• Hardware Platform GPU • DeepStream Version 6.0 • JetPack Version (valid for Jetson only) • TensorRT Version8.0.6.1 • NVIDIA GPU Driver Version (valid for GPU only) 470 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
We have many samples, such as: /opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-preprocess-test/test/config_preprocess_yolo.txt Can you have a try it?
