Asynchronous performance between CPU and GPU
Hi all,
I’m currently working on performance regarding asynchronous mechanism between 1 GPU and 1 CPU.
Goal is to increase time performance by using CPU processing while GPU is working.
Here is how it works:
* CPU send datas_1 regarding a kernel on the GPU
* CPU ask GPU to execute this kernel
* while kernel is beeing processed with datas_1, CPU is sending datas_2 in order to be process by the kernel.
Problem is that I get low performance.
Indeed, the total time of execution is almost the same as data transfer time + kernel execution.
(If data transfer + kernel execution are asynchronous, the total time should be shorter(?))
Do you have any solutions to make a real asynchronous execution?
Did anymore make tests regarding this scope: 1 GPU/ 1 CPU? did you came to the same results?
Is this conclusion correct?
Could you post some code?
Currently, to realise my asynchronous program, I initialize two arrays (h_A and h_B) which include N matrix (of size MxM).
After that, I make an asynchronous (with overlapping) system which :
  • load datas from CPU to GPU : only one matrix A(MxM) (a piece of h_A) and one matrix B(MxM) (a piece of h_B)
  • execute a kernel on GPU (for those matrix)
  • return result on CPU
I execute “M” times this system.
Here is my code:
// setup execution parameters
dim3 threads(BLOCK_SIZE, BLOCK_SIZE);
dim3 grid(N / threads.x, N / threads.y);
cudaStream_t stream[nb_iter];
cudaEvent_t start;
cudaEvent_t stop;
float elapsed;
for(int i=0; i<nb_iter; i++){
  cudaStreamCreate(&stream[i]);
cudaEventCreate(&start);
cudaEventCreate(&stop);
//allocate host memory
float *h_A = tabMatrixAlloc( N, nb_iter );
float* h_B = tabMatrixAlloc( N, nb_iter );
float* h_C = tabMatrixAlloc( N, nb_iter );
//allocate device memory
float* d_A, *d_B, *d_C;
cudaMalloc((void**) &d_A, getMatrixSize(N)*nb_iter);
cudaMalloc((void**) &d_B, getMatrixSize(N)*nb_iter);
cudaMalloc((void**) &d_C, getMatrixSize(N)*nb_iter);
tabMatrixInit(h_A, N, nb_iter);
  tabMatrixInit(h_B, N, nb_iter);
cudaEventRecord(start);
  for (int var = 0; var < nb_iter; ++var) {
        cudaMemcpyAsync(getMatrix( d_A, N, var), getMatrix( h_A, N, var), getMatrixSize(N), cudaMemcpyHostToDevice ,stream[var]);
        cudaMemcpyAsync(getMatrix( d_B, N, var), getMatrix( h_B, N, var), getMatrixSize(N), cudaMemcpyHostToDevice ,stream[var]);
        matrixMul<<<grid, threads, 0 ,stream[var]>>>(getMatrix( d_C, N, var), getMatrix( d_A, N, var), getMatrix( d_B, N, var), N);
        cudaMemcpyAsync(getMatrix( h_C, N, var), getMatrix( d_C, N, var), getMatrixSize(N), cudaMemcpyDeviceToHost ,stream[var]);
  cudaEventRecord(stop);
  cudaEventSynchronize(stop);
  cudaEventElapsedTime(&elapsed,start,stop);
  // clean up memory
free(h_A);free(h_B);free(h_C);
cudaFree(d_A);cudaFree(d_B);cudaFree(d_C);
cudaEventDestroy(start); cudaEventDestroy(stop);
//Destroy Stream
for(int i=0; i<nb_iter; i++){cudaStreamDestroy(stream[i]);}
//Reset du gpu
cudaDeviceReset();
return elapsed;
FYI:
getMatrix() : create a matrix from a table
getMatrixSize(): return the matrix size
check out slides 21 and 22…
if you are working on a fermi device this could be your problem. Easy to test by changing to depth first issuing. Streams and performance optimization is sometimes a tricky topic…
