Thanks for the help @JerryChang .
Now I have vi errors when using the v4l2-ctl to stream the /dev/video0. For example:
(NULL device *): vi_capture_control_message: NULL VI channel received
I saw you answered this issue before in another thread for the AGX Orin.
I didn’t understand both the cause and solution for this error. Does it related to some mismatch config data between the sensor and the vi? (different resolution for example)
Hi @JerryChang ,
I followed this chapters and noticed that the compliance test fails in 2 out of 45 tests.
Following is the log of executing the test and executing the v4l2 stream that fails. log.log (14.6 KB)
From the error messages I see there is something NULL. Is it related to a missing function or something else?
Hi @JerryChang ,
I played a little with the settings on both driver and device tree.
I still fail in 2 tests out of 45 from the previous log I sent, but now I’m able to record the frames using the v4l2-ctl command without getting the “VI NULL errors.”
Now I wish to verify the recorded frames (the source is de-serializer pattern generator)
I can’t use gstreamer. I read here:
I have the same AB24 format. What can I do in order to be able to display the video on GUI?
What I need to do in order to pass the 2 tests out of 45.
WARNING: erroneous pipeline: could not link nvv4l2camerasrc0 to videoconvert0, nvv4l2camerasrc0 can’t handle caps video/x-raw(memory:NVMM), format=(string)BGRA, width=(int)640, height=(int)480, framerate=(fraction)60/1
Hi @JerryChang ,
I wish to thank you for your help and patience. I’ve learned a lot.
I saw that on JP5.1.3 the v4l2 plugin doesn’t support RGB888 and it requires a patch.
We decided to go with YUV for now and it works.
I’ll close this thread and thank you again.
