After the system is started, when you run the command to play or record an audio file for the first time, the system prompts Device or Resource busy
aplay.log (46.6 KB)
amixer -c jetsonxaviernxa cset name="I2S5 Mux" "ADMAIF1"
amixer -c jetsonxaviernxa cset name="x Left DAC Switch" 1
amixer -c jetsonxaviernxa cset name="x Right DAC Switch" 1
aplay -D hw:1,0 test.wav
If you run aplay -d hw:1,0 test.wav for the second time, there is no Device or resource busy prompt, And in ADMAIF1, the audio and video on the Internet page are normal.
n@n-desktop:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: tegrahdaxnx [tegra-hda-xnx], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: tegrahdaxnx [tegra-hda-xnx], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: tegrahdaxnx [tegra-hda-xnx], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: tegrahdaxnx [tegra-hda-xnx], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 0: ADMAIF1 CIF ADMAIF1-0 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 1: ADMAIF2 CIF ADMAIF2-1 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 2: ADMAIF3 CIF ADMAIF3-2 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 3: ADMAIF4 CIF ADMAIF4-3 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 4: ADMAIF5 CIF ADMAIF5-4 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 5: ADMAIF6 CIF ADMAIF6-5 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 6: ADMAIF7 CIF ADMAIF7-6 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 7: ADMAIF8 CIF ADMAIF8-7 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 8: ADMAIF9 CIF ADMAIF9-8 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 9: ADMAIF10 CIF ADMAIF10-9 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 10: ADMAIF11 CIF ADMAIF11-10 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 11: ADMAIF12 CIF ADMAIF12-11 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 12: ADMAIF13 CIF ADMAIF13-12 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 13: ADMAIF14 CIF ADMAIF14-13 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 14: ADMAIF15 CIF ADMAIF15-14 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 15: ADMAIF16 CIF ADMAIF16-15 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 16: ADMAIF17 CIF ADMAIF17-16 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 17: ADMAIF18 CIF ADMAIF18-17 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 18: ADMAIF19 CIF ADMAIF19-18 []
Subdevices: 1/1
card 1: jetsonxaviernxa [jetson-xaviernx-ape], device 19: ADMAIF20 CIF ADMAIF20-19 []
Subdevices: 1/1
When I used other ADMAIF except ADMAIF1, after the system started, I used the following command for the first time, but the system did not have Device or Resource busy prompt
amixer -c jetsonxaviernxa cset name="I2S5 Mux" "ADMAIF2"
aplay -D hw:1,1 test.wav
But I can’t hear the audio and video on the Internet page, I don’t know if you understand what I’m saying.
