I used ncu to analysis cdist_backward. I have some questions about the print below。
what’s sm__throughput.avg.pct_of_peak_sustained_elapsed and gpu__dram_throughput.avg.pct_of_peak_sustained_elapsed mean ?
sm__throughput.avg.pct_of_peak_sustained_elapsed = compute_efficiency?
gpu__dram_throughput.avg.pct_of_peak_sustained_elapsed = io_efficiency?
How it is calculated
this is my gpu information
GPU Name = Tesla V100-SXM2-16GB
Compute Capability = 7.0
GPU SMs = 80
GPU CUDA cores = 5120
GPU SM clock rate = 1.530 GHz
GPU Mem clock rate = 0.877 GHz
FP32 Peak Performance = 15667.200 GFLOPS
FP16 Peak Performance = 31334.400 GFLOPS
INT8 Peak Performance = 62668.800 GFLOPS
Tensor Core FP16 Peak Performance = 125337.600 GFLOPS
root@sh815:/work/operator# ncu --print-summary per-kernel --section SpeedOfLight python cdist_backward.py
==PROF== Connected to process 489 (/opt/conda/bin/python3.7)
==PROF== Profiling "cdist_kernel_cuda_impl" - 1: 0%....50%....100% - 19 passes
torch.Size([900, 31])
==PROF== Profiling "cdist_backward_kernel_cuda_impl" - 2: 0%....50%....100% - 19 passes
==PROF== Profiling "reduce_kernel" - 3: 0%....50%....100% - 19 passes
torch.Size([900, 8])
==PROF== Disconnected from process 489
[489] python3.7@127.0.0.1
void at::native::<unnamed>::cdist_backward_kernel_cuda_impl<float, at::native::<unnamed>::dists<float>::one>(T1 *, const T1 *, const T1 *, const T1 *, const T1 *, long, T1, long, long, long, long, long, long, long), Block Size 1, Grid Size 1, Device 0, 1 invocations
Section: GPU Speed Of Light Throughput
Metric Name Metric Unit Minimum Maximum Average
dram__cycles_elapsed.avg.per_second cycle/usecond 802.114804 802.114804 802.114804
gpc__cycles_elapsed.avg.per_second cycle/nsecond 1.185659 1.185659 1.185659
gpc__cycles_elapsed.max cycle 25192.000000 25192.000000 25192.000000
gpu__compute_memory_throughput.avg.pct_of_peak_sustained_elapsed % 13.941638 13.941638 13.941638
gpu__dram_throughput.avg.pct_of_peak_sustained_elapsed % 0.813250 0.813250 0.813250
gpu__time_duration.sum usecond 21.184000 21.184000 21.184000
l1tex__throughput.avg.pct_of_peak_sustained_active % 15.368853 15.368853 15.368853
lts__throughput.avg.pct_of_peak_sustained_elapsed % 2.568912 2.568912 2.568912
sm__cycles_active.avg cycle 22784.962500 22784.962500 22784.962500
sm__throughput.avg.pct_of_peak_sustained_elapsed % 60.943825 60.943825 60.943825
void at::native::<unnamed>::cdist_kernel_cuda_impl<float, at::native::<unnamed>::dists<float>::one>(T1 *, const T1 *, const T1 *, T1, long, long, long, long, long, long), Block Size 1, Grid Size 1, Device 0, 1 invocations
dram__cycles_elapsed.avg.per_second cycle/usecond 870.075509 870.075509 870.075509
gpc__cycles_elapsed.avg.per_second cycle/nsecond 1.297918 1.297918 1.297918
gpc__cycles_elapsed.max cycle 253287.000000 253287.000000 253287.000000
gpu__compute_memory_throughput.avg.pct_of_peak_sustained_elapsed % 12.712454 12.712454 12.712454
gpu__dram_throughput.avg.pct_of_peak_sustained_elapsed % 0.017300 0.017300 0.017300
gpu__time_duration.sum usecond 194.944000 194.944000 194.944000
l1tex__throughput.avg.pct_of_peak_sustained_active % 12.822529 12.822529 12.822529
lts__throughput.avg.pct_of_peak_sustained_elapsed % 0.575559 0.575559 0.575559
sm__cycles_active.avg cycle 250853.300000 250853.300000 250853.300000
sm__throughput.avg.pct_of_peak_sustained_elapsed % 76.590542 76.590542 76.590542
void at::native::reduce_kernel<(int)128, (int)4, at::native::ReduceOp<float, at::native::func_wrapper_t<float, at::native::sum_functor<float, float, float>::operator ()(at::TensorIterator &)::[lambda(float, float) (instance 1)]>, unsigned int, float, (int)4>>(T3), Block Size 1, Grid Size 1, Device 0, 1 invocations
dram__cycles_elapsed.avg.per_second cycle/usecond 610.294118 610.294118 610.294118
gpc__cycles_elapsed.avg.per_second cycle/usecond 912.055760 912.055760 912.055760
gpc__cycles_elapsed.max cycle 9933.000000 9933.000000 9933.000000
gpu__compute_memory_throughput.avg.pct_of_peak_sustained_elapsed % 13.133001 13.133001 13.133001
gpu__dram_throughput.avg.pct_of_peak_sustained_elapsed % 13.133001 13.133001 13.133001
gpu__time_duration.sum usecond 10.880000 10.880000 10.880000
l1tex__throughput.avg.pct_of_peak_sustained_active % 23.517313 23.517313 23.517313
lts__throughput.avg.pct_of_peak_sustained_elapsed % 5.245606 5.245606 5.245606
sm__cycles_active.avg cycle 1482.950000 1482.950000 1482.950000
sm__throughput.avg.pct_of_peak_sustained_elapsed % 0.998429 0.998429 0.998429
