_intel_match uvcvideo snd_soc_acpi btintel iwlmvm videobuf2_vmalloc soundwire_generic_allocation btbcm coretemp uvc soundwire_bus btmtk videobuf2_memops nvidia_modeset(POE) snd_soc_core mac80211 videobuf2_v4l2 bluetooth snd_compress kvm_intel videodev snd_hda_codec_hdmi ac97_bus snd_pcm_dmaengine libarc4 videobuf2_common vfat ptp mc fat joydev ecdh_generic snd_hda_intel mousedev i915 snd_intel_dspcfg pps_core kvm snd_intel_sdw_acpi snd_hda_codec snd_hda_core
 21664	Mar 14 00:55:32 void kernel:  irqbypass snd_hwdep drm_buddy iwlwifi hid_multitouch thinkpad_acpi i2c_algo_bit processor_thermal_device_pci_legacy iTCO_wdt snd_pcm processor_thermal_device ttm intel_pmc_bxt nvidia(POE) ledtrig_audio rapl processor_thermal_wt_hint snd_timer mei_hdcp mei_pxp ee1004 drm_display_helper processor_thermal_rfim iTCO_vendor_support intel_cstate platform_profile think_lmi intel_rapl_msr firmware_attributes_class wmi_bmof cfg80211 spi_nor cec processor_thermal_rapl intel_lpss_pci mei_me snd i2c_i801 intel_uncore psmouse mtd pcspkr rfkill intel_rapl_common intel_gtt intel_lpss i2c_hid_acpi soundcore i2c_smbus mei idma64 processor_thermal_wt_req video i2c_hid processor_thermal_power_floor ucsi_acpi processor_thermal_mbox int3403_thermal typec_ucsi int340x_thermal_zone thunderbolt typec int3400_thermal intel_soc_dts_iosf roles acpi_thermal_rel intel_pmc_core wmi acpi_pad pinctrl_tigerlake acpi_tad mac_hid vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) i2c_dev fuse crypto_user loop nfnetlink ip_tables x_tables ext4
 21665	Mar 14 00:55:32 void kernel:  crc32c_generic crc16 mbcache jbd2 hid_generic usbhid dm_crypt cbc encrypted_keys trusted asn1_encoder tee dm_mod crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic gf128mul rtsx_pci_sdmmc ghash_clmulni_intel sha512_ssse3 mmc_core sha256_ssse3 serio_raw sha1_ssse3 nvme atkbd aesni_intel libps2 vivaldi_fmap crypto_simd nvme_core xhci_pci cryptd spi_intel_pci rtsx_pci xhci_pci_renesas spi_intel nvme_auth i8042 serio
 21666	Mar 14 00:55:32 void kernel: CR2: 000000000000000a
 21667	Mar 14 00:55:32 void kernel: ---[ end trace 0000000000000000 ]---
 21668	Mar 14 00:55:32 void kernel: RIP: 0010:refill_obj_stock+0x4f/0x180
 21669	Mar 14 00:55:32 void kernel: Code: c7 40 08 03 00 65 4c 03 3d 7e 61 e3 73 49 8b 47 10 48 39 f8 0f 84 9c 00 00 00 4c 89 ff e8 59 f2 ff ff 49 89 c6 e8 61 ab d8 ff <48> 8b 45 00 a8 03 0f 85 c9 00 00 00 65 48 ff 00 e8 5c e3 d8 ff 49
