Hi.
I’m facing trouble to use torch2trt. When I run this code, it will stop.
code
model=torchvision.models.efficientnet_v2_s(weights=weights)
model.eval()
model=model.to(device)
model_trt=torch2trt(model, ,fp16_mode=True,int8_mode=True,max_batch_size=1)
result
[TRT] [E] 3: [builderConfig.cpp::canRunOnDLA::493] Error Code 3: API Usage Error (Parameter check failed at: optimizer/api/builderConfig.cpp::canRunOnDLA::493, condition: dlaEngineCount > 0)
I guess torch2trt or tensorRT try to use DLA which Orin nano doesn’t have.
How can I set “No use DLA”?
Thank you for your time.
Environment
TensorRT Version : 8.5.2.2
GPU Type : Jetson Orin Nano (Developer kit)
Nvidia Driver Version : JetPack 5.1.1
CUDA Version : 11.4.315
CUDNN Version : 8.6.0
Operating System + Version : JetPack 5.1.1
Python Version (if applicable) : 3.8.10
PyTorch Version (if applicable) : 2.0.0+nv23.5
**torch2trt Version **: 0.4.0
Please use dla=False when calling torch_trt:
Below is a related topic for your reference:
We are trying to convert model to TensorRT.
But it is failed with the error as below :
[image]
We set like this
=> torch2trt option : dla=True, max_workspace_size=1GB
But it looks it doesn’t apply.
The conversion process is killed but we can get the output.
This output works and inferencing time is half than before conversion.
Thank you for your support.
I added dla=False but same error appears.
model_trt=torch2trt(model, ,fp16_mode=True,int8_mode=True,max_batch_size=1,dla=False)
Did I add at the wrong place?
What is the device_types value in your use case?
max_workspace_size=1<<25,
strict_type_constraints=False,
keep_network=True,
int8_mode=False,
int8_calib_dataset=None,
int8_calib_algorithm=DEFAULT_CALIBRATION_ALGORITHM,
use_onnx=False,
default_device_type=trt.DeviceType.GPU,
dla_core=0,
gpu_fallback=True,
device_types={},
min_shapes=None,
max_shapes=None,
opt_shapes=None,
onnx_opset=None,
max_batch_size=None,
avg_timing_iterations=None,
**kwargs):
# capture arguments to provide to context
kwargs.update(locals())
I’m sorry. I didn’t get what you mean because of lacking knowledge.
How can I check the device_types value?
Thank you.
You can find some info in the below link:
NVIDIA-AI-IOT:master ← jaybdub:dla_support
opened 02:28AM - 25 Feb 21 UTC
This PR enables DLA support through torch2trt. Please note this is subject to c… hange.
### Todo
- [x] concurrent model execution profiling (DLA should free up GPU, also there are two DLAs)
- [x] 2 model GPU 0 model DLA
- [x] 1 model GPU 1 model DLA
- [x] 0 model GPU 2 model DLA
- [x] increment version to enable backtracking to legacy conversion
- [x] update documentation with DLA instructions / benchmarks
- [ ] sanity check models on imagenet data
### Basic usage
This will enable DLA usage globally by setting the default device type. If a particular layer is not supported by DLA, it will fall back to GPU unless ``gpu_fallback=False`` is set (it is True by default). Please note, either ``fp16_mode=True`` or ``int8_mode=True`` are required for DLA.
```python
import torch
from torch2trt import trt, torch2trt
from torchvision.models import resnet18
model = resnet18(pretrained=True).cuda().eval()
data = torch.randn(1, 3, 224, 224).cuda()
model_trt = torch2trt(model, [data], fp16_mode=True, default_device_type=trt.DeviceType.DLA, dla_core=0)
### Set device for particular modules
In some cases you may want only a particular part of the model to run on DLA. This may be useful if your model has a large block that can run on DLA, but other parts with mixed supported / unsupported components which may occur overhead cost. This is done at a module-level granularity. Each lower-level set will override a higher level module, but only apply to layers added within the module.
For example, here we convert the resnet18 blocks ``layer1`` and ``layer2`` and the first block in ``layer3`` to run on DLA.
```python
model_trt = torch2trt(model, [data], default_device_type=trt.DeviceType.GPU, fp16_mode=True, dla_core=0, device_types={
model.layer1: trt.DeviceType.DLA,
model.layer2: trt.DeviceType.DLA,
model.layer3[0]: trt.DeviceType.DLA
You could do the inverse of this if you wanted.
```python
model_trt = torch2trt(model, [data], default_device_type=trt.DeviceType.DLA, fp16_mode=True, device_types={
model.layer1: trt.DeviceType.GPU,
model.layer2: trt.DeviceType.GPU,
model.layer3[0]: trt.DeviceType.GPU
In any instance, a DLA layer will run on GPU if ``gpu_fallback=True``. If you would prefer to disable this behavior, you can set ``gpu_fallback=False``, but TensorRT optimization may fail internally.
TODO
- validate existing test cases. may be cool to log DLA supported layers https://nvidia-ai-iot.github.io/torch2trt/master/converters.html
- perform sanity checks on real world model / data
Could you try if the following command can work?
model_trt = torch2trt(model, [data], default_device_type=trt.DeviceType.GPU, fp16_mode=True, ...)
import torch
from torch2trt import torch2trt,trt
import torchvision
device='cuda'
weights=torchvision.models.segmentation.FCN_ResNet50_Weights.DEFAULT
model=torchvision.models.segmentation.fcn_resnet50(weights=weights).to(device).eval()
input_size=[1,3,256,256]
x=torch.zeros(input_size).to(device)
model_trt=torch2trt(model,[x],default_device_type=trt.DeviceType.GPU, fp16_mode=True,int8_mode=True,max_batch_size=1,dla=False)
It doesn’t work. Same error occurred.
Thank you.
Thanks for the feedback.
We are checking this issue internally.
Will share more information with you later.
We are trying to reproduce this issue in our environment.
It seems that you have installed torch2trt on JetPack 5.x.
Could you share how do you install it?
We got another topic that reporting the tool is not working on JetPack 5.
I’m trying to install torch_tensorrt at the Orin.
But now, I get errors.
Could you advice about it?
cat /etc/nv_tegra_release
# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
JetPack : 5.1.1
Docker image : nvcr.io/nvidia/l4t-jetpack:r35.3.1
Originally, torch_tensorrt is support until Jetpack 5.0.
I checked it by below codes.
py/setup.py
python3 setup.py bdist_wheel --jetpack-version 5.0 --use-cxx11-abi
Originally, I wan…
Sorry for late reply. I installed tensorRT and torch2trt by following way.
sudo dpkg -i nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb
sudo cp /var/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4/* -keyring.gpg /usr/share/keyrings/
sudo apt-get update
sudo apt-get install tensorrt
sudo apt-get install python3-libnvinfer-dev
git clone https://github.com/NVIDIA-AI-IOT/torch2trt
cd torch2trt
sudo python3 setup.py install
