A Faster (maybe better?) Qwen 3.5 122B
I know my timing is great (just when 3.8 Flash was released) but a bit over a month ago I asked myself a simple question: “Can we make Qwen3.5-122b-a10b faster while maintaining its quality?”. Albond’s provided me with a great hybrid model to use and it is still today that most of us still trust that model but I wanted a bit more.
So I went on a mission, but TL:DR First:
  • You will need @eugr_nv’s repo to start with
  • I only tested this in a GB10 chipset, should work on other hardware though
  • You MUST apply the hybrid patch for proper performance
  • The Hybrid Patch also works for @Albond’s old trusty Int4FP8 Hybrid model, so if you want to run the newest vLLM as of today (0.26.xx) with that model, you can use my patch
  • I vibe-coded the heck out of everything :)
  • If you follow the above, you should easily get 70+ tok/sec in coding.
  • This model also got the Spark-AutoRound treament from @whpthomas
Why is it faster?
The model has 256 small specialist networks (“experts”) in every layer. It doesn’t use them all — for each word it generates, a router picks a handful and only those run.
I changed the router from picking 8 to picking 4. Nothing was deleted. All 256 experts are still in the file. The model just consults half as many per word, so each word costs about half the expert work which is where the speed comes from.
The catch: the model was trained expecting 8 opinions and now gets 4, so it loses a bit of quality.
That’s what the healing fixed, every layer also has one “shared expert” that always runs regardless of the router, and I retrained that one to make up for the 4 that no longer get consulted.
So basically, I told it to ask 4 specialists instead of 8, then trained its generalist to cover the difference.
In my (very custom) benchmarks, I recovered the entire quality that I lost originally:
Albond’s Hybrid Int4Fp8 - 51%
Standard INT4 AutoRound - 47%
This model TopK4-Int4 - 50.7%
(results are from 10 rounds average trimming the lowest and highest scores to remove outliers)
Also tool-calling should be on-par with what the base FP8 or INT4 models can do at around 90/100 on the tool-eval-bench benchmark (it would gravitate from 89 to 91 in my tests)
Please run it, try it, tell me the good, the bad and the ugly. I have the final checkpoint for about a week, I was doing quality analysis while in parallel improving the MTP head for better acceptance (spoiler alert, it barely improve things by about ~2%) so I’m happy with this checkpoint but I’m still working on getting it better if I find things I don’t like. So far so good :)
Get your model from here (launch parameters used in the development and testing are in the model card)
Don’t forget to patch your vLLM image!!! Otherwise you’ll be around 47-50 tok/s
Very very cool work dude. Thanks! Can’t wait to see what you do with Qwen 3.8 Flash next
@azampatti that sounds like amazing work - very cool idea to half the experts used. How did you come up with that one? Surely this principle could be applied to every MOE model? I am imagining pairing it with the latest prismaquant work by @tenari
3.8 Flash is ~180B — it won’t fit a single DGX Spark. That’s why I went with the dense 27B first; Flash later.
Qwen3.8-27B on one DGX Spark, ~50 tok/s single request (a single request lands around 50 tok/s — about 56 with a short prompt, about 47 once the prompt is 8,000 tokens.), and it holds up in parallel:
NVIDIA test 16 parallel
balanced (1000 in / 1000 out) 255.97 tok/s
decode-heavy (1000 / 8000) 208.64 tok/s
prompt-heavy (8000 / 1000) 115.23 tok/s
Measured today, vLLM 0.27.1, AutoRound INT4 + MTP + SM121 kernels, warm-up excluded. Forum’s NVFP4 on prompt-heavy is 87.91, FP8 65.58.
As usual, on my part: clone, run one install script, pick how many requests run at once — the rest queues. Project albond/DenseSpark-Qwen3.8-27B · GitHub push when it’s up,.
Please make sure to give me feedback when you try it for a few days! :)
I spent long hours researching and learning with Claude (it’s an amazing teacher ;-) ), I’ve tried multiple things and this method what the one that caused the least initial damage to the model so it was the easiest to recover. I had another method that I tried for about 10 days in a row that was much faster but it was impossible for me to recover the quality so I abandoned it.
I want to use your repo 3.8 Flash Next to find way to run 3.8 Flash Next on Single DGX Spark with minimum quality impact and good performance. Let’s see. I am also curiosity.
PS: Qwen3.8 27b released v1.0 with good performance as for Dense model.
I’ll give you 27B a go soon! I don’t normally run dense models, it’s always good to have them handy.
Feel free to grab, destroy, improve my 3.8-flash one as you wish :) Also, DM me if you want, I’m already deep into extracting 5 more tok/sec out of this model (Already done, now working on recovering more quality) :)
I reviewed your project and it has no licenses :) and I could not use it by policy. I recommend next time generate Apache 2 or MIT.
But your project based on GitHub - deathbyorderfill/flashnext-one-spark: A 180B model that officially needs two DGX Sparks, running on one at full 256k context - by compressing the one part of the model no quantizer can touch. · GitHub, they have MIT and I reviewed also. Mostly I look for deep way to improve performance.
My first project Qwen3.5 122b and new 27b has opcode optimization in Triton just for SM121 and fix MTP up to 6. let see what I will have in final Flash-Next.
Yeah, I might screwed up with the license. I’ll change it as soon as I get home. Feel free to copy whatever you want.
Done, Apache 2 license attached. @Albond It’s all yours! looking forward what you can do with it! :)
