When we flashed the AGX orin and it starts booting up and got o setup configuration. After setting up the configuration only spining cursor is coming on display. Not able to logout as well.
After resetting, it is again come up in setup configuration while i already did it in after first boot.
How did you flash the AGX Orin? With SDKM or flash script?
Do you mean that there’s display on your monitor but it always shows a spinning cursor rather than entering into desktop?
Please share the full serial console log for further check.
With the skip-oemconfig, I am able to login from host machine via console but in custom devkit there is no display coming out now. But able to runs commands via console using host machine.
When we are not skipping oem-config display is coming up with spinning cursor only.
After skipping oem-config, we are able to take control of console but sudo command is not working , we are getting this error when we run any command with sudo prefix-
/usr/bin/sudo must be owned by uid 0 and have the setuid bit set
Do you hit the permission issue only on the custom carrier board?
We would not hit the similar issue on the devkit.
Is there any custom modification may cause sudo not working?