 21670	Mar 14 00:55:32 void kernel: RSP: 0018:ffffb9de02e3f940 EFLAGS: 00010002
 21671	Mar 14 00:55:32 void kernel: RAX: 0000000000000002 RBX: 00000000000002dd RCX: ffff981a55c21460
 21672	Mar 14 00:55:32 void kernel: RDX: ffff981a6cb09800 RSI: 00000000000002dd RDI: ffff98296f5b0840
 21673	Mar 14 00:55:32 void kernel: RBP: 000000000000000a R08: ffff981a6d65ac30 R09: 0000000000000000
 21674	Mar 14 00:55:32 void kernel: R10: ffff981a55c21460 R11: 0000000000000000 R12: 0000000000000206
 21675	Mar 14 00:55:32 void kernel: R13: 00000000000231b4 R14: ffff981a84a1c880 R15: ffff98296f5b0840
 21676	Mar 14 00:55:32 void kernel: FS:  0000000000000000(0000) GS:ffff98296f580000(0000) knlGS:0000000000000000
 21677	Mar 14 00:55:32 void kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
 21678	Mar 14 00:55:32 void kernel: CR2: 000000000000000a CR3: 0000000644420006 CR4: 0000000000f70ef0
 21679	Mar 14 00:55:32 void kernel: PKRU: 55555554
 21680	Mar 14 00:55:32 void kernel: note: QXcbEventQueue[1154] exited with irqs disabled
 21681	Mar 14 00:55:32 void kernel: note: QXcbEventQueue[1154] exited with preempt_count 4
 21682	Mar 14 00:55:32 void kernel: Fixing recursive fault but reboot is needed!
 21683	Mar 14 00:55:32 void kernel: BUG: scheduling while atomic: QXcbEventQueue/1154/0x00000000
 21684	Mar 14 00:55:32 void kernel: Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg snd_ctl_led snd_soc_skl_hda_dsp snd_soc_hdac_hdmi snd_soc_intel_hda_dsp_common snd_sof_probes snd_hda_codec_realtek snd_hda_codec_generic snd_soc_dmic qrtr bnep uinput nvidia_uvm(POE) snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof nvidia_drm(POE) snd_sof_utils intel_tcc_cooling snd_soc_hdac_hda snd_hda_ext_core btusb x86_pkg_temp_thermal btrtl intel_powerclamp snd_soc_acpi_intel_match uvcvideo snd_soc_acpi btintel iwlmvm videobuf2_vmalloc soundwire_generic_allocation btbcm coretemp uvc soundwire_bus btmtk videobuf2_memops nvidia_modeset(POE) snd_soc_core mac80211 videobuf2_v4l2 bluetooth snd_compress kvm_intel videodev snd_hda_codec_hdmi ac97_bus snd_pcm_dmaengine libarc4 videobuf2_common vfat ptp mc fat joydev ecdh_generic snd_hda_intel mousedev i915 snd_intel_dspcfg pps_core kvm snd_intel_sdw_acpi snd_hda_codec snd_hda_core
 21685	Mar 14 00:55:32 void kernel:  irqbypass snd_hwdep drm_buddy iwlwifi hid_multitouch thinkpad_acpi i2c_algo_bit processor_thermal_device_pci_legacy iTCO_wdt snd_pcm processor_thermal_device ttm intel_pmc_bxt nvidia(POE) ledtrig_audio rapl processor_thermal_wt_hint snd_timer mei_hdcp mei_pxp ee1004 drm_display_helper processor_thermal_rfim iTCO_vendor_support intel_cstate platform_profile think_lmi intel_rapl_msr firmware_attributes_class wmi_bmof cfg80211 spi_nor cec processor_thermal_rapl intel_lpss_pci mei_me snd i2c_i801 intel_uncore psmouse mtd pcspkr rfkill intel_rapl_common intel_gtt intel_lpss i2c_hid_acpi soundcore i2c_smbus mei idma64 processor_thermal_wt_req video i2c_hid processor_thermal_power_floor ucsi_acpi processor_thermal_mbox int3403_thermal typec_ucsi int340x_thermal_zone thunderbolt typec int3400_thermal intel_soc_dts_iosf roles acpi_thermal_rel intel_pmc_core wmi acpi_pad pinctrl_tigerlake acpi_tad mac_hid vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) i2c_dev fuse crypto_user loop nfnetlink ip_tables x_tables ext4
