Hey all, after several failed NVIDIA driver install attempts and Debian 13 re-installs, I have a process that results in a fully functional RTX 5090 in Gnome Desktop with the latest version of the driver (as of this writing) 580.95.05.
IMPORTANT DEBIAN 13 NOTES:
- The 5090 is ONLY supported from driver versions above 560.X, and ONLY with the nvidia-open driver packages available from the NVIDIA Developer repository.
- Attempts at installing cuda-drivers from the NVIDIA Developer repo will fail.
- Attempts at installing NVIDIA drivers from the official Debian 13 repositories will fail.
- Attempts at installing NVIDIA drivers from the .run package will fail.
- As of this writing, the NVIDIA Developer repo only has a Debian 12 path, this still works for Debian 13.
The process that works for me:
- Install necessary dependencies:
sudo apt install linux-headers-$(uname -r) build-essential
- Download and install the NVIDIA CUDA keyring package:
wget https://developer.download.nvidia.com/compute/cuda/repos/debian12/x86_64/cuda-keyring_1.1-1_all.deb
sudo dpkg -i cuda-keyring_1.1-1_all.deb
- Update the package list:
sudo apt update
- Install the NVIDIA driver:
sudo apt install nvidia-open --install-suggests
- Reboot your system:
sudo reboot
- Verify the installation:
After rebooting, run:
nvidia-smi
You should see the ascii box displaying your GPU details:
Fri Oct 10 15:15:04 2025
| NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 5090 On | 00000000:01:00.0 Off | N/A |
| 0% 28C P8 24W / 600W | 18MiB / 32607MiB | 0% Default |
| | | N/A |
