Hi NVIDIA,
I am attempting to install pytorch and torchvision on the Jetson AGX Xavier by following the post at PyTorch for Jetson
I have tried multiple versions of pytorch and torchvision but never get further then the command python3 setup.py install --user in the torchvision directory.
The error I got included print statements such as ‘cached_cast’ is not a member of ‘at::autocast’, with error: command ‘aarch64-linux-gnu-gcc’ failed with exit status 1’. I would like to print the entire output but now when I do the call only ‘segmentation fault’ or ’ segmentation fault (core dumped)’ is printed.
Do you have an idea what may be going wrong? Thanks in advance!
