I don’t know how exactly to allocate memory for a std::vector of a struct that contains pointers. The first two lines of allocation for the d_nodes and the copy of the static memory works well. However when I allocate memory for the pointers inside d_nodes (only for the nodes with triangles) I get segmentation fault.
Thank you in advance,
Rafael Scatena
Error check:
#define CUDA_CHECK(call) \
do { \
cudaError_t err = call; \
if (err != cudaSuccess) { \
fprintf(stderr, "CUDA error in %s at %s:%d: %s\n", \
__FUNCTION__, __FILE__, __LINE__, cudaGetErrorString(err)); \
exit(err); \
} while (0)\
Host struct:
struct OctreeNode {int64_t index; Point Center; double HalfWidth[3]; int64_t ChildIndex[8]; int Level; int TriangleCount; double* p1x; double* p1y; double* p1z; double* p2x; double* p2y; double* p2z; double* p3x; double* p3y; double* p3z; int* Material; int* Body; int64_t* triangle_id;
+ cpu constructor
Device Struct:
struct OctreeNodeGPU {int64_t index; Point Center; double HalfWidth[3]; int64_t ChildIndex[8]; int Level; int TriangleCount; double* p1x; double* p1y; double* p1z; double* p2x; double* p2y; double* p2z; double* p3x; double* p3y; double* p3z; int* Material; int* Body; int64_t* triangle_id;}
Function to allocate memory on the gpu:
__host__ void AllocateAndLaunchOctree(OctreeNodeGPU* &d_nodes, std::vector<OctreeNode>& h_nodes) {
// Allocate memory for the entire OctreeNode array on the device
int numNodes = h_nodes.size();
CUDA_CHECK(cudaMalloc(&d_nodes, numNodes * sizeof(OctreeNodeGPU)));
std::cerr << "Main Node Alloc Ok" << std::endl;
CUDA_CHECK(cudaMemcpy(d_nodes, h_nodes.data(), numNodes * sizeof(OctreeNodeGPU), cudaMemcpyHostToDevice));
std::cerr << "Static Node Alloc Ok: "<< std::endl;
for (int i = 0; i < numNodes; ++i) {
if(h_nodes[i].TriangleCount>0){
std::cerr << "Dynamic Node Alloc Node: "<<i<<" Triangle Count: "<<h_nodes[i].TriangleCount<< std::endl;
// Allocate memory on the GPU for each pointer member of the current node
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p1x), sizeof(double) * h_nodes[i].TriangleCount)); // p1x
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p1y), sizeof(double) * h_nodes[i].TriangleCount)); // p1y
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p1z), sizeof(double) * h_nodes[i].TriangleCount)); // p1z
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p2x), sizeof(double) * h_nodes[i].TriangleCount)); // p2x
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p2y), sizeof(double) * h_nodes[i].TriangleCount)); // p2y
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p2z), sizeof(double) * h_nodes[i].TriangleCount)); // p2z
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p3x), sizeof(double) * h_nodes[i].TriangleCount)); // p3x
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p3y), sizeof(double) * h_nodes[i].TriangleCount)); // p3y
CUDA_CHECK(cudaMalloc(&(d_nodes[i].p3z), sizeof(double) * h_nodes[i].TriangleCount)); // p3z
CUDA_CHECK(cudaMalloc(&(d_nodes[i].Material), sizeof(int) * h_nodes[i].TriangleCount)); // Material
CUDA_CHECK(cudaMalloc(&(d_nodes[i].Body), sizeof(int) * h_nodes[i].TriangleCount)); // Body
CUDA_CHECK(cudaMalloc(&(d_nodes[i].triangle_id), sizeof(int64_t) * h_nodes[i].TriangleCount)); // triangle_id
std::cerr << "Dynamic Allocated Node: "<<i << std::endl;
Error message:
Segmentation Fault (core image dumped)
