Advancing the Accuracy-Efficiency Frontier with Llama-3.1-Nemotron-51B
Originally published at: https://developer.nvidia.com/blog/advancing-the-accuracy-efficiency-frontier-with-llama-3-1-nemotron-51b/
Today, NVIDIA released a unique language model that delivers an unmatched accuracy-efficiency performance. Llama 3.1-Nemotron-51B, derived from Meta’s Llama-3.1-70B, uses a novel Neural Architecture Search (NAS) approach that results in a highly accurate and efficient model. The model fits on a single NVIDIA H100 GPU at high workloads, making it much more accessible and affordable.…
Looks like something is missing on the huggingface repo. This is what running it with VLLM does:
 AttributeError: 'DeciLMConfig' object has no attribute 'num_key_value_heads_per_layer'
And with lmsys’ model_worker from fastchat, the output is basically garbage:
NoQuestion and dried#def035def0Question the but which said WELL)def1TitleQuestion from.........NETQuestion l cellsRQuestion that she pursuedQuestion Question from if0def0Question Question in def0Question or is we.from event's selectsdef1#ForQuestionQuestion and he.Question he,Question we,Question but he [def3Question and securing we,##import The waiting
Question atGenQuestion \(Question as she.##Question1#InternationalQuestion Question Question and if0Question anddef0Question ppQuestion and ScottishQuestion1def2Question althoughQuestion but and question and leadingQuestion Question and which she girl pageQuestion and |#Question as sincedef0Question andMichaeldef0
#Question createQuestion and Evedef10Adef1-Question 196def 'importThis and have constantQuestion #Question This of including even as to they:Question import......MicQuestion or well and people andQuestion it RegionalQuestion the CaliforniaQuestion and experienced thedef0Question000Question or picks3As COMQuestion such.
#def0def01Question000Question Question and employingQuestion OpticalQuestion where Question from especially between which In the PoQuestion onQuestion and WordQuestion seQuestion and ##Question and Lisadef0Question particularly I:We.Question 199Question which says tools and pressingQuestion 201import6Question where such in being and IndependentQuestion MaryQuestion onQuestion andQuestion that This 201#from{import :12#Question and SecAimport1def2Question Question import #Question and trusted smaller.##Question I.Question the VisashiQuestion which says FL#Question are thedef0def1Question and ‘I.#Question importbdef15Question000#Question 11Question import1Question but
Question and Serve##One2def0def1def0Question that he
importdef0def0Question 201Question theQuestion because1#Question0A#FQuestion but I
Question how my largest storyTh#def0Question Question said QuestionQuestion and she,def0As cub##UnitedQuestion &Question and perseverance They     13I:def0Question letQuestion anddef0def03Question andQuestion Question2Question from3I.5def0Question here.43#def1Question for picksAQuestion and choices andThedef0#Question andQuestion where but and she,Thedef100Question they:def30Question and.WaterQuestion def0F#It,Question 202def0Question 201Question as if2Question then skilled SchoolQuestion given and combines she:Should1RWe-This 198def3TheQuestion which Most QuestionQuestion one then thedef0def0TheQuestion but to stdoutQuestion anddef0def1Ldef1
def0def0def35-Question and silly InstituteQuestion importdef0Question such |__VerQuestion which said とIn idef0
Question there,Question so important from '{0def0def0Question def0Question and QuestionQuestion and we (Question and question and027Question of orOneQuestion and local hádef1Question StateQuestion as how She &#def0Question the 201def0Question Question and choices with major
Question who:def0Question and NOThe#def2def0Question Question but but CQuestion to we will the ‘Question and explained000Question Question for but picksQuestion that she
I,Question then
import2F#def1Question including participantsdef1def0def0def0Question 11Question and feminist.,Question you:def1Question if3Mdef18Question and cáQuestion #ByQuestion to we,Question which stateQuestion and fitness is selectsdef0
This ofdef1#Question a
importifQuestion for while backgroundQuestion and
Question which
#Question and.Question or DevQuestionAnTheQuestion in the shridef03Question theQuestion Texasdef2Question are the UnitedQuestion and interestQuestion 1##"def2def0Question by they
NQuestion of but challenged is
We/Question and questionnaire and will said while9Question Question or MQuestion atWe,Question that for#!/201This in StandardQuestion and selectsQuestion from LisaQuestion and electronicch#sQuestion importIt.def0
Question but and aboutQuestion in DeskQuestion delivering because5def0Question we
#Does he,def1#Question it,Question but ydef0def2Question anddef0Question a we
#Question (How to he
Question its if1
def0def0This/importTagdef0def0Question and said1Question aboutMicrosoftdef02#Analysis#def0Question nimportLQuestion 201Question HomeQuestion MarilynQuestion to polyQuestion most But _Question and EuropeanQuestion W#def0Question def
AttributeError: ‘DeciLMConfig’ object has no attribute ‘num_key_value_heads_per_layer’ stuck with this error, while deploying on top of vLLM. ANY WORKAROUNDS OR SUGGESTIONS
