I took an example of data transfer between Host and Device for CUDA Fortran and found this:
Host Code:
program incTest
use cudafor
use simpleOps_m
implicit none
integer, parameter :: n = 256
integer :: a(n), b, i
integer, device :: a_d(n)
a = 1
b = 3
a_d = a
call inc<<<1,n>>>(a_d, b)
a = a_d
if (all(a == 4)) then
write(*,*) 'Success'
endif
end program incTest
Device Code:
module simpleOps_m
contains
attributes(global) subroutine inc(a, b)
implicit none
integer :: a(:)
integer, value :: b
integer :: i
i = threadIdx%x
a(i) = a(i)+b
end subroutine inc
end module simpleOps_m
The expected outcome is the console presenting “Success”, but this did not happen. Nothing did, nothing errors or messages. This happen because don’t enter in if, because a_d has the same value that before call inc subroutine.
I’m using:
OS: Linux - Ubuntu 16
Cuda 8
PGI to compile
Commands to compile:
pgf90 -Mcuda -c Device.cuf
pgf90 -Mcuda -c Host.cuf
pgf90 -Mcuda -o HostDevice Device.o Host.o
./HostDevice
I tried other examples and they did not work too.
I tried using simple Fortran (.f90) code with the same commands to compile and it works!
How can I fix this problem?
