40 RPM Requested limit: 200 RPM (or the next available tier for individual developer use)
Hello NVIDIA Support Team,
I am writing to formally request a rate limit increase for my NVIDIA NIM API account.
Current limit: 40 RPM Requested limit: 200 RPM (or the next available tier for individual developer use)
Account email: omisrani09@proton.me
Project Overview: I am developing OpenClaw, an AI-powered coding assistant that orchestrates multi-agent workflows for automated coding tasks and file system operations. The system uses a multi-agent architecture where several agents run concurrently — each requiring independent API calls to NVIDIA NIM endpoints — to handle tasks such as code generation, debugging, refactoring, and file management in parallel.
Why I need higher limits: The current 40 RPM limit creates synchronization bottlenecks when multiple agents attempt to call the NIM API simultaneously. This significantly slows down the orchestration pipeline and limits the effectiveness of the multi-agent system during active development and testing.
Requested increase: A limit of 200 RPM would allow OpenClaw’s agents to operate concurrently without hitting rate limit errors, enabling meaningful testing of the full multi-agent workflow.
Thank you for considering this request. I am happy to provide any additional information if needed.
i think that you don’t understud that is free test plan …. it’s not fair use to request 200 rpm … if you planed to used it in concurent workflow you should think about purchase some cloud hardware like nvidia allready purpose or maybe stop conccurency
in fact current 40 rpm is allready enougth to test model and they don’t need to upgrade that because api is allready dying every day because too much people are on it, so if you need more power you have to take a look at Brev.dev Console that allready exist and will help you and nvidia
hope that you understud FREE TESTING is not made for hardcore usage
please take care about ToS and QoS from NIM API …
Hi there,
I can elevate this internally to the team, as many others have had similar requests, but we cannot approve rate-limit increases directly from the forum.
I know that’s not the answer you are looking for, but I will do my best to ensure forum posters are heard in the decision-making process.
Thanks,
Aharpster