 21686	Mar 14 00:55:32 void kernel:  crc32c_generic crc16 mbcache jbd2 hid_generic usbhid dm_crypt cbc encrypted_keys trusted asn1_encoder tee dm_mod crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic gf128mul rtsx_pci_sdmmc ghash_clmulni_intel sha512_ssse3 mmc_core sha256_ssse3 serio_raw sha1_ssse3 nvme atkbd aesni_intel libps2 vivaldi_fmap crypto_simd nvme_core xhci_pci cryptd spi_intel_pci rtsx_pci xhci_pci_renesas spi_intel nvme_auth i8042 serio
 21687	Mar 14 00:55:32 void kernel: CPU: 6 PID: 1154 Comm: QXcbEventQueue Tainted: P      D    OE      6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
 21688	Mar 14 00:55:32 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
 21689	Mar 14 00:55:32 void kernel: Call Trace:
 21690	Mar 14 00:55:32 void kernel:  <TASK>
 21691	Mar 14 00:55:32 void kernel:  dump_stack_lvl+0x47/0x60
 21692	Mar 14 00:55:32 void kernel:  __schedule_bug+0x56/0x70
 21693	Mar 14 00:55:32 void kernel:  __schedule+0x103e/0x1410
 21694	Mar 14 00:55:32 void kernel:  ? __wake_up_klogd.part.0+0x3c/0x60
 21695	Mar 14 00:55:32 void kernel:  ? vprintk_emit+0x175/0x2b0
 21696	Mar 14 00:55:32 void kernel:  ? _printk+0x64/0x80
 21697	Mar 14 00:55:32 void kernel:  do_task_dead+0x43/0x50
 21698	Mar 14 00:55:32 void kernel:  make_task_dead+0x151/0x170
 21699	Mar 14 00:55:32 void kernel:  rewind_stack_and_make_dead+0x17/0x20
 21700	Mar 14 00:55:32 void kernel: RIP: 0033:0x7a851c7190bf
 21701	Mar 14 00:55:32 void kernel: Code: Unable to access opcode bytes at 0x7a851c719095.
 21702	Mar 14 00:55:32 void kernel: RSP: 002b:00007a8513dffbd0 EFLAGS: 00000293 ORIG_RAX: 0000000000000007
 21703	Mar 14 00:55:32 void kernel: RAX: fffffffffffffdfc RBX: 00005e7f2adaf320 RCX: 00007a851c7190bf
 21704	Mar 14 00:55:32 void kernel: RDX: 00000000ffffffff RSI: 0000000000000001 RDI: 00007a8513dffc08
 21705	Mar 14 00:55:32 void kernel: RBP: 00005e7f2adaf320 R08: 0000000000000000 R09: 0000000000000001
 21706	Mar 14 00:55:32 void kernel: R10: 00007a850c009b20 R11: 0000000000000293 R12: 0000000000000000
 21707	Mar 14 00:55:32 void kernel: R13: 0000000000000000 R14: 00005e7f2adaf338 R15: 00007a8513dffc08
 21708	Mar 14 00:55:32 void kernel:  </TASK>
 21709	Mar 14 00:55:32 void kernel: ------------[ cut here ]------------
 21710	Mar 14 00:55:32 void kernel: Voluntary context switch within RCU read-side critical section!
 21711	Mar 14 00:55:32 void kernel: WARNING: CPU: 6 PID: 1154 at kernel/rcu/tree_plugin.h:320 rcu_note_context_switch+0x591/0x680
 21712	Mar 14 00:55:32 void kernel: Modules linked in: rfcomm ccm cmac algif_hash algif_skcipher af_alg snd_ctl_led snd_soc_skl_hda_dsp snd_soc_hdac_hdmi snd_soc_intel_hda_dsp_common snd_sof_probes snd_hda_codec_realtek snd_hda_codec_generic snd_soc_dmic qrtr bnep uinput nvidia_uvm(POE) snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof nvidia_drm(POE) snd_sof_utils intel_tcc_cooling snd_soc_hdac_hda snd_hda_ext_core btusb x86_pkg_temp_thermal btrtl intel_powerclamp snd_soc_acpi_intel_match uvcvideo snd_soc_acpi btintel iwlmvm videobuf2_vmalloc soundwire_generic_allocation btbcm coretemp uvc soundwire_bus btmtk videobuf2_memops nvidia_modeset(POE) snd_soc_core mac80211 videobuf2_v4l2 bluetooth snd_compress kvm_intel videodev snd_hda_codec_hdmi ac97_bus snd_pcm_dmaengine libarc4 videobuf2_common vfat ptp mc fat joydev ecdh_generic snd_hda_intel mousedev i915 snd_intel_dspcfg pps_core kvm snd_intel_sdw_acpi snd_hda_codec snd_hda_core
