Many of you are using free tier API access to NVIDIA NIMs. This usually involves a rate limit that is dependent on model, use-case and the amount of current overall traffic using the same access.
There is no official way to circumvent this rate limit or to receive a rate limit increase on that same tier.
And specifically here on the forums we do not have any influence on those rate limits.
To make full use of a NIM blueprint you will need to deploy it.
For more details on NVIDIA NIM refer to the official pages at NVIDIA NIM Microservices for AI Inference and read the FAQ.
Any further posts asking for rate limit increases might be considered Spam.
Thank you for your reply, but respectfully, it does not address any of the real problems.
The core issue is not “bypassing limits”, but whether the limits are reasonable.
40 RPM might be sufficient for simple tests, but for real development scenarios like Claude Code – which requires multiple tool calls – the limit is hit almost instantly. We are not trying to “abuse” free resources; we simply want to complete a single realistic task (e.g., write code → compile → debug → fix) within a reasonable limit.
“Deploy a blueprint” is unrealistic for individual developers.
What you call “deploying a NIM blueprint” implies high hardware costs and operational burdens that individual developers simply cannot bear. Is the NVIDIA free tier only meant for “Hello World”-level toys?
Community feedback is being treated as a “spam” threat.
The last sentence of your reply – “Any further posts asking for rate limit increases might be considered Spam” – essentially silences genuine user voices. We post because we encounter real problems, not to harass anyone. This attitude runs counter to NVIDIA’s “developer-first” mantra.
My request is very simple:
Please clearly state: is there any feasible way for an individual developer to stably use the NIM free tier in real-world projects without self-hosting a blueprint?
If not, please honestly admit that “the free tier is not suitable for serious development” instead of brushing us off with boilerplate responses.
We are looking for a sincere solution, not bureaucratic talk.
Hi there @ponpong.
Thank you for your honest feedback!
I really appreciate posts like yours because they show there is a real person behind the request.
The response above is aimed at the at least 10-20 automated requests for rate limit increases we see across the forums per day. They are created by AI agents or through AI Chat assistance simply because AI Web search found the initial requests here on the forums.
These forums do not support the build.nvidia.com technical offerings, simply because we don’t have the personnel to do so. That is also the reason why I cannot answer your request. That is part of the build.nvidia.com communications.
And I sincerely do not want to brush you off; I can assure you that the team is aware of the implications of the 40 rpm rate limit. There are internal discussions going on to find ways to handle this on a bigger scale. But that is all I am aware of at this time.
I know this is not what you asked for; at the same time, it hopefully clarifies the situation.
Hi there
Thank you for taking the time to write back personally.
I appreciate that you acknowledged my request came from a real person, not a bot. I also understand that your hands are tied – the forums simply aren’t set up to handle build.nvidia.com technical issues, and you don’t have the personnel. That’s not your fault.
What I truly respect is that you lowered the “arrogant” stance (which I called out) and gave me a sincere, human apology. You didn’t hide behind a template. You admitted the limit is known, internal discussions are ongoing, but there’s no solution for me right now. That honesty means a lot.
So, apology accepted. No hard feelings toward you personally.
That said, as a developer trying to build an automated AI coding assistant on limited hardware, the 40 RPM limit remains a real blocker. I hope NVIDIA’s internal discussions lead to a practical free tier or at least a clear roadmap for indie developers and small teams – not just enterprise customers.
Until then, I’ll move forward with alternative tech stacks. But I’ll keep an eye on NVIDIA’s progress.
Thanks again for being a decent human in a frustrating situation.
Best,
ponpong
Hey guys,
I am on the same boat.
Keen to find a solution here… Loving the models but just need slightly bigger rates to fully test.
Cheers
Godsped
