I update the xavier from 32.3 to 32.7.2, and I execute the command ’ sudo nvbootctrl dump-slots-info’.The following is the the output.
Current bootloader slot: B
Active bootloader slot: B
Then in the following process, when I execute ‘sudo nvbootctrl set-active-boot-slot 0’ and reboot,the network is not ok.
“Make sure device boot to Chain A
→ Follow Xavier image-based update from 32.6.1 to 32.7.2 successfully,then to 35.1failed - #22 by carolyuu steps.”
After the upper process, I excute the commanda “sudo nvbootctrl dump-slots-info” and “ifconfig -a”, the following is the output.
*-desktop:~$ sudo nvbootctrl dump-slots-info
**[sudo] password for *: **
Current bootloader slot: A
Active bootloader slot: A
magic:0x43424e00, version: 3 features: 3 num_slots: 2
slot: 0, priority: 15, suffix: _a, retry_count: 7, boot_successful: 1
slot: 1, priority: 14, suffix: _b, retry_count: 7, boot_successful: 1
*-desktop:~$ ifconfig -a
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:37:05:35:7f txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
dummy0: flags=130<BROADCAST,NOARP> mtu 1500
ether f2:3e:59:16:ce:a8 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 4295 bytes 264393 (264.3 KB)
TX packets 4295 bytes 264393 (264.3 KB)
