18.04 CUDA docker image is broken
Steps:
  1. docker run --rm -it nvidia/cudagl:10.1-devel-ubuntu18.04
  2. apt-get update
Result:
W: GPG error: Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A4B469963BF863CC
E: The repository ‘Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease’ is not signed.
Seems related to these topics:
similar issue in docker; I followed the key commands posted on the forum but still having the same issue
I have the following build followed by some additional RUN and COPY commands but the build fails
FROM nvidia/cuda:11.0-cudnn8-runtime-ubuntu18.04
RUN apt-get update && \
    apt-get upgrade -y && \
    apt-get install -y git lsb-core
RUN apt-key del 7fa2af80
RUN wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-keyring_1.0-1_all.deb
RUN dpkg -i cuda-keyring_1.0-1_all.deb
However the build still fails with a similar error as tho I have not rotated the key:
Sending build context to Docker daemon 43.94MB
Step 1/19 : FROM nvidia/cuda:11.0-cudnn8-runtime-ubuntu18.04
 ---> 848be2582b0a
Step 2/19 : RUN apt-get update &&     apt-get upgrade -y &&     apt-get install -y git lsb-core
 ---> Running in b42917c47f5a
Get:1 http://archive.ubuntu.com/ubuntu bionic InRelease [242 kB]
Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:3 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  InRelease [1575 B]
Get:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Ign:6 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  InRelease
Get:7 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Release [564 B]
Err:3 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A4B469963BF863CC
Get:8 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Release.gpg [833 B]
Get:9 http://security.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [909 kB]
Get:10 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages [2733 kB]
Get:11 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [1496 kB]
Get:12 http://archive.ubuntu.com/ubuntu bionic/multiverse amd64 Packages [186 kB]
Get:13 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [21.1 kB]
Get:14 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages [1344 kB]
Get:15 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages [11.3 MB]
Get:16 http://archive.ubuntu.com/ubuntu bionic/restricted amd64 Packages [13.5 kB]
Get:17 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [942 kB]
Get:18 http://archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [29.8 kB]
Get:19 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [2272 kB]
Get:20 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [3167 kB]
Get:21 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Packages [73.8 kB]
Get:22 http://archive.ubuntu.com/ubuntu bionic-backports/main amd64 Packages [12.2 kB]
Get:23 http://archive.ubuntu.com/ubuntu bionic-backports/universe amd64 Packages [12.9 kB]
Reading package lists...
W: GPG error: https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A4B469963BF863CC
E: The repository 'https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  InRelease' is not signed.
Can someone advise what I’m doing wrong?
**** UPDATE: mat.g was correct
They are rotating keys – see here for steps to resolve:
**** UPDATE2:
Welp ok turns out even adding the manual key fails so yes there’s definitely something wrong here.
RUN apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/$distro/$arch/3bf863cc.pub
root@033ada28c0a3:/# apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/3bf863cc.pub
Executing: /tmp/apt-key-gpghome.2G1j3RpS1J/gpg.1.sh --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/3bf863cc.pub
gpg: requesting key from 'https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/3bf863cc.pub'
gpg: key A4B469963BF863CC: public key "cudatools <cudatools@nvidia.com>" imported
gpg: Total number processed: 1
gpg:               imported: 1
root@033ada28c0a3:/# apt-get update
Get:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  InRelease [1575 B]
Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:4 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  InRelease
Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Get:6 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Release [564 B]
Hit:7 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:9 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  Packages [709 kB]
Err:9 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  Packages
  File has unexpected size (952932 != 708701). Mirror sync in progress? [IP: ]
  Hashes of expected file:
   - Filesize:708701 [weak]
   - SHA256:3bb17f2151c764a6f868b36f175c82ba8deb79cd79160375ccdaacebf12a26c7
   - SHA1:c40cd8e703ef81fad35da4cec0fed58bf3b6c83a [weak]
   - MD5Sum:00af6704ab07a4620d61569ec0053961 [weak]
  Release file created at: Mon, 25 Apr 2022 23:02:48 +0000
Ign:8 https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Release.gpg
Reading package lists... Done
W: GPG error: https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Release: The following
signatures couldn't be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
E: The repository 'https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64  Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Same here,
I’m running the tensorflow/tensorflow:2.7.0-gpu docker file and added this at the beginning :
RUN rm /etc/apt/sources.list.d/cuda.list
RUN rm /etc/apt/sources.list.d/nvidia-ml.list
RUN apt-get install -y --no-install-recommends wget
RUN wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/cuda-keyring_1.0-1_all.deb
RUN wget https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu2004/x86_64/cuda-keyring_1.0-1_all.deb
RUN apt-get update
Then I get this error on the update :
#12 3.762 E: Failed to fetch https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/Packages.gz File has unexpected size (631054 != 481481). Mirror sync in progress? [IP: 152.199.20.126 443]
#12 3.762 Hashes of expected file:
#12 3.762 - Filesize:481481 [weak]
#12 3.762 - SHA256:8556d67c6d380c957f05057f448d994584a135d7ed75e5ae6bb25c3fc1070b0b
#12 3.762 - SHA1:c5ea9556407a3b5daec4aac530cd038e9b490441 [weak]
#12 3.762 - MD5Sum:a5513131dbd2d4e50f185422ebb43ac9 [weak]
#12 3.762 Release file created at: Mon, 25 Apr 2022 23:27:19 +0000
#12 3.762 E: Some index files failed to download. They have been ignored, or old ones used instead.
