Audio2Face Installation Error
Hello, when installing Audio2Face on Windows, I am getting this error when I click “install” or near the end of the installation, preventing A2F from installing:
Error occurred during installation of Audio2Face: request to (url) failed, reason: getaddrinfo ENOTFOUND (url)
(The actual urls in the error had to be cut because of the "new users can only put one link in a post) limitation
The launcher logs are attached here:
launcher.log (1.5 MB)
How should I fix this error?
Hello and welcome to the forums @totallyalemming
  • It might be worth updating the Launcher to see if this works.
  • Can you also try and see if you can install any other applications from Launcher, e.g. USD Composer?
Thanks for the reply. Selecting 'check for updates" did not do anything, so I assume my launcher is currently up-to-date.
Installing another application (Cache) did not work with the same error, and installing USD Composer also gave the same error as before. The launcher logs are here:
launcher.log (3.1 MB)
Thanks for trying and sending the log file. We’ve created ticket OM-100886 for this issue
