This library decodes JPEG images to RGB, either on the GPU or on the CPU.
For JPEGs that contain restart intervals, also the huffman decoding is done in parallel on the GPU, which can boost performance a lot.
HI:
guys,I use cujpeg lib for deoceing multiframe files which is constructed by jpegs picture,but i find cujpeg_decode() spend mush time as 140ms, in my programms,code like this:
while(av_read_frame(pFormatCtx, &packet)>=0)
// use avcodec to parser a frame from XXX.mjpg
if(packet.stream_index==videoStream)
KrojamSoft PhotoViewerPro is great to view all images within a folder . You can organize and view/edit images. View images on a calendar etc.Try it out
