atomiccas usage
Hi all,
I have troubles using the function atomiccas as suggested in the book by Ruetsch and Fatica. Here is my code:
module test
implicit none
integer(kind=4),device::lock
contains
attributes(global) subroutine adds(a_d,asum_d,lock)
implicit none
real(kind=8),device::a_d(:),asum_d
integer n
n=threadidx%x+(blockidx%x-1)*blockDim%x
do while(atomiccas(lock,0,1)==1) ! set lock
end do
asum_d=asum_d+a_d(n)
call threadfence()
lock=0 ! release lock
end subroutine
end module
program test2
use cudafor
use test
implicit none
real(kind=8),allocatable::a(:)
real(kind=8),allocatable,device::a_d(:)
real(kind=8),device::asum_d
real(kind=8)::asum
integer n,j
n=1024
lock=0
allocate(a(n),a_d(n))
do j=1,n
   a(j)=1.0d0*j
end do
a_d=a
asum_d=0.0d0
call adds<<<(n-1)/32+1,32>>>(a_d,asum_d,lock)
istat=cudaDeviceSynchronize()
asum=asum_d
print*,asum
end
But when I compile and run this simple code, it never finishes, just hanging there.
Can you tell me what’s wrong?
Thanks,
Lam
Hi Lam,
I found a good explanation of the issue:
Basically, you can have only one thread in the block enter the critical section. Given that all threads in a warp will execute the same code at the same time, if one thread grabs the lock, it can’t proceed since the other threads are stuck in the do while loop.
You’ll see this in Ruetsch and Fatica’s example where the atomiccas is only executed by one thread and used to perform the final sum reduction.
Hope this helps,
Mat
Thanks Mat
