/tmp/selfgz6986/NVIDIA-Linux-x86_64-384.98-custom/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz6986/NVIDIA-Linux-x86_64-384.98-custom/kernel/nvidia/nvlink_linux.o
LD [M] /tmp/selfgz6986/NVIDIA-Linux-x86_64-384.98-custom/kernel/nvidia.o
make[3]: warning: Clock skew detected. Your build may be incomplete.
Building modules, stage 2.
make[3]: Warning: File ‘include/config/auto.conf’ has modification time 27078 s in the future
MODPOST 1 modules
FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘sme_active’
make[3]: *** [/usr/src/linux-4.15.0-rc1-1.1/scripts/Makefile.modpost:95: __modpost] Error 1
make[3]: Target ‘_modpost’ not remade because of errors.
make[2]: *** [/usr/src/linux-4.15.0-rc1-1.1/Makefile:1511: modules] Error 2
make[2]: Leaving directory ‘/usr/src/linux-4.15.0-rc1-1.1-obj/x86_64/default’
make[1]: *** [Makefile:146: sub-make] Error 2
make[1]: Target ‘modules’ not remade because of errors.
make[1]: Leaving directory ‘/usr/src/linux-4.15.0-rc1-1.1’
make: *** [Makefile:81: modules] Error 2
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed.
I’ve noticed that 4.15-rc1 with 340.104/ION2/Atom D525 will reboot the kernel when resuming from suspend, and then boot successfully.
4.15-rc1 and a Skylake i915/i5 NUC is also unable to resume from suspend - I haven’t investigated but it goes into a continuous reboot loop so the kernel is most likely panicking.
It might be s a general issue/bug with 4.15-rc1 and power management, one that will hopefully be fixed in 4.15-rc2 or a later rc.
4.14.2 on both 340.104/ION2/Atom and the i915/i5 Skylake NUC resumes from suspend without a problem.
Just mentioning it here as I don’t think this is a GPU driver-related suspend/resume issue.
