I’m experiencing a persistent access issue with my NVIDIA Build account (build.nvidia.com) that is blocking me from using the API and the playground entirely.
The problem is not specific to a single model. I have tried multiple models and each one fails with a different but related error:
- deepseek-ai/deepseek-v4-flash — fails with “400 status code (no body)” after repeated auto-retries
- qwen/qwen2.5-coder-32b-instruct — fails with “410 status code (no body)”
- qwen/qwen3-coder-480b-a35b-instruct — fails with “410 status code (no body)”
To rule out a client-side issue, I also tested directly in the NVIDIA Build playground (not through any third-party tool or API client), sending a simple “hi” message to a model. The playground returned this error:
“Function id ‘52e1ddb6-c745-4802-93f5-ba012d04c336’ version ‘null’: Specified function in account ‘NtdWlQlq9M-CYImoK2kS6Qp53OQ6Y9Dmou6DMUaiP1M’ is not found”
Since this exact error occurs both through direct API calls and through the official playground UI, I believe the issue is not related to my API key, network, or any client-side code — it appears to be an account-level function registration problem on NVIDIA’s side.
Relevant identifiers:
- Account ID: NtdWlQlq9M-CYImoK2kS6Qp53OQ6Y9Dmou6DMUaiP1M
- Function ID: 52e1ddb6-c745-4802-93f5-ba012d04c336
I also attempted a direct curl request to the chat completions endpoint using a valid API key, and received a 400 error with no response body, which is consistent with the above.
I’m currently using this account for a personal software development project and this issue has completely blocked my ability to use any model through the API. Could you please investigate the function registration for this account and let me know what steps are needed to resolve it?
Thank you very much for your help.
Best regards
