I am getting a error 404 when I attempt to download the latest Jetson SD card image from developer.nvidia.com. Is this a known issue?
Hi @lordiradin, sorry about that - we are working to resolve the issue asap.
This error occurs for BSP packages as well.
Thank you, yes there are issues with a number of the downloads at the moment - our apologies for the trouble.
Is there any ETA on the fix or potentially a working mirror?
Not currently, sorry - it’s working on being restored as we speak.
Has there been any update on this? I have a project that is dead in the water until I can get access to these images. I am willing to explore other options if there is some workaround or alternative method to getting a Jetson setup.
Maybe someone can put an image for Jetson Nano 2gb to google drive? Pls
Here’s a temporary mirror of the JetPack 4.6.1 SD card images for Jetson Nano 2GB/4GB:
https://nvidia.box.com/s/decfhbgilz1b90oypa49n80c5cexnoi6
hello dusty_nv,
Is it possible to have a mirror for these files too?
https://developer.download.nvidia.com/embedded/L4T/r32_Release_v5.1/r32_Release_v5.1/T186/Tegra186_Linux_R32.5.1_aarch64.tbz2
https://developer.nvidia.com/embedded/l4t/r32_release_v5.1/r32_release_v5.1/t186/tegra_linux_sample-root-filesystem_r32.5.1_aarch64.tbz2
https://developer.nvidia.com/embedded/l4t/r32_release_v5.1/r32_release_v5.1/sources/t186/public_sources.tbz2
Thank you a lot!
I’m sorry, those I do not personally have locally. Hope they will be back up soon - our apologies for the delay.
I understand. Thank you anyway :-)
Hi Dusty,
Do you happen to have the 32.7.1 bsp local?
Sorry, I do not
Thanks Dusty. I was able to download both of these. Appreciate the work around!
OK great - yea, the downloads should be back up now. I have taken down the temp mirror of the SD card images on box.com
