Any resource tells about instruction cache?
Any one can help to recommend readings that tells about instruction cache?
Thanks,
Susan
Old, but presumably not too much has changed since:
Demystifying GPU Microarchitecture through Microbenchmarking
Cool! Thank you!
Susan
One more to confirm, Are warps blocked at barrier are not considered for instruction fetching? I saw following statement in the paper: “Effect of instruction fetch and memory scheduling on GPU performance” http://comparch.gatech.edu/hparch/gputhread.pdf
“Warps that are blocked at
a barrier, are waiting for loads/stores to complete, or are waiting
for a branch to be resolved are not considered for fetching.”
Thanks,
Susan
Note the statement you are citing from the paper is a description of the simulated architecture, not necessarily of any actual Nvidia card.
I would believe that, due to the pipelined nature of instruction execution, in actual Nvidia cards blocked warps can have a handful of follow-up instructions fetched. This is due to the fact that at the time of instruction fetch it is not even known whether a warp is blocked or not.
