Hi
I use AGX Xavier jetpack5.1.1,The kernel generates an NVGPu-related error. Services that depend on the gpu cannot work properly。May I ask what is the reason and how to solve this problem, which has seriously affected our normal use。
nvgpu_error.txt (1.2 MB)
nvmap_alloc_handle: PID 26673: gst-launch-1.0: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.261225] nvgpu: 17000000.gv11b nvgpu_gr_intr_handle_sm_exception:390 [ERR] could not pre-process sm error!
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.261895] nvgpu: 17000000.gv11b gr_intr_handle_exception_interrupts:759 [ERR] set gr exception notifier
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.262326] nvgpu: 17000000.gv11b nvgpu_set_err_notifier_locked:149 [ERR] error notifier set to 13 for ch 501
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.262970] gv11b Channel Status - chip gv11b
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.262974] gv11b ---------------------------
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.263195] gv11b 496-gv11b, TSG: 7, pid 26673, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.263388] gv11b channel status: in use idle not busy
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.263758] gv11b RAMFC: TOP: 000000000000 PUT: 0002009703a4 GET: 0002009703a4 FETCH: 0202009703a4 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.263983] gv11b
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.264734] gv11b 497-gv11b, TSG: 7, pid 26673, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.265139] gv11b channel status: in use idle not busy
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.266743] gv11b RAMFC: TOP: 000000000000 PUT: 000200874218 GET: 000200874218 FETCH: 020200874218 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 000201187fb4 payload 000000000004e5a6 execute 00001003
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.267492] gv11b
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.279572] gv11b 498-gv11b, TSG: 6, pid 26673, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.282071] gv11b channel status: in use idle not busy
Feb 20 15:41:44 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.291500] gv11b RAMFC: TOP: 000000000000 PUT: 00020077acd4 GET: 00020077acd4 FETCH: 02020077acd4 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 002000411000 payload 000000000014ee1a execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.296871] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.315563] gv11b 499-gv11b, TSG: 6, pid 26673, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.318040] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327421] gv11b RAMFC: TOP: 000000000000 PUT: 00020067b824 GET: 00020067b824 FETCH: 02020067b824 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 00200040d000 payload 000000000014ee1d execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327911] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327920] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327927] tegra194-vi5 15c10000.vi: IVC control submit failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327981] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327993] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.327996] tegra194-vi5 15c10000.vi: IVC control submit failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.328000] tegra194-vi5 15c10000.vi: csi_stream_release: failed to disable nvcsi tpg on stream 4 virtual channel 1
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333125] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333137] gv11b 500-gv11b, TSG: 6, pid 26673, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333828] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333834] tegra194-vi5 15c10000.vi: IVC control submit failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333926] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333939] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333942] tegra194-vi5 15c10000.vi: IVC control submit failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.333946] tegra194-vi5 15c10000.vi: csi_stream_release: failed to disable nvcsi tpg on stream 5 virtual channel 1
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.351401] tegra194-vi5 15c10000.vi: IVC control submit failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.351510] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.360101] gv11b channel status: in use on_pbdma_and_eng busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.368563] tegra-capture-ivc bc00000.rtcpu:ivc-bus:ivccontrol@3: tegra_ivc_write: error -512
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.374642] gv11b RAMFC: TOP: 000000000000 PUT: 00020055b5e4 GET: 00020055b5e4 FETCH: 02020055b5e4 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 002000405000 payload 000000000014ee1c execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.381739] tegra194-vi5 15c10000.vi: IVC control submit failed
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.381748] tegra194-vi5 15c10000.vi: csi_stream_release: failed to disable nvcsi tpg on stream 2 virtual channel 1