 21713	Mar 14 00:55:32 void kernel:  irqbypass snd_hwdep drm_buddy iwlwifi hid_multitouch thinkpad_acpi i2c_algo_bit processor_thermal_device_pci_legacy iTCO_wdt snd_pcm processor_thermal_device ttm intel_pmc_bxt nvidia(POE) ledtrig_audio rapl processor_thermal_wt_hint snd_timer mei_hdcp mei_pxp ee1004 drm_display_helper processor_thermal_rfim iTCO_vendor_support intel_cstate platform_profile think_lmi intel_rapl_msr firmware_attributes_class wmi_bmof cfg80211 spi_nor cec processor_thermal_rapl intel_lpss_pci mei_me snd i2c_i801 intel_uncore psmouse mtd pcspkr rfkill intel_rapl_common intel_gtt intel_lpss i2c_hid_acpi soundcore i2c_smbus mei idma64 processor_thermal_wt_req video i2c_hid processor_thermal_power_floor ucsi_acpi processor_thermal_mbox int3403_thermal typec_ucsi int340x_thermal_zone thunderbolt typec int3400_thermal intel_soc_dts_iosf roles acpi_thermal_rel intel_pmc_core wmi acpi_pad pinctrl_tigerlake acpi_tad mac_hid vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) i2c_dev fuse crypto_user loop nfnetlink ip_tables x_tables ext4
 21714	Mar 14 00:55:32 void kernel:  crc32c_generic crc16 mbcache jbd2 hid_generic usbhid dm_crypt cbc encrypted_keys trusted asn1_encoder tee dm_mod crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic gf128mul rtsx_pci_sdmmc ghash_clmulni_intel sha512_ssse3 mmc_core sha256_ssse3 serio_raw sha1_ssse3 nvme atkbd aesni_intel libps2 vivaldi_fmap crypto_simd nvme_core xhci_pci cryptd spi_intel_pci rtsx_pci xhci_pci_renesas spi_intel nvme_auth i8042 serio
 21715	Mar 14 00:55:32 void kernel: CPU: 6 PID: 1154 Comm: QXcbEventQueue Tainted: P      D W  OE      6.7.7-1-MANJARO #1 273ab81b500d40daf476e41bc3d0ff78dd8ae875
 21716	Mar 14 00:55:32 void kernel: Hardware name: LENOVO 20Y50016US/20Y50016US, BIOS N40ET37W (1.19 ) 08/26/2022
 21717	Mar 14 00:55:32 void kernel: RIP: 0010:rcu_note_context_switch+0x591/0x680
 21718	Mar 14 00:55:32 void kernel: Code: ff 45 85 ed 0f 84 14 fc ff ff 4d 89 bc 24 a0 00 00 00 e9 07 fc ff ff 48 c7 c7 80 60 44 8d c6 05 48 54 e5 01 01 e8 af ea f3 ff <0f> 0b e9 c6 fa ff ff 48 89 fe 4c 89 ff e8 cd 17 4f 00 49 83 bc 24
 21719	Mar 14 00:55:32 void kernel: RSP: 0018:ffffb9de02e3fe30 EFLAGS: 00010082
 21720	Mar 14 00:55:32 void kernel: RAX: 0000000000000000 RBX: ffff98296f5b5100 RCX: 0000000000000027
 21721	Mar 14 00:55:32 void kernel: RDX: ffff98296f5a16c8 RSI: 0000000000000001 RDI: ffff98296f5a16c0
 21722	Mar 14 00:55:32 void kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffb9de02e3fcb8
 21723	Mar 14 00:55:32 void kernel: R10: 0000000000000003 R11: ffffffff8dcca788 R12: ffff98296f5b4200
 21724	Mar 14 00:55:32 void kernel: R13: ffff981a6cb09800 R14: 0000000000000000 R15: 0000000000000000
