Alphafold2 bug
There seems to be an issue with the alphafold2 container when passing the NIM_PARALLEL_MSA_RUNNERS and NIM_PARALLEL_THREADS_PER_MSA env variables.
The following docker command results in exception when calling the following get operation:
curl -X 'POST' \
    -i \
    "http://localhost:8000/protein-structure/alphafold2/predict-structure-from-sequence"  \
    -H 'accept: application/json' \
    -H 'Content-Type: application/json' \
    -d '{"sequence": "MVLSEGEWQLVLHVWAKVEADVAGHGQDILIRLFKSHPETLEKFDRVKHLKTEAEMKASEDLKKHGVTVLTALGAILKKKGHHEAELKPLAQSHATKHKIPIKYLEFISEAIIHVLHSRHPGNFGADAQGAMNKALELFRKDIAAKYKELGYQG", "databases": ["uniref90", "mgnify", "small_bfd"]}' > output.json
docker run --rm --name alphafold2 --runtime=nvidia     -e NGC_CLI_API_KEY -e NIM_PARALLEL_MSA_RUNNERS=5 -e NIM_PARALLEL_THREADS_PER_MSA=4     -v $LOCAL_NIM_CACHE:/opt/nim/.cache     -p 8000:8000     nvcr.io/nim/deepmind
/alphafold2:1.0.0
Exception:
INFO:     172.17.0.1:45376 - "POST /protein-structure/alphafold2/predict-structure-from-sequence HTTP/1.1" 500 Internal Server Error
ERROR:    Exception in ASGI application
  + Exception Group Traceback (most recent call last):
  |   File "/usr/local/lib/python3.10/dist-packages/starlette/_utils.py", line 87, in collapse_excgroups
  |     yield
  |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/base.py", line 190, in __call__
  |     async with anyio.create_task_group() as task_group:
  |   File "/usr/local/lib/python3.10/dist-packages/anyio/_backends/_asyncio.py", line 680, in __aexit__
  |     raise BaseExceptionGroup(
  | exceptiongroup.ExceptionGroup: unhandled errors in a TaskGroup (1 sub-exception)
  +-+---------------- 1 ----------------
    |   File "/usr/local/lib/python3.10/dist-packages/uvicorn/protocols/http/h11_impl.py", line 407, in run_asgi
    |     result = await app(  # type: ignore[func-returns-value]
    |   File "/usr/local/lib/python3.10/dist-packages/uvicorn/middleware/proxy_headers.py", line 69, in __call__
    |     return await self.app(scope, receive, send)
    |   File "/usr/local/lib/python3.10/dist-packages/fastapi/applications.py", line 1054, in __call__
    |     await super().__call__(scope, receive, send)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/applications.py", line 123, in __call__
    |     await self.middleware_stack(scope, receive, send)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/errors.py", line 186, in __call__
    |     raise exc
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/errors.py", line 164, in __call__
    |     await self.app(scope, receive, _send)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/base.py", line 189, in __call__
    |     with collapse_excgroups():
    |   File "/usr/lib/python3.10/contextlib.py", line 153, in __exit__
    |     self.gen.throw(typ, value, traceback)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/_utils.py", line 93, in collapse_excgroups
    |     raise exc
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/base.py", line 191, in __call__
    |     response = await self.dispatch_func(request, call_next)
    |   File "/usr/local/lib/python3.10/dist-packages/nimlib/nim_inference_api_builder/api.py", line 113, in metrics_middleware
    |     response = await call_next(request)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/base.py", line 165, in call_next
    |     raise app_exc
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/base.py", line 151, in coro
    |     await self.app(scope, receive_or_disconnect, send_no_error)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/middleware/exceptions.py", line 65, in __call__
    |     await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/_exception_handler.py", line 64, in wrapped_app
    |     raise exc
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/_exception_handler.py", line 53, in wrapped_app
    |     await app(scope, receive, sender)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/routing.py", line 756, in __call__
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/routing.py", line 776, in app
    |     await route.handle(scope, receive, send)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/routing.py", line 297, in handle
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/routing.py", line 77, in app
    |     await wrap_app_handling_exceptions(app, request)(scope, receive, send)
    |     raise exc
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/routing.py", line 72, in app
    |     response = await func(request)
    |   File "/usr/local/lib/python3.10/dist-packages/fastapi/routing.py", line 278, in app
    |     raw_response = await run_endpoint_function(
    |   File "/usr/local/lib/python3.10/dist-packages/fastapi/routing.py", line 193, in run_endpoint_function
    |     return await run_in_threadpool(dependant.call, **values)
    |   File "/usr/local/lib/python3.10/dist-packages/starlette/concurrency.py", line 42, in run_in_threadpool
    |     return await anyio.to_thread.run_sync(func, *args)
    |   File "/usr/local/lib/python3.10/dist-packages/anyio/to_thread.py", line 56, in run_sync
    |     return await get_async_backend().run_sync_in_worker_thread(
    |   File "/usr/local/lib/python3.10/dist-packages/anyio/_backends/_asyncio.py", line 2177, in run_sync_in_worker_thread
    |     return await future
    |   File "/usr/local/lib/python3.10/dist-packages/anyio/_backends/_asyncio.py", line 859, in run
    |     result = context.run(func, *args)
    |   File "/opt/inference.py", line 409, in nim_api_post_call_protein_structure_alphafold2_predict_structure_from_sequence_post
    |     alignments_and_templates = self.nim_api_post_call_protein_structure_alphafold2_predict_msa_from_sequence_post(msa_request_body)
    |   File "/opt/inference.py", line 224, in nim_api_post_call_protein_structure_alphafold2_predict_msa_from_sequence_post
    |     dbname_to_alignments = create_alignments(body.sequence,
    |   File "/opt/alphafold2_inference_wrappers.py", line 178, in create_alignments
    |     queue = AsyncWorkQueue(max_workers=n_workers, use_processes=False)
    |   File "/usr/local/lib/python3.10/dist-packages/bia/concurrent/TaskQueue.py", line 17, in __init__
    |     self.executor = concurrent.futures.ThreadPoolExecutor(max_workers=max_workers)
    |   File "/usr/lib/python3.10/concurrent/futures/thread.py", line 143, in __init__
    |     if max_workers <= 0:
    | TypeError: '<=' not supported between instances of 'str' and 'int'
During handling of the above exception, another exception occurred:
    raise exc
    raise exc
    raise app_exc
    raise exc
    raise exc
    return await future
It works fine if the env variables are removed.
Let me know if I’m doing something not right.
Thanks,
Timur
Hi Timur,
Thanks for your interest in BioNeMo and the AlphaFold2 NIM!
I am able to reproduce this behavior, and we’re working on a fix. I will let you know when resolved.
Thanks,
Kris
Hi Kris, any update on that ?
Facing the same Issue
Hi @Kris.NV , I was wondering if this bug has been fixed?
Hi All,
This issue is fixed. Please use the latest Alphafold-2 NIM container with the following tag: nvcr.io/nim/deepmind/alphafold2:latest
Thanks,
Neel
