About PyTorch for Jetpack4.5.2
Hi
I bought a device with NVIDIA® Jetson™ Xavier NX pre-installed.
I checked the Jetpack version.
It was Jetpack 4.5.2
I tried to install PyTorch by referring to the following case, but I can’t find PyTorch that supports JetPack 4.5.2.
PyTorch v1.10.0 is compatible with JetPack4.5.1
My Jetson is JetPack4.5.2, can I use this?
Hi @Heartful-echo, yes you should be able to use the PyTorch v1.10 wheel with JetPack 4.5.1. You could also use the l4t-pytorch container (the r32.5.0 tags for JetPack 4.5.x)
