A Simple Guide to Deploying Generative AI with NVIDIA NIM
Originally published at: https://developer.nvidia.com/blog/a-simple-guide-to-deploying-generative-ai-with-nvidia-nim/
Whether you’re working on-premises or in the cloud, NVIDIA NIM inference microservices provide enterprise developers with easy-to-deploy optimized AI models from the community, partners, and NVIDIA. Part of NVIDIA AI Enterprise, NIM offers a secure, streamlined path forward to iterate quickly and build innovations for world-class generative AI solutions. Using a single optimized container, you…
Hello! I am trying to carefully follow the Getting started NIM blog above to run the NIM image standalone on my GPU based AWS EC2 instance but I’m blocked by this strange docker authentication issue:
docker login nvcr.io
Authenticating with existing credentials… WARNING! Your password will be stored unencrypted in /home/ec2-user/.docker/config.json. Configure a credential helper to remove this warning.
$ docker pull nvcr.io/nim/meta/llama3-8b-instruct:24.05
Error response from daemon: Head “https://nvcr.io/v2/nim/meta/llama3-8b-instruct/manifests/24.05”: unauthorized: 401 Authorization Required
nginx/1.22.1
I am using the export NGC_API_KEY= for authentication.
Any suggestions on why direct authentication into ‘nvcr.io’ using my key works:
echo "$NGC_API_KEY" | docker login nvcr.io --username '$oauthtoken' --password-stdin
Configure a credential helper to remove this warning. See
Login Succeeded`
but this command just trying to pull down an image from nvcr.io:
`docker pull nvcr.io/nim/meta/llama3-8b-instruct:24.05
Error response from daemon: Head "XXXXXX : unauthorized:
nginx/1.22.1
What am I missing please? thanks!
Note that an NVIDIA AI Enterprise License is required to download and use NIM.
Any guide to apply NVIDIA AI Enterprise License? Thanks
How do we implement this inside our datacenter? This looks like you need public cloud offering and our bank generally likes to keep things on-prem.
Hi! The image tag changed and the post has been updated. Please try again. Sorry for the trouble.
You can run this on premises using the instructions in this blog post.
The first snippet has a typo, it should be
export IMG_NAME="nvcr.io/nim/${VENDOR_NAME}/${CONTAINER_NAME}:1.0.0"
but currently there are round brackets around VENDOR_NAME so it tries to run it as a command.
Where should these commands be executed?
I have a windows PC with a docker installed. Should I be running them on a CMD prompt?
And how about testing the interface requests? Should that be also on a CMD prompt?
Br,
Raghu
