I have installed the nVIDIA software in CentOS8.2 with kernel 5.10.131 with A5000 without problems;
I installed NVIDIA-Linux-x86_64-510.73.06-vgpu-kvm.run ok, but when I list
/sys/bus/pci/devices/0000:86:00.0 there is not directory mdev_supported_types.
Some ideas? Can you help me?
I attempted /usr/lib/nvidia/sriov-manage -e 0000:86:00.0
but there is not directory mdev_supported_types.
I confirmed the iommu is on;
Are you running the A5000 in the required mode (datacenter mode)?
Did you use the mode selector tool? If not, the GPU is still in workstation mode and won’t work as a vGPU device.
