I have written a small program, where Ram is being tested by video card and wanted total Memory to allocate, but not at all possible, if can help me?
As a piece of code is:
//Calculate size of allocatable memory
//Allocate device memory
extern "C" __declspec(dllexport) void FSC_cudaMemTest(int device, size_t *errors0, size_t *errorsComp, size_t *allocatedMem, size_t *totalMem)
//Declarations
unsigned char *ptr;
unsigned char value = 0;
unsigned int available = 0,
total = 0;
size_t factor = 0,
size = 0;
dim3 blocks(8, 1, 1),
threads(510, 1, 1);
//Set device
cudaSetDevice(device);
//Get meminfo
FSC_cudaGetMemInfo(&available, &total, device);
//Set factor
factor = (size_t)(total * 0.1);
//Calculate allocatable memory
while(factor > 0)
while(cudaMalloc((void**)&ptr, size += factor) == cudaSuccess)
cudaFree(ptr);
size -= factor;
factor = (size_t)(factor * 0.1);
while (cudaMalloc((void**)&ptr, ++size) == cudaSuccess)
cudaFree(ptr);
//Allocate global memory
CUDA_SAFE_CALL(cudaMalloc((void**)&ptr, --size));
*errors0 = FSC_cudaMemInit(blocks, threads, size, value, ptr);
//Set complement
value = ~value;
*errorsComp = FSC_cudaMemInit(blocks, threads, size, value, ptr);
//Free device memory
cudaFree(ptr);
//Set variables
*totalMem = total;
*allocatedMem = size;
//Reset cudaSetDevice(device)
cudaThreadExit();
Output is total Memory : 1610285056 Bytes
allocated Memory : 1510408192 Bytes
