Hi there,
Please have a look at my attempt at a complex datatype and basic maths operators. The overall aim is to provide a complex data type that is about as easy to use as a float. This code might evolve to something really useful, so check back frequently for updates. This is under a BSD style license so you can use it more or less like public domain.
The code is supposed to work in CUDA kernels in device and host mode as well as in plain old C/C++ functions (e.g. the Gold CPU kernels in the various SDK project templates). I’ve verified that this compiles in both the emulation mode and in the device mode. My compilation tests were on Mac Mini with the MAC OS X CUDA 1.1 SDK installed (No hardware CUDA GPU present apparently). I also tested this on Visual C++ 2005 Express on CUDA SDK 2.0 beta2 and executed it on a CUDA device.
The complex data type is implemented as a struct (not a C++ object), so no constructors are available. I named it cudacomplex in order to not conflict with existing complex types. Neither the built-in C99 _Complex data type nor std::complex are used.
Any comments about this approach? Useful? Could some things be done better? I’m listening…
I wonder if making the complex struct a C++ object would break things? Some folks said you can’t use C++ features in CUDA kernels, so was too scared to try ;)
I am getting some “expression has no effect” warnings on scalar assignments when compiling Debug or Release modes for the device, but scalar assignments do work despite the strange warning.
When assigning the scalar 0 to a complex and you receive an error related to ambiguity of the assignment operator, use .0f instead. that seems to work better.
Possible future enhancements:
-magnitude function (abs for complex numbers)
-conversion to polar representation and back
-add a double precision complex type for compute capability 1.3
-provide some trigonometry functions with complex arguments
-create 2x2 complex matrix types and related maths functions
WARNING and DISCLAIMER: This is NOT currently a replacement for the standardized <complex.h> header file which conforms to ISO/IEC 9899:1999(E). This is also not fully verified for mathematical correctness. Use at your own risk.
* Copyright (c) 2008 Christian Buchner <Christian.Buchner@gmail.com>
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* THIS SOFTWARE IS PROVIDED BY Christian Buchner ''AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL Christian Buchner BE LIABLE FOR ANY
* DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#ifndef CUDACOMPLEX_H
#define CUDACOMPLEX_H
// Depending on whether we're running inside the CUDA compiler, define the __host_
// and __device__ intrinsics, otherwise just make the functions static to prevent
// linkage issues (duplicate symbols and such)
#ifdef __CUDACC__
#define HOST __host__
#define DEVICE __device__
#define HOSTDEVICE __host__ __device__
#else
#define HOST static inline
#define DEVICE static inline
#define HOSTDEVICE static inline
#endif
// Struct alignment is handled differently between the CUDA compiler and other
// compilers (e.g. GCC, MS Visual C++ .NET)
#ifdef __CUDACC__
#define ALIGN(x) __align__(x)
#else
#if defined(_MSC_VER) && (_MSC_VER >= 1300)
// Visual C++ .NET and later
#define ALIGN(x) __declspec(align(x))
#else
#if defined(__GNUC__)
// GCC
#define ALIGN(x) __attribute__ ((aligned (x)))
#else
// all other compilers
#define ALIGN(x)
#endif
#endif
#endif
// Somehow in emulation mode the code won't compile Mac OS X 1.1 CUDA SDK when the
// operators below make use of references (compiler bug?). So instead we compile
// the code to pass everything through the stack. Slower, but works.
// I am not sure how the Linux CUDA SDK will behave, so currently when I detect
// Microsoft's Visual C++.NET I always allow it to use references.
#if !defined(__DEVICE_EMULATION__) || (defined(_MSC_VER) && (_MSC_VER >= 1300))
#define REF(x) &x
#define ARRAYREF(x,y) (&x)[y]
#else
#define REF(x) x
#define ARRAYREF(x,y) x[y]
#endif
typedef struct ALIGN(8) _cudacomplex {
float real;
float img;
// assignment of a scalar to complex
_cudacomplex& operator=(const float REF(a)) {
real = a; img = 0;
return *this;
// assignment of a pair of floats to complex
_cudacomplex& operator=(const float ARRAYREF(a,2)) {
real = a[0]; img = a[1];
return *this;
} cudacomplex;
// add complex numbers
HOSTDEVICE cudacomplex operator+(const cudacomplex REF(a), const cudacomplex REF(b)) {
cudacomplex result = { a.real + b.real, a.img + b.img };
return result;
// add scalar to complex
HOSTDEVICE cudacomplex operator+(const cudacomplex REF(a), const float REF(b)) {
cudacomplex result = { a.real + b, a.img };
return result;
// add complex to scalar
HOSTDEVICE cudacomplex operator+(const float REF(a), const cudacomplex REF(b)) {
cudacomplex result = { a + b.real, b.img };
return result;
// subtract complex numbers
HOSTDEVICE cudacomplex operator-(const cudacomplex REF(a), const cudacomplex REF(b)) {
cudacomplex result = { a.real - b.real, a.img - b.img };
return result;
// subtract scalar from complex
HOSTDEVICE cudacomplex operator-(const cudacomplex REF(a), const float REF(b)) {
cudacomplex result = { a.real - b, a.img };
return result;
// subtract complex from scalar
HOSTDEVICE cudacomplex operator-(const float REF(a), const cudacomplex REF(b)) {
cudacomplex result = { a - b.real, -b.img };
return result;
// multiply complex numbers
HOSTDEVICE cudacomplex operator*(const cudacomplex REF(a), const cudacomplex REF(b)) {
cudacomplex result = { a.real * b.real - a.img * b.img,
a.img * b.real + a.real * b.img };
return result;
// multiply complex with scalar
HOSTDEVICE cudacomplex operator*(const cudacomplex REF(a), const float REF(b)) {
cudacomplex result = { a.real * b, a.img * b };
return result;
// multiply scalar with complex
HOSTDEVICE cudacomplex operator*(const float REF(a), const cudacomplex REF(b)) {
cudacomplex result = { a * b.real, a * b.img };
return result;
// divide complex numbers
HOSTDEVICE cudacomplex operator/(const cudacomplex REF(a), const cudacomplex REF(b)) {
float tmp = ( b.real * b.real + b.img * b.img );
cudacomplex result = { (a.real * b.real + a.img * b.img ) / tmp,
(a.img * b.real - a.real * b.img ) / tmp };
return result;
// divide complex by scalar
HOSTDEVICE cudacomplex operator/(const cudacomplex REF(a), const float REF(b)) {
cudacomplex result = { a.real / b, a.img / b };
return result;
// divide scalar by complex
HOSTDEVICE cudacomplex operator/(const float REF(a), const cudacomplex REF(b)) {
cudacomplex result = { ( a * b.real ) / tmp, ( -a * b.img ) / tmp };
return result;
// complex conjugate
HOSTDEVICE cudacomplex operator~(const cudacomplex REF(a)) {
cudacomplex result = { a.real, -a.img };
return result;
#endif // #ifndef CUDACOMPLEX_H
