12_camera_v4l2_cuda problem with mPCIe V4L2 device
I have a 1280x720 60fps monochrome HD-SDI camera that I am using together with a nanoGrabber HD-SDI frame grabber which creates a V4L2 (/dev/video0) interface for receiving the frames. The frame grabber is attached to an Elroy Carrier through a mPCIe port. The Jetson system in question is a TX2i.
I can successfully use this system together with Gstreamer or v4l2-ctl to capture and use the stream of raw frames. However, I am running into some problems regarding the time-tags received from Gstreamer being wrong and therefore considering migrating to the Jetson multimedia API in order to see if more low-level control over the data flow will solve my problem. I have downloaded and compiled the R32.2.0 version. With the camera attached and turned on, I can not get the 12th sample code to execute successfully. Here are some commands I have used and their results that I think may have diagnostic purposes. Any help would be appreciated!
This is the error message when trying to run the sample (I have also tried all of the different -f options, same result):
gftb@tegra-ubuntu:~/Desktop/Tegra_Multimedia_API_R32.2.0_aarch64/tegra_multimedia_api/samples/12_camera_v4l2_cuda$ ./camera_v4l2_cuda -d /dev/video0 -s 1280x720
ERROR: camera_initialize(): (line:272) Failed to set camera output format: Invalid argument (22)
ERROR: init_components(): (line:335) Failed to initialize camera device
ERROR: main(): (line:716) Failed to initialize v4l2 components
nvbuf_utils: dmabuf_fd 0 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
App run failed
This demonstrates the caps that Gstreamer uses while accessing the data stream:
gftb@tegra-ubuntu:~$ gst-launch-1.0 v4l2src ! xvimagesink -v
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, framerate=(fraction)120/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, framerate=(fraction)120/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:14.638381536
Setting pipeline to READY …
Caught SIGSEGV
^C
This shows some properties of the frame grabber and its driver:
gftb@tegra-ubuntu:~$ sudo lspci -xxxvvv
00:03.0 PCI bridge: NVIDIA Corporation Device 10e6 (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 381
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 40200000-407fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #2, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM L0s Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=30us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: pcieport
00: de 10 e6 10 07 01 10 00 a1 00 04 06 00 00 01 00
10: 00 00 00 00 00 00 00 00 00 01 01 00 11 11 00 00
20: 20 40 70 40 f1 ff 01 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 7d 01 00 00
40: 0d 48 00 00 de 10 00 00 01 50 03 f8 00 00 00 00
50: 05 60 82 00 00 00 00 00 00 00 00 00 00 00 00 00
60: 08 80 00 a8 00 00 e0 fe 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80: 10 00 42 01 20 80 00 00 1f 29 00 00 12 3c 31 02
90: 41 00 11 30 00 00 00 00 c0 01 48 01 08 00 00 00
a0: 00 00 00 00 13 08 00 00 00 04 00 00 00 00 00 00
b0: 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01:00.0 Multimedia video controller: Device 0907:0100 (rev 01)
Subsystem: Device 0907:0001
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Region 0: Memory at 40400000 (32-bit, non-prefetchable) [size=4M]
Region 1: I/O ports at 1000 [size=256]
Region 4: I/O ports at 1100 [size=256]
Region 5: Memory at 40200000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 <8us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Kernel driver in use: ngrabber
00: 07 09 00 01 07 00 10 00 01 00 00 04 00 00 00 00
10: 00 00 40 40 01 10 00 00 00 00 00 00 00 00 00 00
20: 01 11 00 00 00 00 20 40 00 00 00 00 07 09 01 00
40: 01 50 c3 5b 00 00 00 00 00 00 00 00 00 00 00 00
50: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70: 10 00 02 00 01 87 00 00 10 20 00 00 11 3c 02 00
80: 41 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90: 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
This shows that there are no directly controllable registers of the frame grabber device:
gftb@tegra-ubuntu:~$ v4l2-ctl --list-ctrls
Please run $ v4l2-ctl --list-formats-ext and share the prints. It looks like the format is YUV420 which is not supported in 12_camera_v4l2_cuda by default.
The output is as follows:
gftb@tegra-ubuntu:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: ‘YU12’ (Planar YUV 4:2:0)
If it is not supported by default, is it possible to modify the code a bit to make it supported?