 21725	Mar 14 00:55:32 void kernel: FS:  0000000000000000(0000) GS:ffff98296f580000(0000) knlGS:0000000000000000
 21726	Mar 14 00:55:32 void kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
 21727	Mar 14 00:55:32 void kernel: CR2: 000000000000000a CR3: 0000000644420006 CR4: 0000000000f70ef0
 21728	Mar 14 00:55:32 void kernel: PKRU: 55555554
 21729	Mar 14 00:55:32 void kernel: Call Trace:
 21730	Mar 14 00:55:32 void kernel:  <TASK>
 21731	Mar 14 00:55:32 void kernel:  ? rcu_note_context_switch+0x591/0x680
 21732	Mar 14 00:55:32 void kernel:  ? __warn+0x81/0x130
 21733	Mar 14 00:55:32 void kernel:  ? rcu_note_context_switch+0x591/0x680
 21734	Mar 14 00:55:32 void kernel:  ? report_bug+0x171/0x1a0
 21735	Mar 14 00:55:32 void kernel:  ? console_unlock+0x78/0x120
 21736	Mar 14 00:55:32 void kernel:  ? handle_bug+0x3c/0x80
 21737	Mar 14 00:55:32 void kernel:  ? exc_invalid_op+0x17/0x70
 21738	Mar 14 00:55:32 void kernel:  ? asm_exc_invalid_op+0x1a/0x20
 21739	Mar 14 00:55:32 void kernel:  ? rcu_note_context_switch+0x591/0x680
 21740	Mar 14 00:55:32 void kernel:  __schedule+0xc0/0x1410
 21741	Mar 14 00:55:32 void kernel:  ? __wake_up_klogd.part.0+0x3c/0x60
 21742	Mar 14 00:55:32 void kernel:  ? vprintk_emit+0x175/0x2b0
 21743	Mar 14 00:55:32 void kernel:  ? _printk+0x64/0x80
 21744	Mar 14 00:55:32 void kernel:  do_task_dead+0x43/0x50
 21745	Mar 14 00:55:32 void kernel:  make_task_dead+0x151/0x170
 21746	Mar 14 00:55:32 void kernel:  rewind_stack_and_make_dead+0x17/0x20
 21747	Mar 14 00:55:32 void kernel: RIP: 0033:0x7a851c7190bf
 21748	Mar 14 00:55:32 void kernel: Code: Unable to access opcode bytes at 0x7a851c719095.
 21749	Mar 14 00:55:32 void kernel: RSP: 002b:00007a8513dffbd0 EFLAGS: 00000293 ORIG_RAX: 0000000000000007
 21750	Mar 14 00:55:32 void kernel: RAX: fffffffffffffdfc RBX: 00005e7f2adaf320 RCX: 00007a851c7190bf
 21751	Mar 14 00:55:32 void kernel: RDX: 00000000ffffffff RSI: 0000000000000001 RDI: 00007a8513dffc08
 21752	Mar 14 00:55:32 void kernel: RBP: 00005e7f2adaf320 R08: 0000000000000000 R09: 0000000000000001
 21753	Mar 14 00:55:32 void kernel: R10: 00007a850c009b20 R11: 0000000000000293 R12: 0000000000000000
 21754	Mar 14 00:55:32 void kernel: R13: 0000000000000000 R14: 00005e7f2adaf338 R15: 00007a8513dffc08
 21755	Mar 14 00:55:32 void kernel:  </TASK>
 21756	Mar 14 00:55:32 void kernel: ---[ end trace 0000000000000000 ]---
 21757	Mar 14 00:55:32 void systemd[1]: Removed slice Slice /system/modprobe.
 21758	-- Boot 4012cc38dced46e686e6664f4ea34e4c --
 21759	Mar 14 17:36:08 void kernel: Linux version 6.7.7-1-MANJARO (builduser@fv-az713-526) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Fri Mar  1 18:26:06 UTC 2024
 21760	Mar 14 17:36:08 void kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64 root=UUID=4aa51505-ebba-4b87-bbf2-c48b1e1a82ba rw quiet cryptdevice=UUID=8c292157-5d23-4997-8751-334a7a1311ca:luks-8c292157-5d23-4997-8751-334a7a1311ca root=/dev/mapper/luks-8c292157-5d23-4997-8751-334a7a1311ca splash resume=/dev/mapper/luks-e7a8430b-004a-41f7-abd1-4c66ab255105 udev.log_priority=3
 21761	Mar 14 17:36:08 void kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Are you able to reproduce the issue at NVIDIA?
