ojaswa
April 10, 2009, 11:55pm
1
In my application, I need a variable number of texture references (number ‘n’ specified by user at runtime). Like this:
texture<float, 3, cudaReadModeElementType> *texrefs;
texrefs = (texture<float, 3, cudaReadModeElementType> *) malloc(n*sizeof(texture<float, 3, cudaReadModeElementType>));
A dynamic array for that purpose is good. Is it possible to do it and how do I access the texrefs inside a kernel?
Every member of the texref will be bound to its own cudaArray.
I’m fine even if it is somehow possible to unbind/bind to different cudaArrays inside a kernel to a single texref, but I don’t think that’s possible.
Any suggestion will be highly appreciated.
-Oj
ojaswa
April 10, 2009, 11:57pm
2
http://forums.nvidia.com/index.php?showtopic=80654
Says that it is not possible. Is it still the case with cuda 2.1? Do I have any option then?
-Oj
-Oj
Yes, this is a hardware limitation (fixed in DirectX 11, btw).
Your options are:
use a switch statement like in the other thread
use a 3D texture
ojaswa
April 14, 2009, 2:12pm
4
Thanks for reply. In fact I needed an array of 3D tex references.
-Oj
Sorry, missed that. Unfortunately we don’t have 4D textures. Yet!
ojaswa
April 14, 2009, 3:15pm
6
The number of texture units is dependent on the hardware. Is there any limitation on number of 3D textures that can be simultaneously used in CUDA (did I miss that in the CUDA manuals anywhere??)? or is it again the same as the hardware limit?
I should then query CUDA to return me that limit? Is there an API for that?
ojaswa
April 14, 2009, 4:15pm
7
As a side note, I just checked on my card (8600 M GT that supports 4 tex units) that I could use 5 texture references bound to 5 cudaArrays at the same time in a kernel!
Did I understand something wrong here??
ojaswa
April 14, 2009, 4:32pm
8
I think I have a clue of what to do.
I can concatenate my 3D textures for form a larger (rather longer) 3D texture and kinda emulate a 4D texture!
(http://forums.nvidia.com/index.php?showtopic=44424 )
Thanks Simon for the info.
-Oj
Yes, packing multiple textures into a larger texture atlas is a good solution if this works for you.
BTW, I don’t see it documented anywhere, but I believe CUDA supports up to 16 texture references.
