A general C++ CUDA integration framework example I present a simple C++ integration
HI everybody,
I want to introduce you my little framework to manage CUDA in my C++ program.
And I hope I will motivate another person to help me to do the same with texture and cuda Array.
Here the following code I can use in a C++ program (It’s pleasant is’nt it !)
//--| Initialiaze Cuda librairie
	cuda_lib::InitCudaLibrary();
	//--| Create a host and device memory interface
	cuda_lib::gpu_vector<float> device_mem;
	cuda_lib::cpu_vector<float> host_mem;
	//--| Allocate memory
	host_mem.Allocate(10,true,1.0);
	device_mem.Allocate(10);
	//--| Affect data to the cpu vector
	cout<<endl;
	for(int i=0;i<10;++i)
  cout<<" "<<host_mem[i];
	try
  //--| Transfert CPU data to GPU data
  device_mem<<host_mem;
 //--| Test a little computation : (vector+=4)
  cuda_lib::CallKernelFloat(device_mem.GetDeviceMemoryPointer(),device_mem.GetSize());
 //--| Transfert GPU data to CPU data
  device_mem>>host_mem;
 //--| Display the result :
  cout<<endl;
	catch(exception & e)
  cout<<endl<<"Exception : "<< e.what()<<endl;
  int i=0; cin>>i;
	cuda_lib::CloseCudaLibrary();
If you want take a look (attachments or link) :
go on : THe example code
I wait all your comment and some help to manage with succes a CPP framework to use texture (I have done some test but without success).
External Image Enjoy it.
I have try to respect cuda style (note the << and >> operator for the memory transfert)
Cuda.zip (24 KB)
NICE
Can’t believe I haven’t come across this before. That syntax looks very nice and Boost-like.
Any news of the project?
If you are interestes in something similar. We are developing a CUDA Template library at our institute. Everybody is welcome to share some ideas and collaborate. Therefore we started a SF project:
[url=“cudatemplates download | SourceForge.net”]https://sourceforge.net/projects/cudatemplates[/url]
Best Regards,
Manuel Werlberger
[url=“cudatemplates download | SourceForge.net”]cudatemplates download | SourceForge.net
The cudatemplate URL gets redirected to URL above and says “Invalid project”
ok? It doesn’t do that for me??
Manuel
Invalid project for me too :( Looks like interesting work!
Ok. Strange.
You can go to http://www.gpu4vision.org . In the download section there is a link to the CUDA templates which links towards SF.
Also a search for cuda in SF brings up the link [url=“cudatemplates download | SourceForge.net”]http://sourceforge.net/projects/cudatemplates/[/url]
If it still does not work, please post here again.
Best regards,
Manuel
