About LD instruction for wmma
I confused about LD instruction.
I have a cuda program about wmma, I just launch a block and the block size is 32. my cuda code is very simple, like this:
__global__ void ldmatrix_test(float *a, float *b, float *C)
  // Declare the fragments
  wmma::fragment<wmma::matrix_a, 16, 16, 8, wmma::precision::tf32, wmma::row_major> a_frag;
  wmma::fragment<wmma::matrix_b, 16, 16, 8, wmma::precision::tf32, wmma::col_major> b_frag;
  wmma::fragment<wmma::accumulator, 16, 16, 8, float> acc_frag;
  wmma::fill_fragment(acc_frag, 0.0f);
  wmma::load_matrix_sync(a_frag, a, 8);
  wmma::load_matrix_sync(b_frag, b, 8);
  // Perform the matrix multiplication
  wmma::mma_sync(acc_frag, a_frag, b_frag, acc_frag);
  wmma::store_matrix_sync(C, acc_frag, 16, wmma::mem_row_major);
A shap is [16, 8], and B shape is [8, 16], A is row-major, B is col-major.
I’m very confused about the SASS, as following:
	code for sm_86
		Function : _Z13ldmatrix_testPfS_S_
	.headerflags    @"EF_CUDA_SM86 EF_CUDA_PTX_SM(EF_CUDA_SM86)"
        /*0000*/                   MOV R1, c[0x0][0x28] ;                               /* 0x00000a0000017a02 */
        /* 0x000fc40000000f00 */
        /*0010*/                   S2R R2, SR_LANEID ;                                  /* 0x0000000000027919 */
        /* 0x000e220000000000 */
        /*0020*/                   MOV R25, 0x4 ;                                       /* 0x0000000400197802 */
        /* 0x000fe20000000f00 */
        /*0030*/                   ULDC.64 UR4, c[0x0][0x118] ;                         /* 0x0000460000047ab9 */
        /* 0x000fe20000000a00 */
        /*0040*/                   SHF.R.U32.HI R5, RZ, 0x2, R2 ;                       /* 0x00000002ff057819 */
        /* 0x001fe40000011602 */
        /*0050*/                   LOP3.LUT R2, R2, 0x3, RZ, 0xc0, !PT ;                /* 0x0000000302027812 */
        /* 0x000fc800078ec0ff */
        /*0060*/                   LEA R0, R5, R2, 0x3 ;                                /* 0x0000000205007211 */
        /* 0x000fc800078e18ff */
        /*0070*/                   IADD3 R14, R0.reuse, 0x40, RZ ;                      /* 0x00000040000e7810 */
        /* 0x040fe20007ffe0ff */
        /*0080*/                   IMAD.WIDE R12, R0, R25, c[0x0][0x168] ;              /* 0x00005a00000c7625 */
        /* 0x000fc800078e0219 */
        /*0090*/                   IMAD.WIDE R10, R14, R25.reuse, c[0x0][0x160] ;       /* 0x000058000e0a7625 */
        /* 0x080fe400078e0219 */
        /*00a0*/                   LD.E R12, [R12.64] ;                                 /* 0x000000040c0c7980 */
        /* 0x000ea4000c101900 */
        /*00b0*/                   IMAD.WIDE R8, R0, R25.reuse, c[0x0][0x160] ;         /* 0x0000580000087625 */
        /*00c0*/                   LD.E R7, [R10.64] ;                                  /* 0x000000040a077980 */
        /*00d0*/                   IMAD.WIDE R14, R14, R25, c[0x0][0x168] ;             /* 0x00005a000e0e7625 */
        /* 0x000fe400078e0219 */
        /*00e0*/                   LD.E R6, [R8.64] ;                                   /* 0x0000000408067980 */
        /* 0x000ea2000c101900 */
        /*00f0*/                   IADD3 R18, R0, 0x4, RZ ;                             /* 0x0000000400127810 */
        /* 0x000fc60007ffe0ff */
        /*0100*/                   LD.E R14, [R14.64] ;                                 /* 0x000000040e0e7980 */
        /* 0x000ee2000c101900 */
        /*0110*/                   IADD3 R0, R0, 0x44, RZ ;                             /* 0x0000004400007810 */
        /* 0x000fe20007ffe0ff */
        /*0120*/                   IMAD.WIDE R22, R18, R25, c[0x0][0x168] ;             /* 0x00005a0012167625 */
        /*0130*/                   IMAD.WIDE R18, R18, R25.reuse, c[0x0][0x160] ;       /* 0x0000580012127625 */
        /*0140*/                   LD.E R22, [R22.64] ;                                 /* 0x0000000416167980 */
        /* 0x000f24000c101900 */
        /*0150*/                   IMAD.WIDE R20, R0.reuse, R25.reuse, c[0x0][0x160] ;  /* 0x0000580000147625 */
        /* 0x0c0fe400078e0219 */
        /*0160*/                   LD.E R16, [R18.64] ;                                 /* 0x0000000412107980 */
        /*0170*/                   IMAD.WIDE R24, R0, R25, c[0x0][0x168] ;              /* 0x00005a0000187625 */
        /*0180*/                   LD.E R17, [R20.64] ;                                 /* 0x0000000414117980 */
        /* 0x000f28000c101900 */
        /*0190*/                   LD.E R24, [R24.64] ;                                 /* 0x0000000418187980 */