Same symptoms, same 550 driver, likewise the error appears in both X11 and Wayland, likewise the kernel panic stack starts with the __die function, likewise happens most often when shutting down/rebooting the laptop
I’m using EndeavourOS now, tried to change kernel: the problem occurs on both mainline (6.7.9) and LTS (6.6.21). Tried to switch to CachyOS - same problem. I haven’t changed to rollback to the previous version of NVIDIA drivers yet, but by subjective feelings, the problems started with using beta driver (with subsequent switch to 550).
мар 15 18:33:09 REDMI systemd[1467]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
мар 15 18:33:09 REDMI systemd[1467]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
мар 15 18:33:10 REDMI systemd[1467]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
мар 15 18:33:10 REDMI systemd[1467]: Started dbus-:1.2-org.kde.Shutdown@0.service.
мар 15 18:33:10 REDMI systemd[1467]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=exited, status=1/FAILURE
мар 15 18:33:10 REDMI systemd[1467]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
мар 15 18:33:10 REDMI kded6[1546]: Service  ":1.41" unregistered
мар 15 18:33:10 REDMI polkitd[805]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.48, object path /org/kde/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8) (disconnected from bus)
мар 15 18:33:10 REDMI kernel: BUG: kernel NULL pointer dereference, address: 000000000000001a
мар 15 18:33:10 REDMI kernel: #PF: supervisor read access in kernel mode
мар 15 18:33:10 REDMI kernel: #PF: error_code(0x0000) - not-present page
мар 15 18:33:10 REDMI kernel: PGD 0 P4D 0
мар 15 18:33:10 REDMI kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
мар 15 18:33:10 REDMI kernel: CPU: 1 PID: 1467 Comm: systemd Tainted: P           OE      6.6.21-1-lts #1 0c0a74bb77159d2e130f727f514cce3b101bcba5
мар 15 18:33:10 REDMI kernel: Hardware name: TIMI Redmi G 2022/TM2135, BIOS RMGAD6T0P0F0F 09/30/2022
мар 15 18:33:10 REDMI kernel: RIP: 0010:rb_first+0xf/0x30
мар 15 18:33:10 REDMI kernel: Code: 10 c3 cc cc cc cc 0f 1f 44 00 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 48 8b 07 48 85 c0 74 14 48 89 c2 <48> 8b 40 10 48 85 c0 75 f4 48 89 d0 c3 cc cc cc cc 31 d2 eb f4 66
мар 15 18:33:10 REDMI kernel: RSP: 0018:ffffc90005e6bc18 EFLAGS: 00010206
мар 15 18:33:10 REDMI kernel: RAX: 000000000000000a RBX: ffff8881098fa300 RCX: 0000000000671801
мар 15 18:33:10 REDMI kernel: RDX: 000000000000000a RSI: 0000000000000000 RDI: ffff888101025498
мар 15 18:33:10 REDMI kernel: RBP: ffff88818bc5f780 R08: 0000000000000000 R09: 0000000000039060
мар 15 18:33:10 REDMI kernel: R10: ffff8881098fa298 R11: ffffc90005e6bc18 R12: 0000000000000000
мар 15 18:33:10 REDMI kernel: R13: ffff888101025498 R14: ffffffffbe8df278 R15: ffff88810a485000
мар 15 18:33:10 REDMI kernel: FS:  000077374a962880(0000) GS:ffff88904b840000(0000) knlGS:0000000000000000
мар 15 18:33:10 REDMI kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
мар 15 18:33:10 REDMI kernel: CR2: 000000000000001a CR3: 0000000102fbc000 CR4: 0000000000f50ee0
мар 15 18:33:10 REDMI kernel: PKRU: 55555554
мар 15 18:33:10 REDMI kernel: Call Trace:
мар 15 18:33:10 REDMI kernel:  <TASK>
