[ASUS Ascent GX10 / DGX Spark] Permanent Power Throttle at 30W (Safety Mode) - PD Firmware Negotiation Failure
System Information:
  • Hardware: ASUS Ascent GX10 (DGX Spark)
  • OS: NVIDIA DGX OS 7.2.3 (Base) updated to latest Kernel
  • BIOS Version: 0102
  • EC Version: 2.75.3.3
  • TPM Status: Enabled (SHA384 Bank Active, /dev/tpm0 visible)
Issue Description: The system is permanently stuck in Hardware Safety Mode, capping the total power draw at ~30W regardless of the workload. GPU temperatures never exceed 55°C under full synthetic load (gpu-burn or PyTorch GEMM). Despite connecting the 240W Power Adapter to the correct PD-IN port, the Power Delivery controller seems unable to negotiate the High Power state (20V/5A+ or 28V).
I just found conclusive evidence in dmesg showing that not only the GPU, but the entire PCIe subsystem is power-starved. The Mellanox (mlx5) network controllers are reporting “insufficient power” and seem capped around 27W, which aligns perfectly with the total system draw of ~30W I am observing.
**Does this log confirm that the PMIC (Power Management IC) is actively restricting the entire main rail due to the PD negotiation failure?
hasan@gx10-4b66:~/Documents/ft_qwen3_vl$ sudo dmesg | grep -iE “limit|throttle|power”
[ 1.107646] pci 000f:01:00.0: 0.000 Gb/s available PCIe bandwidth, limited by Unknown x0 link at 000f:00:00.0
[ 2.555611] mlx5_core 0000:01:00.0: mlx5_pcie_event:326:(pid 165): Detected insufficient power on the PCIe slot (27W).
[ 3.031528] mlx5_core 0000:01:00.1: mlx5_pcie_event:326:(pid 12): Detected insufficient power on the PCIe slot (27W).
[ 3.509043] mlx5_core 0002:01:00.0: mlx5_pcie_event:326:(pid 396): Detected insufficient power on the PCIe slot (27W).
[ 3.983977] mlx5_core 0002:01:00.1: mlx5_pcie_event:326:(pid 12): Detected insufficient power on the PCIe slot (27W).
Have you tried to ensure all the firmwares are up to date?
See - ASUS Ascent GX10|Desktop AI supercomputer|ASUS USA and instructions on how to update here https://www.asus.com/us/support/faq/1056213/
I found that I had to manually install the firmware - NB: you have to flash PD firmware twice as noted in the instructions.
Yes I have followed those instructions to the letter.
I created the bootable USB as required and updated the OS to the latest version available. Regarding the firmware I strictly adhered to the ASUS guide including the specific ‘Double Flash’ procedure for the PD controller (Flash → Reboot → Flash → Reboot) to ensure both EEPROMs were updated.
Despite strictly following this exact protocol the system remains stuck in safety mode.
As this is ASUS GB10 unit, recommend you reachout to ASUS support for a replacement / RMA
