hi all ,i want to know how can i stop the encoder just at my owner ider,for example that following code is from the 03_video_cuda_enc, if i want to just read the frame for 3 times then i break the while loop,then i run the app will has the following errors,so how can stop the encoder normally?
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
-------getNumBuffers=6
H264: Profile = 77, Level = 50
[ERROR] (NvV4l2ElementPlane.cpp:256) Output Plane:Error while Qing buffer: Device or resource busy
Error while queueing buffer at output plane
Encoder is in error
[ERROR] (NvV4l2ElementPlane.cpp:178) Capture Plane:Error while DQing buffer: Broken pipe
[ERROR] (NvV4l2ElementPlane.cpp:256) Capture Plane:Error while Qing buffer: Device or resource busy
Error while Qing buffer at capture plane
App run failed
/* Keep reading input till EOS is reached */
while (!ctx.got_error && !ctx.enc->isInError() && !eos)
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
NvBuffer *buffer;
int fd;
void **dat;
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, sizeof(planes));
v4l2_buf.m.planes = planes;
if (ctx.enc->output_plane.dqBuffer(v4l2_buf, &buffer, NULL, 10) < 0)
cerr << "ERROR while DQing buffer at output plane" << endl;
abort(&ctx);
goto cleanup;
if (read_video_frame(ctx.in_file, *buffer) < 0)
cerr << "Could not read complete frame from input file" << endl;
v4l2_buf.m.planes[0].bytesused = 0;
* buffer is touched by CPU in read_video_frame(), so NvBufferMemSyncForDevice()
* is needed to flash cached data to memory.
fd = buffer->planes[0].fd;
for (uint32_t j = 0 ; j < buffer->n_planes ; j++)
dat = (void **)&buffer->planes[j].data;
ret = NvBufferMemSyncForDevice (fd, j, dat);
if (ret < 0)
cerr << "Error while NvBufferMemSyncForDevice at output plane" << endl;
abort(&ctx);
goto cleanup;
/* map DMA fd to eglImage for CUDA processing */
ctx.eglimg = NvEGLImageFromFd(ctx.eglDisplay, buffer->planes[0].fd);
/* render rectangle by CUDA */
HandleEGLImage(&ctx.eglimg);
/* release eglImage */
NvDestroyEGLImage(ctx.eglDisplay, ctx.eglimg);
ret = ctx.enc->output_plane.qBuffer(v4l2_buf, NULL);
if (ret < 0)
cerr << "Error while queueing buffer at output plane" << endl;
abort(&ctx);
goto cleanup;
if (v4l2_buf.m.planes[0].bytesused == 0)
cerr << "File read complete." << endl;
eos = true;
break;