Please modify the sample:
  1. Add the format to nvcolor_fmt[]
  2. Hard code capture_dmabuf to false
Rebuild the sample and give it a try.
I have done the thing related to the capture_dmabuf.
However, the change I would need to make for nvcolor_fmt is not obvious, because there is already an entry related to YUV420. I’ve modified it to be like this, the part I have outlined in bold is what i have added:
static nv_color_fmt nvcolor_fmt =
// TODO add more pixel format mapping
{V4L2_PIX_FMT_UYVY, NvBufferColorFormat_UYVY},
{V4L2_PIX_FMT_VYUY, NvBufferColorFormat_VYUY},
{V4L2_PIX_FMT_YUYV, NvBufferColorFormat_YUYV},
{V4L2_PIX_FMT_YVYU, NvBufferColorFormat_YVYU},
{V4L2_PIX_FMT_GREY, NvBufferColorFormat_GRAY8},
{V4L2_PIX_FMT_YUV420M, NvBufferColorFormat_YUV420},
{V4L2_PIX_FMT_YUV420, NvBufferColorFormat_YUV420},
Of course, I’ve also modified some other parts of the code so that it now recognizes “-f YUV420” and the fact that it corresponds to V4L2_PIX_FMT_YUV420.
After these modifications, the error message changed to be like this, now a small black screen very briefly appears then disappears when I try executing the code:
gftb@tegra-ubuntu:~/Desktop/Tegra_Multimedia_API_R32.2.0_aarch64/tegra_multimedia_api/samples/12_camera_v4l2_cuda$ ./camera_v4l2_cuda -d /dev/video0 -s 1280x720 -f YUV420
[INFO] (NvEglRenderer.cpp:110) Setting Screen width 1280 height 720
ERROR: request_camera_buff_mmap(): (line:406) V4l2 buffer number is not as desired
ERROR: prepare_buffers(): (line:524) Failed to set up camera buff
ERROR: main(): (line:726) Failed to prepare v4l2 buffs
App run failed
The same error message happens regardless of if the camera is connected or not.
Please try the gstreamer command and see if camera preview is shown:
$ gst-launch-1.0 v4l2src ! video/x-raw, format=I420, width=1280, height=720 ! nvvidconv !  nvoverlaysink
To make sure the caps is correct in gstreamer command.
And please run $ cat /etc/nv_tegra_release to make sure you use r32.2. If you use later version, please install jetson_multimedia_api samples through SDKManager. If the version of system and samples is mismatched, it may hit segment fault or not work properly.
The given Gstreamer command runs correctly and displays the video stream received from the camera.
The given cat command displays this: R32 (release), REVISION: 2.3, GCID: 17644089, BOARD: t186ref, EABI: aarch64, DATE: Tue Nov 5 21:48:17 UTC 2019
So the versions are matched. The current error is
Please add prints in request_camera_buff_mmap() to debug further. Maybe the device does not support V4L2_MEMORY_MMAP, or V4L2_BUFFERS_NUM=4 is not enough.
The device supports both MMAP and DMABUF modes, as far as I know from Gstream.
I have tried playing around with different values of V4L2_BUFFERS_NUM, the default value is 4, only setting it to 2 allowed the program to run. However, I now notice two problems.
1- The video stream is completely green, despite the fact that it needs to be grayscale.
2- The program reports the received FPS to be 30 instead of the correct value of 60.
Edit: The 2nd problem has been solved by feeding the “-r 120” parameter, therefore only the 1st one remains.
This may be because the data in U/V planes are invalid, please call nvbuff_do_clearchroma() to clear the planes and see if the grayscale data shows up.
I have modified the code according to my use case, and can successfully retrieve the raw data from the V4L2 interface. However, I have another question I need to ask. As I have mentioned in my initial topic, the task I need to do with the frames is time-critical, and therefore I need the correct timestamps of each frame. I can just use clock_gettime() after polling for each frame, but I do not think this is the “correct/proper” way to handle this. I think the V4L2 device should be providing a timestamp that i should be able to retrieve together with the frames. However, I can not figure out how.
A possible solution is to get time in driver code and fill in timestamp to struct v4l2_buffer:
3.6. Buffers — The Linux Kernel documentation
So that you can get the kernel timestamp in userspace application.
