Jetpack 5.1.1 version supports Torch2.0, but Cuda version is 11.4. Cuda 11.4 does not support Torch2.0 on the desktop. I installed Torch2.0 on Jetpack 5.1.1 and encountered an error while using the mmdetection framework. The mmcv library was unable to load a system’s so file. May I ask if cuda11.4 in Jetpack 5.1.1 supports Torch.complie() acceleration for PyTorch2.0?
AastaLLL
3
Could you share how you install PyTorch 2.0?
Please try our prebuilt which supports CUDA 11.4 with the below instructions:
Related topics
| Unable to install Torch compatible with Jetson 5.1 and CUDA 11.4 | 1 | 130 | May 5, 2025 | |
| Pytorch install failed | 6 | 1593 | November 16, 2022 | |
| How to download torch 1.7.1 or 2.1.0 with cuda >= 11.0 | 2 | 2268 | December 26, 2023 | |
| Install pytorch 2.6 and torchvision 0.21 | 3 | 625 | April 23, 2025 | |
| Using Pytorch on GPU after upgrading cuda to 11.8 on Jetpack5 | 7 | 2212 | August 7, 2023 | |
| Request pytorch for jetpack5.1.3 | 6 | 496 | April 24, 2025 | |
| PyTorch 1.11 for JetPack 5.0 DP? | 19 | 4065 | May 5, 2022 | |
| Pytorch with CUDA for Jetpack 5.1.4 | 3 | 1109 | December 30, 2024 | |
| Building torch with cuda 10 support on Jetpack 5.0 (cuda 11) | 4 | 1553 | December 22, 2022 | |
| Pytorch installation error | 10 | 1720 | December 14, 2023 |
