An explanation of the config.yaml file's trip wire parameters
Hi there,
Regarding the options listed in the emdx-analytics config.yaml file’s trip wire section, I’m a little confused. I will understand more about the trip wire feature if you describe how those parameters work.
tripwire:
latency_reporting_enabled: false
result_retension_window_sec: 60
frame_buffer: 5
pixel_buffer: 15
in_out_algo:
enable: true
time_threshold_ms: 2000
confidence_threshold: 0.7
prediction_frame_sliding_window: 15
prediction_vector_length_threshold: 3
Here is the guide for configuration of emdx-analytics: Deployment Configuration — Metropolis on Jetson documentation 0.1.0 documentation
Let us know if you need kow more parameter.