        /* 0x000f22000c101900 */
        /*01a0*/                   MOV R3, RZ ;                                         /* 0x000000ff00037202 */
        /* 0x000fca0000000f00 */
        /*01b0*/                   IMAD.WIDE.U32 R2, R5, 0x8, R2 ;                      /* 0x0000000805027825 */
        /* 0x000fca00078e0002 */
        /*01c0*/                   LEA R4, P0, R2, c[0x0][0x170], 0x3 ;                 /* 0x00005c0002047a11 */
        /* 0x000fc800078018ff */
        /*01d0*/                   LEA.HI.X R5, R2, c[0x0][0x174], R3, 0x3, P0 ;        /* 0x00005d0002057a11 */
        /* 0x000fe200000f1c03 */
        /*01e0*/                   HMMA.1684.F32.TF32 R8, R6.reuse, R12, RZ ;           /* 0x0000000c0608723c */
        /* 0x044f6800000850ff */
        /*01f0*/                   HMMA.1684.F32.TF32 R12, R6, R14, RZ ;                /* 0x0000000e060c723c */
        /* 0x008f5800000850ff */
        /*0200*/                   HMMA.1684.F32.TF32 R8, R16.reuse, R22, R8 ;          /* 0x000000161008723c */
        /* 0x070f680000085008 */
        /*0210*/                   HMMA.1684.F32.TF32 R12, R16, R24, R12 ;              /* 0x00000018100c723c */
        /* 0x000f76000008500c */
        /*0220*/                   ST.E.64 [R4.64], R8 ;                                /* 0x0000000804007985 */
        /* 0x020fe8000c101b04 */
        /*0230*/                   ST.E.64 [R4.64+0x200], R10 ;                         /* 0x0002000a04007985 */
        /* 0x000fe8000c101b04 */
        /*0240*/                   ST.E.64 [R4.64+0x20], R12 ;                          /* 0x0000200c04007985 */
        /*0250*/                   ST.E.64 [R4.64+0x220], R14 ;                         /* 0x0002200e04007985 */
        /* 0x000fe2000c101b04 */
        /*0260*/                   EXIT ;                                               /* 0x000000000000794d */
        /* 0x000fea0003800000 */
        /*0270*/                   BRA 0x270;                                           /* 0xfffffff000007947 */
        /* 0x000fc0000383ffff */
        /*0280*/                   NOP;                                                 /* 0x0000000000007918 */
        /* 0x000fc00000000000 */
        /*0290*/                   NOP;                                                 /* 0x0000000000007918 */
        /*02a0*/                   NOP;                                                 /* 0x0000000000007918 */
        /*02b0*/                   NOP;                                                 /* 0x0000000000007918 */
        /*02c0*/                   NOP;                                                 /* 0x0000000000007918 */
        /*02d0*/                   NOP;                                                 /* 0x0000000000007918 */
        /*02e0*/                   NOP;                                                 /* 0x0000000000007918 */
        /*02f0*/                   NOP;                                                 /* 0x0000000000007918 */
I found this instruction:
“LD.E R7, [R10.64]” is before “LD.E R6, [R8.64]”, I think “LD.E R7, [R10.64]” means:
load an 64bits word from R10, and save it into R7 and R8, because LD.E is extend 32bits into 64bits, and R10.64 means 64bits address。
but, “LD.E R6, [R8.64]” will load 64bits word into R6 and R7 again, so, it will overwrite R7,why?
there is a similar problem behind “LD.E R6, [R8.64]”:
why nvcc compile cuda-c like this? I think it is better as following:
LD R16, [R18]
LD R17, [R20]
I cannot sure the reason, is there anyone would like to teach me?
another problem: is there any reference documents about “HMMA.1684.F32.TF32”?
The .E suffix does not indicate that the loaded data is extended to a wider data type, which is what I think you interpreted it as. Rather it indicates that a 64-bit “extended address” is used. Since that is the standard for CUDA these days, you will see LD.E and ST.E all over the place. Instructions consuming or producing 64-bit data generally retrieve data from and deposit data into aligned register pairs (meaning the least significant bits are in a register with an even register number N, the most significant bits in the adjacent register with number N+1), thus
LD.E R17, [R20.64]
is a 32-bit load into the 32-bit register R17, with the 64-bit address in R20 and R21. To me, the .64 suffix seems redundant with the .E suffix and does not appear in disassembly for older GPU architectures before compute capability 8.0 (sm_80). If I am missing something in that regard, I am sure someone in the know will set me straight.
thank you