мар 15 18:33:10 REDMI kernel:  ? __die+0x23/0x70
мар 15 18:33:10 REDMI kernel:  ? page_fault_oops+0x171/0x4e0
мар 15 18:33:10 REDMI kernel:  ? step_into+0x433/0x770
мар 15 18:33:10 REDMI kernel:  ? exc_page_fault+0x7f/0x180
мар 15 18:33:10 REDMI kernel:  ? asm_exc_page_fault+0x26/0x30
мар 15 18:33:10 REDMI kernel:  ? rb_first+0xf/0x30
мар 15 18:33:10 REDMI kernel:  simple_xattrs_free+0x29/0x90
мар 15 18:33:10 REDMI kernel:  kernfs_put.part.0+0x60/0x150
мар 15 18:33:10 REDMI kernel:  kernfs_remove_by_name_ns+0x81/0xd0
мар 15 18:33:10 REDMI kernel:  cgroup_addrm_files+0x2c6/0x350
мар 15 18:33:10 REDMI kernel:  css_clear_dir+0x4b/0xc0
мар 15 18:33:10 REDMI kernel:  cgroup_destroy_locked+0xcd/0x1b0
мар 15 18:33:10 REDMI kernel:  cgroup_rmdir+0x2b/0xd0
мар 15 18:33:10 REDMI kernel:  kernfs_iop_rmdir+0x50/0x80
мар 15 18:33:10 REDMI kernel:  vfs_rmdir+0x97/0x200
мар 15 18:33:10 REDMI kernel:  do_rmdir+0x175/0x1b0
мар 15 18:33:10 REDMI kernel:  __x64_sys_rmdir+0x42/0x70
мар 15 18:33:10 REDMI kernel:  do_syscall_64+0x5d/0x90
мар 15 18:33:10 REDMI kernel:  ? syscall_exit_to_user_mode+0x22/0x40
мар 15 18:33:10 REDMI kernel:  ? do_syscall_64+0x6c/0x90
мар 15 18:33:10 REDMI kernel:  ? ksys_read+0x6f/0xf0
мар 15 18:33:10 REDMI kernel:  entry_SYSCALL_64_after_hwframe+0x6e/0xd8
мар 15 18:33:10 REDMI kernel: RIP: 0033:0x77374b31977b
мар 15 18:33:10 REDMI kernel: Code: f0 ff ff 73 01 c3 48 8b 0d b2 c5 0d 00 f7 d8 64 89 01 48 83 c8 ff c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa b8 54 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 05 c3 0f 1f 40 00 48 8b 15 81 c5 0d 00 f7 d8
мар 15 18:33:10 REDMI kernel: RSP: 002b:00007ffe4d8c4938 EFLAGS: 00000246 ORIG_RAX: 0000000000000054
мар 15 18:33:10 REDMI kernel: RAX: ffffffffffffffda RBX: 0000651404e0d600 RCX: 000077374b31977b
мар 15 18:33:10 REDMI kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000651404e0ceb0
мар 15 18:33:10 REDMI kernel: RBP: 00007ffe4d8c4990 R08: 000077374aeaa90a R09: 0000000000000007
мар 15 18:33:10 REDMI kernel: R10: 0000651404de27b0 R11: 0000000000000246 R12: 0000000000000001
мар 15 18:33:10 REDMI kernel: R13: 0000000000000000 R14: 0000651404e0ceb0 R15: 0000000000000000
мар 15 18:33:10 REDMI kernel:  </TASK>
мар 15 18:33:10 REDMI kernel: Modules linked in: algif_hash af_alg snd_seq_dummy snd_hrtimer snd_seq nf_conntrack_netlink xt_addrtype br_netfilter cmac ccm xt_CHECKSUM xt_MASQUERADE xt_conntrack ipt_REJECT xt_tcpudp nft_compat nf_nat_tftp nf_conntrack_tftp bridge stp llc overlay nft>
мар 15 18:33:10 REDMI kernel:  snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match x86_pkg_temp_thermal intel_powerclamp snd_soc_acpi soundwire_generic_allocation coretemp soundwire_bus iwlmvm snd_soc_core kvm_intel snd_compress joydev cdc_mbim mousedev cdc_wdm snd_hda_codec_>
мар 15 18:33:10 REDMI kernel:  igen6_edac intel_vsec intel_rapl_common idma64 int3403_thermal int3400_thermal int340x_thermal_zone acpi_pad acpi_thermal_rel acpi_tad mac_hid fuse loop dm_mod nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 pkcs8_key_parser usbhid >
мар 15 18:33:10 REDMI kernel: ---[ end trace 0000000000000000 ]---
мар 15 18:33:10 REDMI kernel: note: systemd[1467] exited with irqs disabled
