Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
Description
trtexec couldn’t find my Layernorm plugin when I was building the engine.
trtexec --explicitBatch --plugins=LayerNormPlugin.so --minShapes=hyps_pad_sos_eos:1x10x64,encoder_out:1x16x256,encoder_out_lens:1,hyps_lens_sos:1x10,ctc_score:1x10 --optShapes=hyps_pad_sos_eos:4x10x64,encoder_out:4x64x256,encoder_out_lens:4,hyps_lens_sos:4x10,ctc_score:4x10 --maxShapes=hyps_pad_sos_eos:64x10x64,encoder_out:64x256x256,encoder_out_lens:64,hyps_lens_sos:64x10,ctc_score:64x10 --onnx=decoder-surgeon.onnx --saveEngine=decoder.plan
Environment
TensorRT Version: 8.2
GPU Type: T4
Nvidia Driver Version: 470
CUDA Version: 11.4
Please refer to below links related custom plugin implementation and sample:
While IPluginV2 and IPluginV2Ext interfaces are still supported for backward compatibility with TensorRT 5.1 and 6.0.x respectively, however, we recommend that you write new plugins or refactor existing ones to target the IPluginV2DynamicExt or IPluginV2IOExt interfaces instead.
