A problem with template and kernel call Compilation fails in this case
I’ve got a problem with my program .
I want to templatized a function which calls a template kernel.
Here is my code:
main.cu
[codebox]:
#include “OpOnMatGPUH.cuh”
int main(){
int *a1, *a2;
matSquareMulGPU(a1, a2);
}[/codebox]
OpOnMatGPUH.cuh
[codebox]template
void
matSquareMulGPU(T* a, T* b);
#include “OpOnMatGPU.cu”[/codebox]
OpOnMatGPU.cu
[codebox]#include “matMul.cuh”
template
void matSquareMulGPU(T* a, T* b){
    matMulKernel<<< numBlocks , threadsPerBlock >>>(a,b);
}[/codebox]
matMul.cuh
[codebox]template
global void
matMulKernel(
				   T* mat1,
				   T* matRes,
				   int dimMat,
				   int method){
}[/codebox]
When i compile, under Visual Studio 2005, with Cuda 3.0, compiler sends me:
[codebox]c:\documents and settings\pgaulard\my documents\visual studio 2005\projects\testcuda\testcuda\OpOnMatGPU.cu(134) : error C2059: syntax error : ‘<’
1> c:/…/MainTest.cu(51) : see reference to function template instantiation ‘void matSquareMulGPU(int,T *,T *,int,float *,Args,CudaProps)’ being compiled
1> with
1> [
1> T=int
1> ][/codebox]
where 134 is the kernel call line in OpOnMatGPU.cu and 51 template function call line.
I don’t understand, because i can compile project simpleTemplate provided by Cuda SDK, where we can see how integrate templates.
Thanks for your help
pietro
From a quick glance:
Shouldn’t this:
template <class T>
Changed to:
template <class T>
matMulKernel< T ><<< numBlocks , threadsPerBlock >>>(a,b);
I’ve tried that and it doesn’t work. Compilation sends me the same result
