Orin nano version :Jetpack 6.1 ( L4T 36.4.0)
after i modified device tree of imx219 to add mode that enabling 120 fps, the resulting image is cropped
this is part of my device tree that i add on
mode4 {
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_b";
lane_polarity = "6";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
readout_orientation = "90";
line_length = "3560";
inherent_gain = "1";
mclk_multiplier = "9.33";
pix_clk_hz = "169600000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16";
max_gain_val = "170";
step_gain_val = "1";
default_gain = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000";
max_framerate = "120000000";
step_framerate = "1";
default_framerate = "120000000";
min_exp_time = "13";
max_exp_time = "683709";
step_exp_time = "1";
default_exp_time = "2495";
embedded_metadata_height = "2";
"nvarguscamerasrc silent=true ! "
"video/x-raw(memory:NVMM), width=1280, height=640, framerate=120/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=640, height=320, format=(string)GRAY8 ! "
"videoconvert ! "
"video/x-raw, format=(string)GRAY8 ! appsink name=sink emit-signals=true "
and this is the cropped image get from gstreamer
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
We are seeking assistance in resolving this issue. Thank you very much for your help!
