I run docker images like:
sudo docker run -it --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:4.0.2-19.12-samples
I run some docker images in my the edge gateway,I want to allocate the specific gpu resource size for every docker images.
Can I allocate a gpu resource of the specified size to docker image.
Sorry, you won’t be able to do that.
Please check this page for information:
https://github.com/NVIDIA/nvidia-docker/wiki#can-i-limit-the-gpu-resources-eg-bandwidth-memory-cuda-cores-taken-by-a-container
Can I limit the GPU resources (e.g. bandwidth, memory, CUDA cores) taken by a container?
No. Your only option is to set the GPU clocks at a lower frequency before starting the container.
HI AastaLLL
Thank you AastaLLL
Will you support this function in future releases?
Sorry that this support is not in our future list yet.
Hi AastaLLL
when I run two docker container,one of both occur error follow:
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
The progress of starting container is:
- export DISPLAY=:0
- xhost +
- sudo docker run -it --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:4.0.2-19.12-iot
- deepstream-test5-app -c source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt
The other one is same as it.
when I try use other display,“export DISPLAY=:1”,it still don’t work.
Last question is that can I not use x11? In fact,I needn’t display in local screen.
You can try to launch the container with this command:
$ sudo docker run -it --net=host --runtime nvidia -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:4.0.2-19.12-iot
We can run the step.4 command in the above environment without error.
Hi AastaLLL,
When I run first container,it is correct.But When I run second container,it occur the error.
Both programs, “deepstream-test5-app” ,are running at the same time.
Can I run more than one program,“deepstream-test5-app”,at a time.
We can reproduce this issue in our environment.
The root cause is the second deepstream-test5-app will fail when the display is occupied.
An alternative is to change one of the config into FakeSink.
We can launch two deepstream-test5-app without after applying this update.
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
