I have a question regarding asynchronous triggering of the image sensor and receiving that triggered frame.
Is it possible to adjust syncpoint of SOF on VI->ISP path? I’m using argus_camera sample app and I got timeouts when the trigger is apart more than 1500ms.
I assume this timeout passed for syncpoint is hardcoded like the VI->EMC path in vi4_fops.c
[ 679.262817] fence timeout on [ffffffc18e47a600] after 1500ms
[ 679.269084] name=[nvhost_sync:44], current value=1 waiting value=2
[ 679.275465] ---- mlocks ----
[ 679.278443] 8: locked by channel 6
[ 679.282733] fence timeout on [ffffffc05ea15800] after 1500ms
[ 679.282740] name=[nvhost_sync:29], current value=119559 waiting value=119560
[ 679.282744] ---- mlocks ----
[ 679.282756] 8: locked by channel 6
[ 679.282770] fence timeout on [ffffffc05ea15400] after 1500ms
Can you point me to source files for configuring VI->ISP path, because almost everything is bypassed in vi driver (vi4_fops.c)
hi JerryChang,
thank you for the reply.
- There are different use-cases. For example, when sensor is in master mode you can have longer frame length or longer exposure time, while when sensor is working in slave mode you can have a HW that triggers sensor for a frame.
Simple example. You want to capture cars that are passing by. So, HW that registers a car will trigger image sensor to output a frame (or few). Cars can come by every few seconds/days, you never know.
So the problem is you can’t recover from the timeout without a source code and few workarounds.
Could you please tell me more about VI GPIO functionality. First, GPIO pins VGP1-VGP6 are they connected to a camera connector? Searching the VGP1 pin in TX2-Pinmux-Template results in GPIO_CAM1, VGP2 in GPIO_CAM2 respectively for others.
What is the logic behind generating a series of 128 PWM pulses?
How are sync points incremented? for example SOF.
hello d.kristofic,
you cannot just power-on camera sensor and forced it only output frames when event triggered.
assume you would like to capture sensor frames with some specific condition, there are two approaches for your use-case.
- keep camera steaming, you only handling the image buffer with HW events, ignore rest of image buffers.
- launch camera to capture all frames only when event triggered.
you may refer to below kernel sources about gpio controls,
<top>/kernel/kernel-4.4/drivers/media/i2c/ov5693.c
<top>/kernel_src/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-camera-e3333-a00.dtsi
please refer to below sources for TX2’s VI drivers, please check nvhost_syncpt_wait_timeout_ext() for the syncpt incremented.
<top>/kernel/kernel-4.4/drivers/media/platform/tegra/camera/vi/vi4_fops.c
