Hello ! First of all wish you all a good health amidst this pandemic !
So I came across this problem when I try to run a TF-TRT optimized model in tensorflow 2.3. Model architecture is mobilenet-v2-fpnlite.
The model runs without any errors on a video. But very slowly. FPS count is around 5 or 6.
2021-01-27 07:13:58.631430: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-01-27 07:15:47.595334: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1
2021-01-27 07:15:47.642790: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:47.642967: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1742] Found device 0 with properties:
pciBusID: 0000:00:00.0 name: NVIDIA Tegra X1 computeCapability: 5.3
coreClock: 0.9216GHz coreCount: 1 deviceMemorySize: 3.86GiB deviceMemoryBandwidth: 194.55MiB/s
2021-01-27 07:15:47.643067: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-01-27 07:15:47.849545: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-01-27 07:15:47.949223: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-01-27 07:15:48.078645: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-01-27 07:15:48.258984: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-01-27 07:15:48.352716: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-01-27 07:15:48.357316: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-01-27 07:15:48.357716: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:48.358500: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:48.358734: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1884] Adding visible gpu devices: 0
2021-01-27 07:15:48.399070: W tensorflow/core/platform/profile_utils/cpu_utils.cc:108] Failed to find bogomips or clock in /proc/cpuinfo; cannot determine CPU frequency
2021-01-27 07:15:48.400503: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x27dca4b0 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2021-01-27 07:15:48.400753: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2021-01-27 07:15:48.512299: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:48.512608: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x27db5bc0 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2021-01-27 07:15:48.512668: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): NVIDIA Tegra X1, Compute Capability 5.3
2021-01-27 07:15:48.513217: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:48.513341: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1742] Found device 0 with properties:
2021-01-27 07:15:48.513437: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-01-27 07:15:48.513629: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-01-27 07:15:48.513741: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-01-27 07:15:48.513830: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-01-27 07:15:48.513915: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-01-27 07:15:48.513999: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-01-27 07:15:48.514083: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-01-27 07:15:48.514395: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:48.514645: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:48.514716: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1884] Adding visible gpu devices: 0
2021-01-27 07:15:48.514816: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-01-27 07:15:53.875925: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1283] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-01-27 07:15:53.876114: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1289] 0
2021-01-27 07:15:53.876158: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1302] 0: N
2021-01-27 07:15:53.884393: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:53.884810: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1046] ARM64 does not support NUMA - returning NUMA node zero
2021-01-27 07:15:53.884983: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1428] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 225 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
2021-01-27 07:19:55.611252: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-01-27 07:20:11.239990: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-01-27 07:20:26.029644: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 290.13MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:27.060471: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 798.07MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:27.342806: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 320.70MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:27.432250: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 457.81MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:27.521906: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 473.04MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:27.931603: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 215.05MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:28.007276: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 220.21MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:28.349143: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 220.62MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:28.422506: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 223.28MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-01-27 07:20:28.500687: W tensorflow/core/common_runtime/bfc_allocator.cc:246] Allocator (GPU_0_bfc) ran out of memory trying to allocate 325.33MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
Gtk-Message: 07:20:35.885: Failed to load module "canberra-gtk-module"
Since the amount of memory that it requires is a small(325MB), is there a way to allocate this memory to tensorflow engine ? How can I use the whole 4GB memory?
P.S.:
I know that TF-TRT lags in performance when compared to TensorRT. But due to unavailability of an operator in the current version of TensorRT(7.1.3) I had no choice. (I can retrain the model with PyTorch but unfortunately this is not an option right now.)