Here is the content of the sources.list cuda file, if this can somehow help :
#12 [ 9/15] RUN cat /etc/apt/sources.list.d/cuda-ubuntu2004-x86_64.list
#12 sha256:2ffcda5a63c628ecf592fffe73cf2a6b382e4a7e1def1d0435adc54f47d84490
#12 0.443 deb [signed-by=/usr/share/keyrings/cuda-archive-keyring.gpg] Index of /compute/cuda/repos/ubuntu2004/x86_64 /
#12 DONE 0.5s
UPDATE : The mirror sync seems finished, I do not have the error anymore
UPDATE 2 : I don’t know what I’m doing, maybe this doesn’t work after all
UPDATE 3 : I think that if the nvidia-ml.list isn’t removed it works anyway.
If you blow away the .lists, then I don’t think you need to install the key ring deb because you’re not even going to be using NVIDIA’s repositories anymore.
So you could just do…
…and that will “fix” the issue.
When running RUN dpkg -i cuda-keyring_1.0-1_all.deb it adds a new list, having it and cuda.list created some conflicts. By removing it then adding the new one everything seems to be working.
I must say I’m not an expert, but it looks like it makes sense, no?
The recommended approach doesn’t work (it creates duplicated apt source). The alternate approach does. However, for a new cuda image, we also need to do the same for machine-learning repository. So this would work for a 18.04 cuda 10.2 image
Can’t copy paste the text because the forum doesn’t allow me to post reply with nvidia host (sigh…)
I’m not an expert on this either. Is it asking too much for NVIDIA to push updated images that work with their current repository keys?
It looks like a slightly modified version of francis.toupins dockerfile steps is working for me. The 18.04 image doesn’t have wget and apt isn’t aware of it without running apt-get update which doesn’t work unless you delete the lists.
RUN apt-get update && apt-get install -y --no-install-recommends wget
Our Dockerfile doesn’t update any NVIDIA packages, and I don’t know if this is the “correct” solution.
I also can confirm that the above solution from dennis.pan which fetches the updated public keys seems to work.
RUN apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/3bf863cc.pub
RUN apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64/7fa2af80.pub
Yeah that looks legit. By removing the key and the lists before calling the update it seems to work. I’m still not sure if nvidia-ml.list needs to be removed though
another approach:
RUN apt-key del 7fa2af80 \
    && apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64/3bf863cc.pub \
    && apt-get update \
    && apt-get install -y libsm6 libgl1-mesa-glx libxext6 libfontconfig1 libxrender1 \
    && rm -rf /var/lib/apt/lists/*
Adjust the second to last line to reflect your Dockerfile package installations
@2024a is there any plan to update the docker images or do all of your customers have to fix it in their own Dockerfiles?
Found that
nvidia/cuda:11.2.1-base-ubuntu20.04 is updated a few hours ago
I am facing the same issue, but with cuda:10.1-*-ubuntu18.04 images.
Will those be updated/fixed?
I just used the two public keys together, and this seems to resolve my issue
apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64/7fa2af80.pub && \
apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64/3bf863cc.pub && \
Hi, I just ignore the APT-KEY DEL and it worked.
FROM nvidia/cuda:10.2-cudnn8-runtime-ubuntu18.04
# RUN apt-key del 7fa2af80
RUN apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64/3bf863cc.pub
Thanks. This one works for me.
The solution from @dennis.pan also worked for me.
