I have been using the @dusty_nv jetson-containers project with my Jetson Orin NX 16GB. Mostly I use the text-generation-webui, but loosing my settings each time I restart was bothering me. Here is a quick and dirt solution that worked for me.
# The assumptions:
- jetson-containers is installed
- you can run text-generation-webui
# The issue we are resolving:
- Each time the container is stopped the user settings are lost
# Procedure to add persistance to settings, characters and presets
cd ~/jetson-containers
# We need to have the container running during this phase
# Note the -d flag to detach the container as we need the command prompt
./run.sh -d $(./autotag text-generation-webui)
# Let’s get the container ID
docker ps
# Create an environment variable to make our live simpler
export CONTAINER_ID=<container_id>
# Create directories to store settings on the jetson host
mkdir -p data/settings/text-generation-webui
# Move to new directory to simplify next step
cd data/settings/text-generation-webui
# Copy files and directories
docker cp $CONTAINER_ID:/opt/text-generation-webui/characters .
docker cp $CONTAINER_ID:/opt/text-generation-webui/presets .
docker cp $CONTAINER_ID:/opt/text-generation-webui/settings.yaml .
# Stop and remove the container
docker stop $CONTAINER_ID
# Let's launch the service with persistence activated
./run.sh -v $PWD/data/settings/text-generation-webui/settings.yaml:/opt/text-generation-webui/settings.yaml -v $PWD/data/settings/text-generation-webui/presets/:/opt/text-generation-webui/presets/ -v $PWD/data/settings/text-generation-webui/characters/:/opt/text-generation-webui/characters/ $(./autotag text-generation-webui)