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.527996] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.528008] gv11b 501-gv11b, TSG: 6, pid 26673, refs: 4, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.530580] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.539946] gv11b RAMFC: TOP: 000000000000 PUT: 000200468180 GET: 000200468180 FETCH: 020200468180 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 002000402000 payload 00000000001237e0 execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.545586] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.564117] gv11b 502-gv11b, TSG: 5, pid 13240, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.566697] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.576210] gv11b RAMFC: TOP: 000000000000 PUT: 000200970020 GET: 000200970020 FETCH: 020200970020 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 000000000000 payload 0000000000000000 execute 00000000
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.581746] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.600145] gv11b 503-gv11b, TSG: 5, pid 13240, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.602766] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.612164] gv11b RAMFC: TOP: 000000000000 PUT: 00020087441c GET: 00020087441c FETCH: 02020087441c HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 000201187f8c payload 000000000000234e execute 00001003
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.617815] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.636113] gv11b 504-gv11b, TSG: 4, pid 13240, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.638713] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.648058] gv11b RAMFC: TOP: 000000000000 PUT: 000200777aec GET: 000200777aec FETCH: 020200777aec HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 002000411000 payload 000000000004326b execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.653773] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.672073] gv11b 505-gv11b, TSG: 4, pid 13240, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.674679] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.684018] gv11b RAMFC: TOP: 000000000000 PUT: 000200677cb4 GET: 000200677cb4 FETCH: 020200677cb4 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 00200040d000 payload 0000000000042a42 execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.689738] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.708040] gv11b 506-gv11b, TSG: 4, pid 13240, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.710670] gv11b channel status: in use pending busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.719939] gv11b RAMFC: TOP: 000000000000 PUT: 000200557a74 GET: 000200557a74 FETCH: 020200557a74 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 002000405000 payload 00000000000029de execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.725448] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.743793] gv11b 507-gv11b, TSG: 4, pid 13240, refs: 2, deterministic: yes, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.746338] gv11b channel status: in use pending busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.755652] gv11b RAMFC: TOP: 000000000000 PUT: 0002004ff238 GET: 0002004ff238 FETCH: 0202004ff238 HEADER: 60400000 COUNT: 84000000 SEMAPHORE: addr 000201187fa4 payload 000000000000235a execute 00000003
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.761134] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.779492] gv11b 508-gv11b, TSG: 3, pid 5917, refs: 2, deterministic: no, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.782031] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.791505] gv11b RAMFC: TOP: 80000020004100a0 PUT: 0020004100a0 GET: 0020004100a0 FETCH: 0020004100a0 HEADER: 60400000 COUNT: 80000000 SEMAPHORE: addr 002000408000 payload 0000000000000000 execute 00100001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.797262] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.815872] gv11b 509-gv11b, TSG: 2, pid 4397, refs: 2, deterministic: no, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.818425] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.827902] gv11b RAMFC: TOP: 8000002000410168 PUT: 002000410168 GET: 002000410168 FETCH: 002000410168 HEADER: 60400000 COUNT: 80000000 SEMAPHORE: addr 002000408000 payload 0000000000000000 execute 00100001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.833660] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.852277] gv11b 510-gv11b, TSG: 1, pid 2673, refs: 2, deterministic: no, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.854853] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.863976] gv11b RAMFC: TOP: 8000002000429208 PUT: 002000429208 GET: 002000429208 FETCH: 002000429208 HEADER: 60400000 COUNT: 80000000 SEMAPHORE: addr 002000428000 payload 0000000000000000 execute 00000001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.869727] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.888406] gv11b 511-gv11b, TSG: 0, pid 2673, refs: 2, deterministic: no, domain name: (default)
