a cublas problem
Hi , i have a little problem with a sgemm cublas .
I wold like to create a cycle like this :
real (fp_kind), dimension(:,:), allocatable ::      A, B, C
      real ::      time_start,time_end
      real (fp_kind)::      alpha=1._fp_kind,beta=1._fp_kind, c_right
      integer::  i,j,m1,m2
      integer :: stat,stat2,stat3
      integer:: size_of_real=16
      integer*8:: devPtrA, devPtrB, devPtrC
c CUBLAS
      external cublas_init, cublas_set_matrix, cublas_get_matrix
      external cublas_shutdown, cublas_alloc
      integer cublas_alloc
C CUBLAS
      call cublas_init()
do m1=128,2560,32
       print *,m1
       allocate(A(m1,m1))
       allocate(B(m1,m1))
       allocate(C(m1,m1))
stat=cublas_Alloc(m1*m1,size_of_real, devPtrA)
       stat2=cublas_Alloc(m1*m1,size_of_real, devPtrB)
       stat3=cublas_Alloc(m1*m1,size_of_real, devPtrC)
! Initialize the matrices A,B and C
       A=1._fp_kind
       B=2._fp_kind
       C=3._fp_kind
call cublas_Set_Matrix(m1,m1,size_of_real,A,m1,
     .           devPtrA,m1)
call cublas_Set_Matrix(m1,m1,size_of_real,B,m1,
     .           devPtrB,m1)
call cublas_Set_Matrix(m1,m1,size_of_real,C,m1,
     .           devPtrC,m1)
call cublas_SGEMM ('n','n',m1,m1,m1,alpha,devPtrA,m1,
     .              devPtrB,m1,beta,devPtrC,m1)
call cublas_Free(devPtrA)
       call cublas_Free(devPtrB)
       call cublas_Free(devPtrC)
       deallocate(A,B,C)
      end do
call cublas_shutdown()
But when i’m exec i have only one iteration . Why ?
Thanks for help !!!
For one thing, your size_of_real is wrong.
A single precision floating point value is 4 byte, you are using 16.
Thank you.
Now the cycle go on , but when i compute cputime this values are 0 .
So i suppose that dgemm not calling correctly .
right ?
You never copy back the results. Unless you add a cudaDeviceSynchronize or copy back C, your timing will be incorrect.
thank you . I copy back C and i have what i wont .
There is another question . I wuold like to confrontation Blas dgemm and cublas dgemm. I found that the cublas dgemm faster then mkl dgemm .
But in my application dgemm mkl is better then cublas dgemm .
So i would like to know if there is a place when i read anything in this way .