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.890968] gv11b channel status: in use idle not busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.900114] gv11b RAMFC: TOP: 800000200044aaa0 PUT: 00200044aaa0 GET: 00200044aaa0 FETCH: 00200044aaa0 HEADER: 60400000 COUNT: 80000000 SEMAPHORE: addr 002000420000 payload 0000000000000000 execute 00100001
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.905851] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.924554] gv11b PBDMA Status - chip gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.927110] gv11b -------------------------
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.931674] gv11b pbdma 0:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.936226] gv11b id: -1 - [channel] next_id: - -1 [channel] | status: invalid
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.939385] gv11b PBDMA_PUT 00000020004100a0 PBDMA_GET 00000020004100a0
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.947288] gv11b GP_PUT 00000012 GP_GET 00000012 FETCH 00000012 HEADER 60400000
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.954514] gv11b HDR 00000000 SHADOW0 00a00484 SHADOW1 00140800
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.962997] gv11b pbdma 1:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.970169] gv11b id: 4 - [tsg] next_id: - -1 [channel] | status: valid
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.973114] gv11b PBDMA_PUT 00000002004ff5e0 PBDMA_GET 00000002004ff260
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.980802] gv11b GP_PUT 00000224 GP_GET 00000224 FETCH 00000224 HEADER 201101b0
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.988108] gv11b HDR 2001206c SHADOW0 004ff238 SHADOW1 0003aa02
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 997.996524] gv11b pbdma 2:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.003536] gv11b id: 5 - [tsg] next_id: - -1 [channel] | status: valid
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.006560] gv11b PBDMA_PUT 0000000200874494 PBDMA_GET 0000000200874494
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.014151] gv11b GP_PUT 000000bf GP_GET 000000bf FETCH 000000bf HEADER 60400000
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.021265] gv11b HDR 00000000 SHADOW0 00874458 SHADOW1 00003e02
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.029920] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.037186] gv11b gv11b eng 0:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.039719] gv11b id: 6 (tsg), next_id: 4 (tsg), ctx status: switch
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.043461] gv11b busy
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.050153] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.053000] gv11b gv11b eng 1:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.055500] gv11b id: 5 (tsg), next_id: -1 (channel), ctx status: valid
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.059148] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.066257] gv11b gv11b eng 2:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.068824] gv11b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.072439] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.080207] gv11b gv11b eng 3:
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.082774] gv11b id: -1 (channel), next_id: -1 (channel), ctx status: invalid
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.086438] gv11b ctx_reload
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.094143] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.097525] gv11b
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.105856] nvgpu: 17000000.gv11b nvgpu_report_err_to_sdl:66 [ERR] Failed to report an error: hw_unit_id = 0x9, err_id=0x8, ss_err_id = 0x289
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.116277] nvgpu: 17000000.gv11b gv11b_mm_mmu_fault_handle_buf_valid_entry:525 [ERR] page fault error: err_type = 0x8, fault_status = 0x200
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.128657] nvgpu: 17000000.gv11b gv11b_fb_mmu_fault_info_dump:294 [ERR] [MMU FAULT] mmu engine id: 65, ch id: 501, fault addr: 0x0, fault addr aperture: 0, fault type: invalid pde, access type: virt read,
Feb 20 15:41:45 mxvlkica-qthdaa-4-dcu1 kernel: [ 998.147588] nvgpu: 17000000.gv11b gv11b_fb_mmu_fault_info_dump:307 [ERR] [MMU FAULT] protected mode: 0, client type: gpc, client id: t1 1, gpc id if client type is gpc: 0,
Feb 20 15:41:58 mxvlkica-qthdaa-4-dcu1 kernel: [ 1010.637101] nvmap_alloc_handle: PID 71865: gst-launch-1.0: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
Feb 20 16:11:22 mxvlkica-qthdaa-4-dcu1 kernel: [ 2774.759891] nvgpu: 17000000.gv11b nvgpu_gr_intr_handle_sm_exception:390 [ERR] could not pre-process sm error!
Feb 20 16:11:22 mxvlkica-qthdaa-4-dcu1 kernel: [ 2774.760368] nvgpu: 17000000.gv11b gr_intr_handle_exception_interrupts:759 [ERR] set gr exception notifier
Feb 20 16:11:22 mxvlkica-qthdaa-4-dcu1 kernel: [ 2774.760791] nvgpu: 17000000.gv11b nvgpu_set_err_notifier_locked:149 [ERR] error notifier set to 13 for ch
